You got the YouTube link to a track that gets cut, so I can test it here?
in raspberry PI5 with Youtube Music after install plugin Peppy-Meter-Basic track are reproduced without audio, after remove Peppy-Meter and reboot everything goes back to normal.
Now except from the Autoplay thing it works fine!
(When I click on the first song of the āTop 3ā category in the search, it is playing all three songs even with disabled autoplay.)
Thanks a lot Patrick for your huge effort to provide that service for us!
(BTW whatās the difference between youtube2 and youtube music? Once I switched from youtube 2 to music but no idea why)
This is not autoplay. This is simply Volumio adding all three songs to the queue. Autoplay is when the queue ends, the plugin fetches more songs and add them to the queue for playback.
YouTube2 vs YouTube Music is pretty much the same as visiting www.youtube.com and music.youtube.com. One focuses more on videos and the other more on music (songs, albums and artists). Because YT Music gives you mainly songs (as opposed to videos), if you have YT Premium you get 256 kbps streaming vs 160kbps for videos.
Oh, ok. I donāt like that feature ![]()
Then Iām at the right place with YT music. Thanks! ![]()
Good evening, today youtube music and youtube2 donāt go in play anymore ! How can I do ? Thanks
http error no work anymore failed to decode ā¦
Regards
Try stopping and restarting the plugin. Or Google might have changed something again ā although I havenāt been affected yet.
I also had problems. Renewing the cookie did the trick.
@ patrickkfkan
I go back to Volumio-3.779-2024-11-08-pi and now go again, with last version also wifi after restart not work, for use Spectrum plugin I have to set no mixer.
This worked for me. The cookie seems to have an expiry on it; getting a new one works.
Huge thanks to @patrickkfkan for maintaining this YouTube Music plugin and working around the mess Google throws at us.
Happy holidays to everyone!
Hello, I just installed your plugin and inserted the cookie as intended. It stopped working after a while, but I checked this topic and refreshed the cookie as other users suggested, with successful results. My issue is that, before itād stop working, it would normally play fully through tracks with the āGapless Opus Streamsā option enabled, now, even if I enable it, it just skips the track when itās about to end, usually 10 seconds earlier: this seems to happen with any track Iāve tried. What could be causing this/am I doing anything wrong (unsure as Iām a beginner)? Thanks in advance and happy holidays.
Good evening everyone, my youtube music is not working anymore. Even renewing the cokies gives me error and it doesnāt work. The track search works but when I send to play it fails to decode the stream.
Can anyone help me ? Thank you
mine works ok so farā¦
yes from yesterday work again without any changeā¦
Grab a new cookie, worked for me.
