I can’t get it installed on a Raspberry Pi 4 with the latest Volumio either. ![]()
Updated YouTube2, YouTube Music and YouTube Cast Receiver plugins for Bookworm-based Volumio.
There will be no further updates of these plugins for current Buster-based Volumio. It is too time-consuming for me to make modern libraries used by the plugins work in a legacy environment. I do not want to do that anymore now that Bookworm is available.
Now would be a good time to test the Bookworm release and report any issues to the developers.
Everything is working great, thanks for the update! ![]()
Thank you @patrickkfkan . It works great with Bookworm 0.68.
I instsalled the update but got error when playing content. Volumio 3.812
There is no update for V3.812
Only bookworm version will be updated.
ohh I see. On the plugin installing option it says plugin updated 21-05 that is why I got confused.
I think something are not ok after uninstall reboot and install all new plugin there are again in old version and upgrade not work
regards
Looks like you are still on Buster-based Volumio
Oh yes,
sorry I’m at work and not read carefully your post, in Buster no update of plugin.
I’m waiting Bookworm -Based will be out of alpha
thanks
@patrickkfkan Thank you – the version on Bookworm is working perfectly. Many thanks for that! ![]()
I too can confirm that YT Music works fine in Bookworm 0.68. As a bonus, YT Cast also works which has never worked for me in Buster. Cheers and Thanks @patrickkfkan
It’s not working here I tried both version 0.68 and 0.69.
I have tested today in Bookworm RPI5 and YouTube Music not work:
YouTube2 work
First of all, thanks a lot for your work-
I’ve also installed the Bookworm-based Volumio and now the YouTube plugins are working.
Today I’ve got the upgrade to Volumio version 4.001.
So again thanks.
I am on 0.069 and the plugin works there. However, for some reason I am capped to 160kbps vbr even though I have Premium. Below is an example but it’s the same for every song.
{“status”:“pause”,“position”:1,“title”:“Comfortably Numb”,“artist”:“Pink Floyd”,“album”:“The Wall”,“albumart”:“https://lh3.googleusercontent.com/QzNl1QDss7d8vpvjiK7w8ZEHw1rhGQCMux0_S2WHv3eRrIb7wxIyZX0g2BB6zlaF1ZYF0JcJbNcA2r0=w701-h701-s-l90-rj",“uri”:“ytmusic/song@explodeTrackData:o={“type”%3A"song”%2C"title"%3A"Comfortably%20Numb"%2C"artist"%3A"Pink%20Floyd"%2C"album"%3A"“%2C"albumart”%3A"https%3A%2F%2Flh3.googleusercontent.com%2FQzNl1QDss7d8vpvjiK7w8ZEHw1rhGQCMux0_S2WHv3eRrIb7wxIyZX0g2BB6zlaF1ZYF0JcJbNcA2r0%3Dw701-h701-s-l90-rj"%2C"endpoint"%3A{“type”%3A"watch"%2C"payload"%3A{“videoId”%3A"x-xTttimcNk"%2C"playlistId"%3A"OLAK5uy_lIWmRjuoVdY_4auy8RmM8NdA_951AV7NA"%2C"index"%3A1}%2C"musicVideoType"%3A"MUSIC_VIDEO_TYPE_ATV"}%2C"autoplayContext"%3A{“fetchEndpoint”%3A{“type”%3A"watch"%2C"payload"%3A{“playlistId”%3A"OLAK5uy_lIWmRjuoVdY_4auy8RmM8NdA_951AV7NA"%2C"videoId"%3A"lku1fP-LszI"}}}}",“trackType”:“YouTube”,“seek”:6250,“duration”:382,“samplerate”:"VBR 160 kbps”,“channels”:2,“bitrate”:null,“random”:null,“repeat”:null,“repeatSingle”:false,“consume”:true,“volume”:9,“dbVolume”:null,“mute”:false,“disableVolumeControl”:false,“stream”:false,“updatedb”:false,“volatile”:false,“service”:“mpd”}
No, that’s off.
Not working here. I have tried 4.005 4.004 0.069 0.068, and still not working. I live in Denmark. I have Rspberry Pi Zero 2
