[PLUGIN] Touch Display
Hey @TMT,
Here is a table comparing the required settings for Liar (OSOYOO 3.5 Inch HDMI Screen v2.0) and Greedy (MHS-3.5inch RPi Display) that need to be added to /boot/userconfig.txt
Setting Liar (OSOYOO HDMI v2.0) Greedy (MHS-3.5inch RPi Display)
Display Type HDMI SPI
Driver Uses FKMS (Fake KMS) Uses FBCP driver
Resolution 480x320 320x480
Overlay dtoverlay=vc4-fkms-v3d dtoverlay=mhs35
Framebuffer Handled via HDMI framebuffer_width=320 framebuffer_height=480
Touch Controller Built-in capacitive touch (handled via HDMI) XPT2046 resistive touch
SPI Interface Not required dtoverlay=spi-bcm2835
GPIO Usage Minimal (HDMI only) Heavy usage (SPI + GPIOs)
Rotation Options Handled via hdmi_cvt settings lcd_rotate=0 (or 90, 180, 270)
Backlight Control Automatic via HDMI Manual via GPIO
Other Configurations hdmi_force_hotplug=1 hdmi_group=2 hdmi_mode=87 hdmi_cvt 480 320 60 6 0 0 0 dtoverlay=mhs35 dtparam=spi=on dtparam=i2c_arm=on
/boot/userconfig.txt Example
For Liar (OSOYOO HDMI v2.0)
dtoverlay=ads7846,cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swapxy=0,pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
hdmi_pixel_freq_limit=20000000
For Greedy (MHS-3.5inch RPi Display)
Download mhs35 overlay and place in /boot/overlays folder.
dtoverlay=vc4-kms-v3d
dtoverlay=mhs35
dtparam=spi=on
dtparam=i2c_arm=on
lcd_rotate=0
Disclaimer:
The settings provided are based on a brief review of available sources and should, in theory, allow either screen to function. However, I do not own these displays and cannot provide further support or troubleshooting. If any issues arise, perhaps other Volumio users with hands-on experience can offer additional guidance. This is as far as I can assist without direct access to the hardware - you’re on your own from here. Best of luck!
Does it work with 4inch tft touch displays?
Can’t tell. 4inch tft screen is not much to go on.
Just try and see. Worst case scenario is a factory reset.
Fresh install with the last volumio version on a rpi 3 a+ and a 256gb sd card, everything works, but when i try to install the touch display plugin from the web interface : it keeps failing at 70% and always send this log :
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/touch_display/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/touch_display/volumio/buster/armhf
Création de l'emplacement de destination
Décompression du plugin
Vérifier que le plugin est adapté à cette version de Volumio The plugin can be used with this version of Volumio
Vérification des doublons
Copie du plugin à destination
Installation des utilitaires nécessaires
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Installing graphical environment
The following additional packages will be installed:
keyboard-configuration libegl-mesa0 libegl1 libegl1-mesa libepoxy0 libevdev2
libfontenc1 libgbm1 libgudev-1.0-0 libinput-bin libinput10 libmtdev1
libpciaccess0 libunwind8 libutempter0 libwacom-bin libwacom-common libwacom2
libwayland-server0 libxaw7 libxcomposite1 libxfont2 libxft2 libxkbfile1
libxmu6 libxpm4 libxt6 libxxf86dga1 x11-utils x11-xkb-utils xbitmaps
xfonts-base xfonts-encodings xfonts-utils xserver-common xserver-xorg
xserver-xorg-core xserver-xorg-input-all xserver-xorg-input-libinput
xserver-xorg-input-wacom xserver-xorg-legacy xserver-xorg-video-all
xserver-xorg-video-amdgpu xserver-xorg-video-ati xserver-xorg-video-fbdev
xserver-xorg-video-nouveau xserver-xorg-video-radeon xserver-xorg-video-vesa
xterm
Suggested packages:
pciutils mesa-utils xfonts-100dpi | xfonts-75dpi xfonts-scalable xinput
firmware-amd-graphics xserver-xorg-video-r128 xserver-xorg-video-mach64
xfonts-cyrillic
The following NEW packages will be installed:
xfonts-base xfonts-encodings xfonts-utils xinit xserver-common xserver-xorg
xterm
0 upgraded, 50 newly installed, 0 to remove and 2 not upgraded.
