sla89
June 15, 2017, 5:55pm
41
I think I have found the bug and fixed it:
I am able to search for videos, playlists and channels by their ID (whole URL will be supported in next version!). The found playlists can be added to the queue as you can see in the screenshots above. Do you want to verify that the bug is fixed? But be warned it will be some effort to test it. You have to uninstall the plugin first and install a development version that I will send you as zip file. And because it is a development version it may be not that stable yet.
Just let me know. Otherwise the bug fix will be part of the next release of the plugin.
Hi everybody,
Iāve looked for the answer to my question everywhere but didnāt found it. Whatās the default quality of the stream from Youtube ? Is it max HD by default ? Is there a way to configure it ?
Thanks a lot for this great plungin, I can listen to great live shows now
sla89
July 15, 2017, 5:47pm
43
Imaginarys:
Hi everybody,
sorry, I didnt saw your questions.
Per default we use the highest available quality. At the moment you cannot configure this. I think this fits to everybody using volumio and youtube.
Wish this would work with Tidal⦠Maybe soon
Anyway can I download it directly to my Odroid C0 via the plug in manager?
Cheers
raqpub
July 18, 2017, 4:35pm
45
New on volumio, I download your plugin Youtube. And first of all, thanks for your development.
I create a playlist Youtube on volumio by UI
But itās impossible to add or insert a playlist Youtube directly (like this one find by search mode = commercial music )
Also impossible to add any song to playlist Youtube
The only way I found is to add to queue with UI and after, in ssh mode, copy the content I want of the file /data/queue into the /data/playlist/Youtube file
Is it normal in this version or I have a problem of installation or permission ?
Thks
sla89
July 18, 2017, 5:52pm
46
You can create a plugin wish here: plugin-wish-list-t4361.html
Yes, it should be available in the plugin manager.
raqpub:
Thks
Well, currently this is not supported by volumio itself and therefore we cannot add support for it in our plugin. We will fix this in volumio directly and then it will be available for the youtube plugin too.
raqpub
July 18, 2017, 7:40pm
47
Thks sla89 for your quick answer
Ok Iāll wait for an evolution of volumio.
i have same problem when i search in youtube i will get an āerror occuredā
here the log
Jun 09 20:00:33 volumio volumio[946]: info: CoreCommandRouter::executeOnPlugin: youtube , handleBrowseUri
Jun 09 20:00:33 volumio volumio[946]: info: handleBrowseUri: youtube
Jun 09 20:00:34 volumio volumio[946]: error: certificate is not yet valid
Jun 09 20:00:34 volumio volumio[946]: Error: certificate is not yet valid
Jun 09 20:00:34 volumio volumio[946]: at Error (native)
Jun 09 20:00:34 volumio volumio[946]: at TLSSocket. (_tls_wrap.js:1062:38)
Jun 09 20:00:34 volumio volumio[946]: at emitNone (events.js:86:13)
Jun 09 20:00:34 volumio volumio[946]: at TLSSocket.emit (events.js:185:7)
Jun 09 20:00:34 volumio volumio[946]: at TLSSocket._finishInit (_tls_wrap.js:586:8)
Jun 09 20:00:34 volumio volumio[946]: at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:416:38)
i have tried to reinstall the plugin without successā¦
sla89
July 27, 2017, 5:59pm
50
Can you please tell me which version of the plugin you have tried, which version of volumio you are using and on what platform?
sla89:
Imaginarys:
Hi everybody,
Ok, great, thatās perfect ! Thank you very much for your answer.
sla89
July 28, 2017, 5:59am
52
You are welcome.
By the way there is a new version available.
You can update it under Plugins -> Search Plugins -> Update.
i saw it was 2.163 installed and volumio found āno updatesā and i thought that was the newest version.
anyway i make a clean install with the current version and now everything is fine.
digx
August 4, 2017, 12:20pm
55
Hi guys,
I think you made a great work with this plugin!
Now I inserted the support to youtube plugin(including installation/enabling and updating) to the sound@home App.
Give a try and let me know your comments @:digx@hotmail.it
sla89
August 8, 2017, 6:19pm
56
Oh - nice! I will take a look at it in the next two weeks and give you feedback.
I have tested it over the weekend and it works great
Hi @pintea .
New in the forum and new in volume.
I had tried to install the youtube plugin and I get an error.
