[PLUGIN] YouTube2
only the latest version v1.1.4 (beta) should work oke.
testing here but all is playing.
what version of volumio do you use? and what plugins versions are installed ?
do you have a log file so we could look at it?
here are the steps copy the link to the log and we could take a look what’s happening.
it’s giving a log of your system what’s goining on like wifi conected things what’s loaded errors sevices settings ect. no personal stuff post the link here.
the techs here should find what’s goining on but you can look at it too it’s just a logo of the things that the system does and response like a error log of the system and what’s loaded connections services ect
some parts you will understand and some i even don’t get yet :slight_smile:
but please post the link to the log so we could check and see what’s going on.
i see some errors but have to check if that is recoverble but don’t know who is active at this time
@Darmur dario can you look at his log if it’s fixable.
i see errors on drive 1 and 3 , undervoltage, dirtybit , time error ( out of sync ),problems getting info debain.pool
@patrickkfkan can you take a look at this.
I don’t see anything strange, better to ask @patrickkfkan
When you try to enter the plugin, the logs should capture the following line:
Mar 30 21:57:10 volumio-pi volumio[14572]: info: [youtube2-browse] browseUri: youtube2
I don’t see this in your logs. So either you neglected to actually capture the moment you enter the plugin, or Volumio failed to pass command to the plugin.
Also, in case you weren’t aware, you need to restart Volumio everytime you update a plugin, otherwise Volumio will just load the old plugin files.
Hmm interesting. I swear I had it working sometime. But now the song comes up but wont play.
Not sure if I’m missing something. Ive checked im logged in.
Install the beta version
Thank you. All versions I look at say stable.
Is the beta version somewhere else?
  • Uninstall current version.
  • Enable “Plugins Test Mode” in http://<volumio address>/dev
  • Find the YouTube2 plugin in the plugin store. Click the Details button under it and choose latest beta version to install.
  • Restart Volumio.
All steps mandatory.
Legend worked perfectly. Thank you.
Works like a charm the beta version! I have 160 kbps sound coming out my setup… My question is: can I see the vid as well? I have the now playing plugin installed, but there you only see a static cover.
@Quanticus volumio doesn’t support video…
Pls. post in the thread for the plugin.
Dear colleagues,
I am a beginner to streamer play. I have installed the Volumio on RPi4B with Audiophonics Evo Sabre Q2M DAC box. It has worked very well for my purposes of music play from local files, radios and YouTube, too. But a few days ago, suddenly the YouTube streaming did not work (music search, screen show-up OK but no play, just stopped) though those local files and radios are still working very well. I checked the plugin, the YouTube2, which was version 1.1.5 and the plugin storage shows a button, Update, and so I tried to update. The screen showed successful update but not working again. When I checked the plugin again, there are 1.2.0(beta). 1.1.6(beta), 1.1.5(stable), 1.1.4 & 1.1.3(stable). I tried one by one from 1.1.3 to 1.2.0 but not working, too. When I tried to 1.1.6 and 1.2.0(beta), the installed version resulted in 1.1.5(stable). I produced a log file and found ‘error’ in YouTube keyword lines but I could not interpret. Help is needed, please.
My log file is following;
http://logs.volumio.org/volumio/09KIQCE.html
The plugin should be released as stable tonight or tomorrow.