Need to get 0 B/19.0 MB of archives.
After this operation, 32.0 MB of additional disk space will be used.
Selecting previously unselected package keyboard-configuration.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 34963 files and directories currently installed.)
Preparing to unpack .../00-keyboard-configuration_1.193~deb10u1_all.deb ...
Unpacking keyboard-configuration (1.193~deb10u1) ...
Selecting previously unselected package libxxf86dga1:armhf.
Preparing to unpack .../01-libxxf86dga1_2%3a1.1.4-1_armhf.deb ...
Unpacking libxxf86dga1:armhf (2:1.1.4-1) ...
Selecting previously unselected package libwayland-server0:armhf.
Preparing to unpack .../02-libwayland-server0_1.16.0-1_armhf.deb ...
Unpacking libwayland-server0:armhf (1.16.0-1) ...
Selecting previously unselected package libgbm1:armhf.
Preparing to unpack .../03-libgbm1_19.3.2-1~bpo10+1~rpt4_armhf.deb ...
Unpacking libgbm1:armhf (19.3.2-1~bpo10+1~rpt4) ...
Selecting previously unselected package libegl-mesa0:armhf.
Preparing to unpack .../04-libegl-mesa0_19.3.2-1~bpo10+1~rpt4_armhf.deb ...
Unpacking libegl-mesa0:armhf (19.3.2-1~bpo10+1~rpt4) ...
Selecting previously unselected package libegl1:armhf.
Preparing to unpack .../05-libegl1_1.3.0-7~bpo10+1_armhf.deb ...
Unpacking libegl1:armhf (1.3.0-7~bpo10+1) ...
Selecting previously unselected package libegl1-mesa:armhf.
Preparing to unpack .../06-libegl1-mesa_19.3.2-1~bpo10+1~rpt4_armhf.deb ...
Unpacking libegl1-mesa:armhf (19.3.2-1~bpo10+1~rpt4) ...
dpkg-deb (subprocess): failed to create directory: Structure needs cleaning
dpkg-deb: error: tar subprocess returned error exit status 2
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/07-libepoxy0_1.5.3-0.1_armhf.deb (--unpack):
dpkg-deb --control subprocess returned error exit status 2
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/08-libevdev2_1.6.0+dfsg-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/09-libfontenc1_1%3a1.1.3-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/10-libgudev-1.0-0_232-2+rpi1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/11-libwacom-common_0.32-1_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/12-libwacom2_0.32-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/13-libinput-bin_1.12.6-2+deb10u1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/14-libmtdev1_1.1.5-1+b2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/15-libinput10_1.12.6-2+deb10u1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/16-libpciaccess0_0.14-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/17-libunwind8_1.2.1-10~deb10u1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/18-libutempter0_1.1.6-3_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/19-libwacom-bin_0.32-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/20-libxt6_1%3a1.1.5-1+b3_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/21-libxmu6_2%3a1.1.2-2+b3_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/22-libxpm4_1%3a3.5.12-1+deb10u2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/23-libxaw7_2%3a1.0.13-1+b2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/24-libxcomposite1_1%3a0.4.4-2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/25-libxfont2_1%3a2.0.3-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/26-libxft2_2.3.2-2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/27-libxkbfile1_1%3a1.0.9-2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/28-x11-utils_7.7+4_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/29-x11-xkb-utils_7.7+4_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/30-xbitmaps_1.1.1-2_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/31-xfonts-encodings_1%3a1.0.4-2_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/32-xfonts-utils_1%3a7.7+6_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/33-xfonts-base_1%3a1.0.5_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/34-xinit_1.4.0-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/35-xserver-common_2%3a1.20.4-1+rpt4+deb10u9_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/36-xserver-xorg-core_2%3a1.20.4-1+rpt4+deb10u9_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/37-xserver-xorg-video-amdgpu_18.1.99+git20190207-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/38-xserver-xorg-video-radeon_1%3a19.0.1-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/39-xserver-xorg-video-ati_1%3a19.0.1-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/40-xserver-xorg-video-fbdev_1%3a0.5.0-1+b2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/41-xserver-xorg-video-nouveau_1%3a1.0.16-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/42-xserver-xorg-video-vesa_1%3a2.4.0-1+b1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/43-xserver-xorg-video-all_1%3a7.7+19+b8_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/44-xserver-xorg-input-libinput_0.28.2-2_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/45-xserver-xorg-input-all_1%3a7.7+19+b8_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/46-xserver-xorg-input-wacom_0.34.99.1-1+b6_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/47-xserver-xorg_1%3a7.7+19+b8_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/48-xserver-xorg-legacy_2%3a1.20.4-1+rpt4+deb10u9_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-UmhoUE/49-xterm_344-1+deb10u2_armhf.deb (--unpack):
Errors were encountered while processing:
Installation of xinit failed
Plugin failed to install!
