seems more people requested this. As I don;t have the hardware its dangerous to tell you what to do.
You can try to reach out to the author
Or if you want to take a walk on the wild side, I’ll take no ownership or support if it goes wrong or even fail your current installation.
sudo apt -y install build-essential
cd ~
wget https://github.com/Saiyato/volumio-audiophonicsonoff-plugin/raw/master/volumio-audiophonicsonoff-plugin.zip
mkdir ./onoff
miniunzip volumio-audiophonicsonoff-plugin.zip -d ./onoff
cd onoff
npm update (it might be possible that this is not even needed)
npm install --save onoff@6.0.0
volumio plugin install
cd ..
rm onoff
rm volumio-audiophonicsonoff-plugin.zip
Hello
I have the same device and I asked audiophonics for this plugin. For the moment, the plugin is not working, but they proposed to edit some configuration files so you can invoke directly a dtoverlay and have 90% of the functionality of the power manager without using a plugin or installing anything. Just add these two lines in /boot/userconfig.txt:
dtoverlay=gpio-poweroff,gpiopin=22,active_low
dtoverlay=gpio-shutdown,gpio_pin=17,active_low=0,gpio_pull=down
and the power manager should be functional on the next reboot. This method works on almost any system running on Raspberry Pi (but does not react to reboot / poweroff initiated from another source than the on/off button).
We have already notified plugin’s developer of the problems with kernel 6.6.59, where GPIO addressing is different.
Unfortunately we do not have any ETA when this will be fixed. As such, we are discussing how to support seemingly obsoleted plugins with our internal resources.
Whilst devs are busy with priority tasks, you could help testing plugin change prototype. This is unsupported, ensure that you have backup of your settings, libraries, etc.
Extract attached file, where extracted file name should be index.js
Hi, I have the 1.0.5 edition installed on rel. 3.785 with Audiophonics I-Sabre v4 ES9023. It’s a
clean install and also have the same issue. cannot power down via the button, the light flashes continuously and the add-in is shown as inactive. Did not have an issue prior to this.
