Both plugins released as stable!
Enjoy! ![]()
Tested YT Music today on my good old rPi 3B and works great, so BIG thanks for that.
Hereās the outcome after todayās test.
Sign in: working
Browsing: working
Playback: working
Search: not working
Thanks again!
Im having a bit of an issue with my youtube music plugin. The cookie works fine and I can sign in, browse and search. However I select something to play and it will seem to halt and then once I refresh my screen it shows the album art but nothing is playing. It shows the seconds move but only when I refresh the page. Strangely I try spotify and it works and plays fine. Ive tried restarting, re installing a few times now and still nothing makes it play properly. Iāve enabled the logs and this is what im seeing
info: [ytmusic-play] clearAddPlayTrack: ytmusic/video@explodeTrackData:o=%7B%22type%22%3A%22video%22%2C%22title%22%3A%22Overture%20(Live%20from%20the%20Royal%20Albert%20Hall)%22%2C%22artist%22%3A%22Dua%20Lipa%22%2C%22album%22%3A%22%22%2C%22albumart%22%3A%22https%3A%2F%2Fi.ytimg.com%2Fvi%2F8cdR_qh-FtI%2Fhq720.jpg%3Fsqp%3D-oaymwEXCNUGEOADIAQqCwjVARCqCBh4INgESFo%26rs%3DAMzJL3ksqNRJY_5Bb_HczXMOaBSD1Ng9LA%22%2C%22endpoint%22%3A%7B%22type%22%3A%22watch%22%2C%22payload%22%3A%7B%22videoId%22%3A%228cdR_qh-FtI%22%2C%22playlistId%22%3A%22OLAK5uy_m3euCKWKzGGw_cZdUxEYUmgbaxunEALq0%22%2C%22params%22%3A%22OAHyAQIIAaIDC21aNDRwb0JOT0tN%22%2C%22index%22%3A0%2C%22playlistSetVideoId%22%3A%2277818B147BC796F4%22%7D%2C%22musicVideoType%22%3A%22MUSIC_VIDEO_TYPE_OMV%22%7D%2C%22autoplayContext%22%3A%7B%22fetchEndpoint%22%3A%7B%22type%22%3A%22watch%22%2C%22payload%22%3A%7B%22videoId%22%3A%228cdR_qh-FtI%22%2C%22playlistId%22%3A%22OLAK5uy_m3euCKWKzGGw_cZdUxEYUmgbaxunEALq0%22%2C%22params%22%3A%22OAHyAQIIAaIDC21aNDRwb0JOT0tN%22%2C%22index%22%3A0%2C%22playlistSetVideoId%22%3A%2277818B147BC796F4%22%7D%2C%22musicVideoType%22%3A%22MUSIC_VIDEO_TYPE_OMV%22%7D%7D%7D
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
info: CoreCommandRouter::executeOnPlugin: metavolumio , getInfinityPlayback
info: CorePlayQueue::getQueue
info: Listing playlists
info: CoreCommandRouter::executeOnPlugin: wizard , getOnboardingWizard
info: CALLMETHOD: system_controller my_volumio retreiveBackendEventStates undefined
info: CoreCommandRouter::executeOnPlugin: my_volumio , retreiveBackendEventStates
info: Received Get System Version
State here: Plugin says Iām signed in however I canāt search nor play. I keep trying.
Wonder if this is the same issue im having too. Says im signed in but just wont play
Same here. I can sign in and see my albums and playlists, but nothing plays.
I get the following error:-
Error
I canāt see mine
⦠that sounds good.
I will give it a try when i come home. I hope version 1.2.1 somehow appears ![]()
Thx for all the work you put in the plugin
Strange. I was convinced I installed the 1.2.1 version, of course it didnāt work. When looking in the plugnin list, the 1.2.0 is installed. I donāt get it ![]()
Next try tomorrow! ![]()
Latest is v1.2.2 . @balbuze might be busy. Perhaps @nerd can help in unblocking the ābetaā status of the YT plugins?