Cleaning up...
Removing dependencies
Package 'fonts-arphic-ukai' is not installed, so not removed
The following packages will be REMOVED:
keyboard-configuration* libegl-mesa0* libegl1* libegl1-mesa* libgbm1*
libwayland-server0* libxxf86dga1*
0 upgraded, 0 newly installed, 7 to remove and 2 not upgraded.
7 not fully installed or removed.
After this operation, 3313 kB disk space will be freed.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 35026 files and directories currently installed.)
Removing keyboard-configuration (1.193~deb10u1) ...
Removing libegl1-mesa:armhf (19.3.2-1~bpo10+1~rpt4) ...
Removing libegl1:armhf (1.3.0-7~bpo10+1) ...
Removing libegl-mesa0:armhf (19.3.2-1~bpo10+1~rpt4) ...
Removing libgbm1:armhf (19.3.2-1~bpo10+1~rpt4) ...
Removing libwayland-server0:armhf (1.16.0-1) ...
Removing libxxf86dga1:armhf (2:1.1.4-1) ...
Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u2) ...
Purging configuration files for libxxf86dga1:armhf (2:1.1.4-1) ...
Purging configuration files for keyboard-configuration (1.193~deb10u1) ...
Package 'fonts-arphic-gbsn00lp' is not installed, so not removed
Package 'fonts-unfonts-core' is not installed, so not removed
Package 'fonts-ipafont' is not installed, so not removed
Package 'fonts-vlgothic' is not installed, so not removed
Package 'fonts-thai-tlwg-ttf' is not installed, so not removed
Package 'chromium-browser' is not installed, so not removed
Package 'openbox' is not installed, so not removed
Package 'xinit' is not installed, so not removed
Deleting /opt/volumiokiosk.sh
Deleting /data/volumiokiosk
Enabling login prompt
Done
Une erreur est survenue lors de l'installation du plugin Error
Removing temporary directory /tmp/touch_display-W0VFEAddV2
I already read plenty of threads about it, but id like to see if someone understand my log.
  • Check if your date/time is correct, if not correct it.
  • Did you change the default credentials? If yes, reflash you SD and don’t do it again.
  • How did you flash your SD, with the image downloaded from Volumio.com? If not reflash SD with Volumio’s official image
  • What is the output of: df -Bm
  • What happens if you run: sudo apt-get update. If this also fail reflash SD with Volumio’s official image
I’ve only ever been able to run versions older than 3.4.0 of this plugin.
I get the same errors on a Rpi 4b and chalked them up to the warning on the latest version of the plugin not being compatible with RPi’s with factory HDMI out.
To those who know, is this the case? or is this error completely unrelated to Pi models with HDMI out?
The plugin’s readme states:
The plugin cannot be installed on systems that have a factory option to display Volumio’s UI via HDMI video output.
This refers to devices for which Volumio already displays an option in its GUI “ex works” with which the HDMI output is or can be activated for the connection of a display. However, this does currently not apply to images for Raspberry Pi.
Regarding
and
These issues are mostly caused by network errors occuring when the plugin’s installation process tries to download the required software packages.
Especially on Pi4 models these errors are often caused by incorrectly set system time/date (see first bullet of @Wheaten’s post above).
Another reasons can be unreachable repositories, e.g. because of DNS blocking. Sometimes changing the repository mirror as described here helps.
