[PLUGIN] YouTube Music
Still no bueno with 2.3.4 on 4.0.26. I get album art to load, but nothing actually plays.
EDIT: Well, that’s weird. Hit play, wait 3 minutes and then everything starts playing. So I guess its working (just slow).
Where do I find the betas? I activated the test mode, but it’s still 2.3.2 showing…
Also I have Volumio 4.011 and it says the system is up to date when looking for updates. Did I got cut off or something like that? (Volumio is running in a proxmox VE)
Ok, I found the “Test” Channel - updated both Volumio (4.027) and the player, sitt the "failed to decode…2 Error
Edit of edit - I klicked on 2.3.4 but failed to check - had the 2.3.2 installed (Klick on “Details” and choose 2.3.4(beta)) - now it plays. Yay!
Hey, was looking “everywhere” to find the 2.3.4 (beta)… Clicking on “Details” was beyond me… deinstalled whatever version of YTM I had, rebooted and installed the 2.3.4 beta and now it WORKS!!! This is on volumio 4.026. Thank you @patrickkfkan !!!
@patrickkfkan Thanks for the update! YouTube keeps breaking things, but you always manage to fix it — much appreciated!
@patrickkfkan .
Thanks for your works !! It seems that YouTube has once again broken the plugins…
Yeees! :sob:
Confirm,
plugin not work
Just installed Volumio faught to get the youtube plugins working (ythat was just 2 days ago) and now not working again. It seems they break a lot ? Just bought a DAC to try out as well :frowning:
Not working for me again :frowning:
403 error
Same problem. YT Music wont work…
Thanks @patrickkfkan - working again.
Grazie @patrickkfkan !! Working again perfectly.
Does the youtube music plugin work for you? Since yesterday, playback doesn’t start. Volumio Version 4.089., plugin 2.4
mine also does not work. video stuck at the beginning
Similar, but I’m on volumio 4.097. YouTube Music doesn’t play anything. Its not throwing an error that I can see. I updated to a new cookie to make sure that wasn’t the issue either.
Update: looked at the dev logs and this is the error it is throwing:
error: [ytmusic] Innertube support service: TypeError: exportedVars.nFunction is not a function
    at eval (eval at evalFnImpl (/data/plugins/music_service/ytmusic/node_modules/volumio-yt-support/dist/lib/innertube/Service.js:29:12), :16:26)
    at evalFnImpl (/data/plugins/music_service/ytmusic/node_modules/volumio-yt-support/dist/lib/innertube/Service.js:29:26)
    at Object.evalFn (/data/plugins/music_service/ytmusic/node_modules/volumio-yt-support/dist/lib/innertube/Service.js:65:48)
    at /data/plugins/music_service/ytmusic/node_modules/volumio-yt-support/dist/lib/innertube/Server.js:96:96
    at Layer.handleRequest (/data/plugins/music_service/ytmusic/node_modules/router/lib/layer.js:152:17)
    at next (/data/plugins/music_service/ytmusic/node_modules/router/lib/route.js:157:13)
    at Route.dispatch (/data/plugins/music_service/ytmusic/node_modules/router/lib/route.js:117:3)
    at handle (/data/plugins/music_service/ytmusic/node_modules/router/index.js:435:11)
    at /data/plugins/music_service/ytmusic/node_modules/router/index.js:295:15
I have the same error.
Same problem here also.
Same here :frowning:
sadly the plugin does not play any files anymore
a proper oauth implementation will be the only solution
Here also no playable yt music tracks. You can search them en click them to play, but wait in silence for that that never sounds. Please fix it, because i like the plugin really wel. As whole volumio runs as stable platform, i wil become premium member, but for now it seems to fragile