I paste the info trying to get any advise in order to solve the problem
[code]Aug 15 18:21:48 volumio volumio[902]: info: CoreCommandRouter::volumioGetState
Aug 15 18:21:48 volumio volumio[902]: info: [1502821308577] CoreStateMachine::getState
Aug 15 18:21:48 volumio volumio[902]: info: [1502821308580] CorePlayQueue::getTrack 0
Aug 15 18:21:48 volumio volumio[902]: [1502821308582] ---------------------------- Client requests Volumio state
Aug 15 18:21:48 volumio volumio[902]: info: [1502821308585] InterfaceWebUI::pushState
Aug 15 18:21:48 volumio volumio[902]: info: [1502821308664] ------------------------------ 91ms
Aug 15 18:21:50 volumio volumio[902]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Aug 15 18:21:50 volumio volumio[902]: Plugin multiroom or method getMultiroom not found
Aug 15 18:21:50 volumio volumio[902]: [1502821310572] ---------------------------- Client requests Menu Items
Aug 15 18:21:50 volumio volumio[902]: info: [1502821310579] Listing playlists
Aug 15 18:21:50 volumio volumio[902]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Aug 15 18:21:50 volumio volumio[902]: info: [1502821310644] ------------------------------ 72ms
Aug 15 18:21:54 volumio volumio[902]: info: []
Aug 15 18:22:00 volumio volumio[902]: info: Following Redirect to: http://volumio.github.io/volumio-plugins/plugins/volumio/armhf/plugins.json
Aug 15 18:22:04 volumio volumio[902]: info: Downloading plugin at http://volumio.github.io/volumio-plugins/plugins/volumio/armhf/music_service/youtube/youtube.zip
Aug 15 18:22:07 volumio volumio[902]: info: END DOWNLOAD: http://volumio.github.io/volumio-plugins/plugins/volumio/armhf/music_service/youtube/youtube.zip
Aug 15 18:22:31 volumio volumio[902]: info: Checking if plugin already exists
Aug 15 18:22:31 volumio volumio[902]: info: Rename folder
Aug 15 18:22:37 volumio volumio[902]: info: Move to category
Aug 15 18:22:42 volumio volumio[902]: info: Checking if install.sh is present
Aug 15 18:22:42 volumio volumio[902]: info: Executing install.sh
Aug 15 18:22:42 volumio sudo[8508]: pam_unix(sudo:auth): authentication failure; logname= uid=1000 euid=0 tty= ruser=volumio rhost= user=volumio
Aug 15 18:22:45 volumio sudo[8508]: pam_unix(sudo:auth): conversation failed
Aug 15 18:22:45 volumio sudo[8508]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Aug 15 18:22:45 volumio sudo[8508]: volumio : 1 incorrect password attempt ; TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sh /data/plugins//music_service/youtube/install.sh
Aug 15 18:22:45 volumio volumio[902]: info: Install script return the error Error: Command failed: echo volumio | sudo -S sh /data/plugins//music_service/youtube/install.sh > /tmp/installog
Aug 15 18:22:45 volumio volumio[902]: [sudo] password for volumio: Sorry, try again.
Aug 15 18:22:45 volumio volumio[902]: sudo: 1 incorrect password attempt
Aug 15 18:22:45 volumio volumio[902]: info: An error occurred installing the plugin. Rolling back config
Aug 15 18:22:45 volumio volumio[902]: info: Plugin folders cleanup
Aug 15 18:22:45 volumio volumio[902]: info: Scanning into folder /volumio/app/plugins/
Aug 15 18:22:45 volumio volumio[902]: info: Scanning category audio_interface
Aug 15 18:22:45 volumio volumio[902]: info: Scanning category miscellanea
Aug 15 18:22:45 volumio volumio[902]: info: Scanning category music_service
Aug 15 18:22:45 volumio volumio[902]: info: Scanning category plugins.json
Aug 15 18:22:45 volumio volumio[902]: info: Scanning category system_controller
Aug 15 18:22:45 volumio volumio[902]: info: Scanning category user_interface
Aug 15 18:22:45 volumio volumio[902]: info: Scanning into folder /data/plugins/
Aug 15 18:22:45 volumio volumio[902]: info: Plugin youtube found in folder but missing in configuration. Removing folder.
Aug 15 18:22:46 volumio volumio[902]: info: Plugin folders cleanup completed
Aug 15 18:22:46 volumio volumio[902]: info: Error: Error
Aug 15 18:22:46 volumio volumio[902]: info: Folder /tmp/downloaded_plugin removed
Aug 15 18:22:46 volumio volumio[902]: info: Folder /tmp/downloaded_plugin.zip removed
[/code]
volumio@volumio:/$ ls /data/
INTERNAL backgrounds favourites playerstate plugins
albumart configuration laststates.json playlist queue
volumio@volumio:/$
volumio@volumio:/$ ls /data/configuration
audio_interface miscellanea music_service netconfigured plugins.json system_controller
volumio@volumio:/$
ls /data/configuration/music_service
volumio@volumio:/$ ls /data/plugins/plugins.json
ls: cannot access /data/plugins/plugins.json: No such file or directory
volumio@volumio:/$
Thanks in advance.
pintea
August 31, 2017, 1:53am
58
Hi @frankysoft ,
Sorry for the late answer.
Iām not actively working on the plugin anymore and sla should be your reference point.
Anyways, have you changed the default password for user āvolumioā?
If Iām not mistaken, the default password (āvolumioā) is hardcoded into the plugin installer and changing it will cause plugins not to install correctly.
I think someone is working on that and will fix it soon, in the meanwhile, if you have changed the password for user āvolumioā to something other than āvolumioā you could roll it back and that should fix your problem!
Best regards!
Thanks @pintea .
No, there is no password change. It“s volumio.
I take note about sla reference.
Regards.
sla89
September 6, 2017, 5:14pm
60
I think it has nothing to do with the plugin itself but with your system configuration.
These lines say that you have authentication problems:
Have you tried to install any other plugin like spotify or so?
