[PLUGIN] YouTube Music
L’ho fatto mille volte. Sto provando anche a installare tutto da zero.
Grazie
I have done this. I am also trying to install everything from scratch.Thank you.
Nulla. Installazione fatta da zero. Solo Youtube Music come plugin. Copiato cokie nuovo. La ricerca dei brani funoziona ma quando metto in play non va. Qualcuno può aiutarmi ? Grazie
Nothing. Installation done from scratch. Only Youtube Music as a plugin. Copied new cokie. Track search works but when I put on play it doesn’t go. Can anyone help me ? Thank you
Resolved.
I am writing with the hope that I can help someone.I own an Asus Tinkerboard. I have always installed starting with version 3.512-2023-06-25-tinkerboard and then updating directly from system. Now I have instead directly flashed version 3.779-2024-11-08-tinkerboard and then installed the YoutubeMusic plugin. Now it works correctly.
Risolto.
Scrivo con la speranza che possa aiutare qualcuno.
Posseggo una Asus Tinkerboard. Ho sempre effettuato l’installazione partendo dalla versione 3.512-2023-06-25-tinkerboard e poi aggiornando direttamente da sistema. Ora ho invece flashato direttamente la versione 3.779-2024-11-08-tinkerboard e ho poi installato il plugin per YoutubeMusic. Ora funziona correttamente.
At the moment it looks like the cookie has to be renewed every few days (maybe a week) for YouTube Music to continue to work.
“My” Cookie works the third week now. I’m constantly logged in via phone (volumio was offline for maybe 12 days inbetween).
Hmmmm… Somehow it doesn’t work…
  • had installed YTM plugin 1.2.3 version on latest volumio 3.785, uninstalled YTM plugin
  • rebooted my RPI
  • installed the YTM 1.2.3. version
  • enabled YTM plugin, settings, entered cookie
  • click on YTM plugin in main menu, plugin starts
  • click on whichever link inside YTM (Home, Explore Library, History), I get “Error No results” inside red box
  • try to access plugin settings again, nothing happens (“blank screen”, empty page for settings)
@patrickkfkan … when you have some free (of your valuable) time, please take a look…
Try getting the cookie again. It’s working ok for me, but needs a new cookie regularly.
Unfortunately, can not get to plugin settings any more… tinkering with disable/enable plugin and then settings gets me this:
So can not enter a new cookie…
Looks like google messed with YTM api again…
I don’t think your issue is related to another YT api change. I again had the ‘no results’ error this evening (the cookie seems to expire almost daily now), but no problem getting a new cookie and getting the plugin to work again.
thanx @SimonE , you were right - it was something at my installation… after uninstalling YTM, reboot, installing YTM, reboot, enabling plugin, setting the cookie… now it works!
Did something break again? My youtube music stopped working from yesterday - getting “Failed to Decode” error message. Tried with a new cookie, still the same.
Hi Folks
need your Help , , now long time Youtube broadcast dont work, on RPI 4 with 8BG ram, i just update to the newest version , but still dond work, i was in dev mod enabled test mode and all other m reinstal and instal …bit nothing, on scream or display says in volumio and phone taht is conect no RED failure on something else, spotify and Tidal woks perfect
please for HELP
Same here :frowning:
Still working for me, after refreshing the cookie.
right. still working. thanks for the information
since one week YTM and YTM2 can’t work in Raspberry PI5 also
Regards
You must deinstal youtube broadcast,
in dev.mode enable test mode,
then updste Volumio to the newast wersion ,
restart
than instal youtubebroadcast end enable
restart
than it s work
Ps before you play fom youtube first connect volumio than play music
ok I have re-install Volumio because all other operations can’t work, now it work
Great …
Yes but before plugin was working without use YTM from Smartphone