Sorry for the delay. Iāll be able to have a look in one hourā¦
I see that
I had to push Youtube2 1.3.3 as stable. It seems the problem was due to the fact we removed the plugin from the store.
Youtube2 1.3.3 install ok. But canāt play. Iām not connected. I donāt use it, so I donāt know what should happen.
Iām going to check other plugin.
Tried to update to v1.2.2, now it doesnāt work, I can successfully sign in and browse in my account, but unable to play anything, Iāll keep checking the coming days, thanks again to the developer ![]()
Pushed youtube music v1.2.2.
Remove previous version. Reboot and install it.
Thanks @balbuze. I can see and install both plugins now.
I think Volumio should show a message reminding users to reboot every time a plugin is updated / installed.
This the case only for beta⦠But as we removed previous version from the store and restore (first time it happens) with new version, it seems to be the cause⦠But if now ok, super! Thank you for your work! ![]()
1.2.2 is working fine again.
YoutubeMusic version 1.2.2. plays correctly but search doesnāt go.
Youtube2 version 1.3.3 doesnāt work !!!
hank you very much
Starting Live Log...
serial-getty@ttyS3.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Reloading.
/lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid ā /run/samba/winbindd.pid; please update the unit file accordingly.
Reloading.
info: enable SSH service success
info: Preload queue cleared
info: CoreCommandRouter::volumioReplaceandPlayItems
info: CoreStateMachine::ClearQueue
info: CoreStateMachine::stop
info: CorePlayQueue::clearPlayQueue
info: CorePlayQueue::saveQueue
info: CoreCommandRouter::volumioPushQueue
info: CoreStateMachine::addQueueItems
info: CorePlayQueue::addQueueItems
info: Adding Item to queue: youtube2/generic@endpoint:o=%7B%22type%22%3A%22browse%22%2C%22payload%22%3A%7B%22browseId%22%3A%22UCcXkVzu0xAvW7gQNKNZlH7g%22%7D%7D
info: Using cached record of: youtube2/generic@endpoint:o=%7B%22type%22%3A%22browse%22%2C%22payload%22%3A%7B%22browseId%22%3A%22UCcXkVzu0xAvW7gQNKNZlH7g%22%7D%7D
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: CoreCommandRouter::volumioPlay
info: CoreStateMachine::play index 0
info: CoreStateMachine::play index undefined
info: CoreStateMachine::startPlaybackTimer
info: [youtube2-play] clearAddPlayTrack: youtube2/video@endpoint:o=%7B%22type%22%3A%22watch%22%2C%22payload%22%3A%7B%22videoId%22%3A%228vY6WvwPSzc%22%2C%22playlistId%22%3A%22PLxPBJ9UVuE7iH1gXS1RCkCEgSvuFs5ozu%22%2C%22params%22%3A%22OAE%253D%22%2C%22index%22%3A0%7D%7D@explodeTrackData:o=%7B%22title%22%3A%22Ozork%C3%B3w%20Tesco%202%22%2C%22artist%22%3A%22James%20L.%20Rozier%22%2C%22albumart%22%3A%22https%3A%2F%2Fi.ytimg.com%2Fvi%2F8vY6WvwPSzc%2Fhqdefault.jpg%3Fsqp%3D-oaymwEcCNACELwBSFXyq4qpAw4IARUAAIhCGAFwAcABBg%3D%3D%26rs%3DAOn4CLCpZ1xl22d-s79yWkmftD4m1a03Zw%22%2C%22endpoint%22%3A%7B%22type%22%3A%22watch%22%2C%22payload%22%3A%7B%22videoId%22%3A%228vY6WvwPSzc%22%2C%22playlistId%22%3A%22PLxPBJ9UVuE7iH1gXS1RCkCEgSvuFs5ozu%22%2C%22params%22%3A%22OAE%253D%22%2C%22index%22%3A0%7D%7D%7D
