installs fine. playback page showing thumbnail also but its not playing anything
@tlmyasirs
on what are you replying? youtube or youtube2?
if you updated to youtube2 run the latest update⦠( 26-12-2020 )
and for the 2.xx update the mpd,
On Raspberry PI 4, 4-Gig version
Volumio System Version 2.853
I installed the youtube2 plugin 0.1.0a-20201226
I updated mpd to version mpd-0.21.16_20191227
I played several tracks from youtube and do not have tracks stopping at 2/3, 3/4 of the way through now.
Thanks!
your welcome
thatās why you had to update to 0.21.16
Hello friends.
Can you help me get a full MPD update order !. I can not do that
MPD 0.21.16 for Volumio (arm, armv7 and x86) this is for the 2.xx
the 3.xx version al ready has it ( the eazy way )
Perhaps you could tell us the steps you did to update MPD, so we can better identify the issue. As @dvo mentioned, if you are running Volumio 3.xx beta release, then you should not have to do the update.
@patrickkfkan
looks like this version stopped working after i guess the updates that google did.
on the other version of youtube looks like its working.
do you have also this version and its working?
@giorgosperi @patrickkfkan
Tested scraper version is still running ā¦
Tested API version ā¦even this version is runningā¦
Youtube2 plugin 0.1.0a-20201219 version
System Version 3.015
@dvo
did you try to play something? api works but when i try to play something doesnāt do anything.
yes iām now listening level 42
play list ⦠reboot your system.
i had it on scraper so i switched to api added creds at first i had no sound after reboot it worked again
it seems more a system glitch because local sound didnāt play too
@dvo
now i m confused or i m sleepy
scraper is only on the 2nd version.
also i m using 2.729 version with youtube 0.1.0 version
my second pi tha plays is 2.853 with youtube 0.1.0a-20201226
there is already a newer version ?.. i use Youtube2 plugin 0.1.0a-20201219 version on 3.15
youtube old version is dead ⦠so only use the youtube2
yeah on the second rasberry pi i have the latest version and it works fine.
the older version i was checking if its working because it was working long time nowā¦but i think since the last change of google stopped
the old version is already dead ā¦you where lucky it still did what it didā¦
i know recently it was working fine i guess its the time to move on haha
the new version works way better then the oldā¦
i know just i was using it you remember how long from almost the beginning.
we where both running the old one for a long time⦠but i was testing new images a lot,
at one moment i could not get it running good any more to mutch hickupsā¦
patrick release with christmass the new one and switched over and started debugging with him.
and never looked back againā¦
even now i tried to add youtube2 on the older version of volumio its not working. so i have to update it also. just i feel like the older versions are working better as volumio but not youtube etc.
