[PLUGIN] YouTube Music
@patrickkfkan I am having the same issue after updating to the latest beta version.
I unloaded and reloaded last stable version (v. 1.1.5) but still no playback. Logs at http://logs.volumio.org/volumio/HyNb6fq.html indicate there is a playback bug and to contact you.
Jul 18 09:01:33 musicbox2 volumio[949]: InnertubeError: Something went wrong at PlaylistExpandableMessage!* *Jul 18 09:01:33 musicbox2 volumio[949]: This is a bug, please report it at https://github.com/patrickkfkan/Volumio-YouTube.js/issues
Might have to reflash and reload but I will check on my other player to confirm.
Regards,
I am confused. Your screenshot shows YouTube2 plugin, and you said you updated to latest beta version, but then you said you unloaded and reloaded latest stable. So in other words you are running v1.1.5, a version which is known to have issue with playback.
So I checked your logs and there was no mention of YouTube2 plugin at all. They do mention the YT Music plugin, which you have v1.1.0 installed – again, a version known to have playback issues. v1.1.1 (beta) is what you need to be running.
Also, if you are having issues with beta version, check that you have in fact installed it properly through the following steps:
Sorry I may have posted on the wrong thread but I’m using the YouTube plugin not YouTube2 and I’m installing using the steps indicated. I will recheck, try again and get back to you.
Thank you for your prompt response and your continuing efforts in keeping the plugins updated.
Regards,
All good now. V.1.1.1 has been moved out of beta and is running fine. Thanks again …
After struggling with this for several days, I found Version 1.1.1 which seems to be working.
v1.1.1 has been in the beta channel for more than a week… you probably missed it because you didn’t arrive at this thread sooner and Volumio made installation of beta plugins as convoluted as it can be.
I am new to Volumio. Had installed the Youtube Music Plugin (1.1.1) couple of days back. It worked fine for a day or two. But from yesterday it is not working. If I click on the Play button of one of the songs in search results, it shows an error in the orange colored box, as somebody else had posted here earlier. Any help?
See here:
All working again. Thanks!
Thank you, It works.
Hi, I am having the same problem, I have tried reinstaling the plug in but did not help.
Version 1.1.2 is working properly, please check that you followed all the steps:
Plugins are currently in beta channel. To update:
  • Uninstall current version (1.1.2).
  • Enable “Plugins Test Mode” in http://<volumio address>/dev
  • In the plugin store, click the Details button under the plugin you want to install and choose latest beta version.
  • Restart Volumio.
(All steps mandatory)
All youtube plugins from @patrickkfkan are now released as stable.
no need for
:wink:
Speedy!
Thanks, yes that worked
Did it break again? Not working for me from last two days.
Version 1.1.2 is working ok for me.
Updated v1.1.3, which should fix the playback and sign-in issues (latter needs more testing though).
Currently in beta channel, which you can install as follows:
  • Uninstall current version.
  • Find the YouTube Music plugin in the plugin store. Click the Details button under it and choose latest beta version to install.
  • Restart Volumio.
Thanks. I tested the signing in with v1.1.3. It still didn’t automatically sign in after a restart, but it did so as soon as I went into the plugin’s settings. Previously I needed to toggle disable/enable to do that.
The plugin only signs in when you access its settings or begin browsing. This is to avoid the past situation where a bug in the sign-in process froze the entire setup.