info: sendMpdCommand stop took 9 milliseconds
info: sendMpdCommand clear took 1 milliseconds
info:
---------------------------- MPD announces system playlist update
info: Ignoring MPD Status Update
info:
info: sendMpdCommand addid "https://rr1---sn-uxaxpu5ap5-jp5l.googlevideo.com/videoplayback?expire=1734102298&ei=uvhbZ7GALeKvi9oPiqvSmA0&ip=79.19.246.233&id=o-AJlHy6bTMML3gLU8A73Ji6zJ3fag_h4J5kxipC-m1ilD&itag=140&source=youtube&requiressl=yes&xpc=EgVo2aDSNQ%3D%3D&met=1734080698%2C&mh=oT&mm=31%2C29&mn=sn-uxaxpu5ap5-jp5l%2Csn-hpa7zn6s&ms=au%2Crdu&mv=m&mvi=1&pl=24&rms=au%2Cau&initcwndbps=2257500&siu=1&bui=AfMhrI-ePC1lTT950Svv82ynOBllVYHMUFFNZZdBa-f9YYUbXxbQqT2fbWHOmEGbxnnKrp6y4A&spc=x-caUGjMFskgeV7-ZlvH_4lZSfgZ0QYxsT_gkPS9QkU2G8BkibQHN-1GFTfAmJDon-zS3Qj_gqwx&vprv=1&svpuc=1&mime=audio%2Fmp4&ns=fJoLcceo3WWa_dudD8jQlswQ&rqh=1&gir=yes&clen=497144&dur=30.650&lmt=1712215253950785&mt=1734080237&fvip=2&keepalive=yes&fexp=51326932%2C51335594%2C51347747%2C51355912&c=WEB&sefc=1&txp=1432434&n=EggM7bOgirkqAA&sparams=expire%2Cei%2Cip%2Cid%2Citag%2Csource%2Crequiressl%2Cxpc%2Csiu%2Cbui%2Cspc%2Cvprv%2Csvpuc%2Cmime%2Cns%2Crqh%2Cgir%2Cclen%2Cdur%2Clmt&sig=AJfQdSswRQIhAP0iIy3-5f9TvO-_NGRMsDszS0TZHfnZonKfAUYGpRaeAiA5gO_JgGoGep0MM7uT1JbxmMTLWQFVfKmNUhy38MUMcg%3D%3D&lsparams=met%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps&lsig=AGluJ3MwRgIhAIXNTg_2QYGGQ5WXNMvZG53NbsfO8wtOxbKyMSEJddLBAiEAt77vuJw3w8ubVVoP0Ee0l3oW4GTFWBWUVu6jKh5XrUU%3D&pot=MpgBmboATOB03zCZhvWNTfw0_HQDYbbodEMuGTf3j1zXbSAgzKGIhHRJRbnGufckpAbYpp8BBmmg9HRlB1op6QYa2H8X9G0R4O2TvlVGCJ8QOrGUW6lIPxkxbKHBN41OpEMdxZmo6hyij1hhcPpN1_7f3nIDAGTAIX2Ssgdl4-hl13qpmHb2z3TU0nJ2jWTl8_D5KLWUYNl85nk%3D&cver=2.20241121.01.00&t.YouTube" took 3 milliseconds
info:
info:
info:
info: ------------------------------ 5ms
info: ------------------------------ 6ms
info: ------------------------------ 3ms
info: CoreStateMachine::setConsumeUpdateService mpd
info:
info:
info: sendMpdCommand play took 5 milliseconds
info: ------------------------------ 4ms
info:
---------------------------- MPD announces state update: player
info: ControllerMpd::getState
info:
info:
info: sendMpdCommand status took 9 milliseconds
info: sendMpdCommand status took 10 milliseconds
info: sendMpdCommand clearerror took 18 milliseconds
info: sendMpdCommand clearerror took 15 milliseconds
info: sendMpdCommand clearerror took 14 milliseconds
info: sendMpdCommand playlistinfo took 6 milliseconds
info: sendMpdCommand playlistinfo took 4 milliseconds
info: ControllerMpd::pushState
info: CoreStateMachine::syncState stateService stop
info: CoreStateMachine::syncState currentStatus stop
info: No code
info: No code
info: No code
info: ------------------------------ 138ms
info: ------------------------------ 137ms
Soliciting pool server 93.94.88.51
