[PLUGIN] YouTube Music
Here’s my search screen in YT Music:
Your log entries do not show anything about the search, so I don’t know what’s going on. Also for playback, I see the player clearerror but it doesn’t say what error it encountered. Perhaps a full bug report would show more useful info.
Also, if you’re updating from a previous version, make sure you reboot Volumio after the update.
… updated to the new version.
Now the search function is broken.
Playing youtube-tunes in general is possible.
When i try to access youtube songs that i have already in volumio playlists all is good.
I can play single songs and albums under “Explore”.
So the only problem seems to be the search function.
Thanks for your work. Highly appreciated.
See my reply just above your post. I need logs for the search function because I don’t have this problem myself. Also what do you mean by “search function is broken”? Does it keep on loading without showing anything, or does it show a “No items” / “No results” message?
… concerning logs i tested a search and this was in the logs:
Dec 13 11:45:03 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: ytmusic , handleBrowseUri
Dec 13 11:45:03 volumio volumio[842]: info: [ytmusic-browse] browseUri: ytmusic
Dec 13 11:45:03 volumio volumio[842]: info: Preload queue cleared
Dec 13 11:45:07 volumio volumio[842]: Searching plugin music_service/ytmusic
Dec 13 11:45:07 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: ytmusic , search
Dec 13 11:45:09 volumio volumio[842]: Searching plugin music_service/ytmusic
Dec 13 11:45:09 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: ytmusic , search
Dec 13 11:45:13 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Dec 13 11:45:13 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Dec 13 11:45:13 volumio volumio[842]: info: Discovery: Getting this device information
Dec 13 11:45:13 volumio volumio[842]: info: CoreCommandRouter::volumioGetState
Dec 13 11:45:13 volumio volumio[842]: info: CorePlayQueue::getTrack 0
Dec 13 11:45:13 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Dec 13 11:45:43 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Dec 13 11:45:43 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Dec 13 11:45:43 volumio volumio[842]: info: Discovery: Getting this device information
Dec 13 11:45:43 volumio volumio[842]: info: CoreCommandRouter::volumioGetState
Dec 13 11:45:43 volumio volumio[842]: info: CorePlayQueue::getTrack 0
Dec 13 11:45:43 volumio volumio[842]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
… search function keeps on loading without showing something.
OK. I’ll look into this later.
Yes, that’s the version showing up in the list and once installed, it turns to 1.2.0
Edit: Now it’s 1.2.2 but doesn’t work either.
DId you reboot after installing?
Yes!
I can now play 1 song, what was in my list. The search simply stops at ca. 95% status bar.
And after that nothing happens…
I have now version 1.2.2 and it tells I’m signed in.
So search is not working - this has been reported by other users and I’m investigating this. What about the other functionality?
“Explore” shows tracks but I can’t click them (after I rebooted like the 100th time :D, before, “Explore” showed nothing)
So nothing happens when you click them? You got any logs showing what’s going on in the background when you click a track in “Explore”?
EDIT:
Obwiously the broken “search” blocked the playback of the tracks in “Explore” :woman_facepalming: I’m sorry.
So it’s just the broken search. The progress bar stops right before the end.
Search function fixed in v1.2.3 . Wait until it gets released in the plugin store (thanks @balbuze !)
Remember to reboot after updating.
… sounds good. I check it out asap :slight_smile:
Just installed v1.2.3 and rebooted, everything works except search function, as @Daraia states progress bar stops just before the end, no search results ever get displayed.
Double-check under “Installed Plugins” that you really have v1.2.3 installed. Most likely it will say v1.2.2. Volumio’s plugin store interface is confusing when it comes to beta vs stable releases.
… yes it is strange. I activated plugins test mode rebooted and installed version 1.2.3.
Rebooted again and version 1.2.2 is installed.
I thought different installable versions would show up when clickling on details. But only “youtube music plugin for volumio” shows up…
Should be ok now. But strange behavior with plugins store and beta for this one…
Grazie mille.Ora sembra funzionare tutto bene. Delle volte i brani vengono “tagliati” senza arrivare alla fine. E’ un problema solo mio ?
Thank you very much.Now everything seems to work fine. Sometimes the tracks are “cut” without reaching the end. Is this only my problem ?
went to plugin store, clicked update and then reboot and everything works now, browsing, playback and search box too! thanks!