Finally what worked for me was :
  1. disabling my pihole (im not sure if it was useless or not, but as gvolt said there was downloading errors in the log, so i tried that first)
  2. reinstalling volumio from scratch and from the rpi imager
  3. editing my userconfig.txt with my screen settings (waveshare 4" 800x480)
  4. installing the HD touch plugin, before installing anything.
And it works perfectly now.
Thank you
Hi, and thanks for the help, your work on the plugin, and also quick reply!
I might need to add more context:
I use a RPi 4B with the official 7" touch display and case. Always with the latest release version of Volumio (no beta’s), and the only other plugins active in the system are Spotify and, for a time, System Information. The system has no issues with DNS blocking or time/date settings.
For installing, I’ve only ever been able to get the plugin to download and install properly on a clean slate up to version 3.4.0. Sometimes I could update, others not. When I could, I updated to the latest version.
I had to stop using the plugin and display a couple of weeks ago - 15 days as per my previous post on this thread - due to random errors which I wish I’d documented. But I’ll try it out again and update. Who knows, it might have been a fringe case.
im install touch display but heve error, plz help me
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/download/touch_display/3.5.1/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/download/touch_display/3.5.1/volumio/buster/armhf
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
Get:1 http://archive.raspberrypi.org/debian buster InRelease [54.2 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
Fetched 469 kB in 4s (115 kB/s)
0 upgraded, 0 newly installed, 0 to remove and 158 not upgraded.
xterm
Suggested packages:
xfonts-cyrillic
xterm
0 upgraded, 50 newly installed, 0 to remove and 158 not upgraded.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% dpkg: warning: files list file for package 'plymouth-themes' missing; assuming package has no files currently installed
(Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 35544 files and directories currently installed.)
Selecting previously unselected package libepoxy0:armhf.
Preparing to unpack .../07-libepoxy0_1.5.3-0.1_armhf.deb ...
Unpacking libepoxy0:armhf (1.5.3-0.1) ...
Selecting previously unselected package libevdev2:armhf.
Preparing to unpack .../08-libevdev2_1.6.0+dfsg-1_armhf.deb ...
Unpacking libevdev2:armhf (1.6.0+dfsg-1) ...
Selecting previously unselected package libfontenc1:armhf.
Preparing to unpack .../09-libfontenc1_1%3a1.1.3-1_armhf.deb ...
Unpacking libfontenc1:armhf (1:1.1.3-1) ...
Selecting previously unselected package libgudev-1.0-0:armhf.
Preparing to unpack .../10-libgudev-1.0-0_232-2+rpi1_armhf.deb ...
Unpacking libgudev-1.0-0:armhf (232-2+rpi1) ...
Selecting previously unselected package libwacom-common.
Preparing to unpack .../11-libwacom-common_0.32-1_all.deb ...
Unpacking libwacom-common (0.32-1) ...
Selecting previously unselected package libwacom2:armhf.
Preparing to unpack .../12-libwacom2_0.32-1_armhf.deb ...
Unpacking libwacom2:armhf (0.32-1) ...
Selecting previously unselected package libinput-bin.
Preparing to unpack .../13-libinput-bin_1.12.6-2+deb10u1_armhf.deb ...
Unpacking libinput-bin (1.12.6-2+deb10u1) ...
Selecting previously unselected package libmtdev1:armhf.
Preparing to unpack .../14-libmtdev1_1.1.5-1+b2_armhf.deb ...
Unpacking libmtdev1:armhf (1.1.5-1+b2) ...
Selecting previously unselected package libinput10:armhf.
Preparing to unpack .../15-libinput10_1.12.6-2+deb10u1_armhf.deb ...
Unpacking libinput10:armhf (1.12.6-2+deb10u1) ...
Selecting previously unselected package libpciaccess0:armhf.
Preparing to unpack .../16-libpciaccess0_0.14-1_armhf.deb ...
Unpacking libpciaccess0:armhf (0.14-1) ...
Selecting previously unselected package libunwind8:armhf.
Preparing to unpack .../17-libunwind8_1.2.1-10~deb10u1_armhf.deb ...
Unpacking libunwind8:armhf (1.2.1-10~deb10u1) ...
Selecting previously unselected package libutempter0:armhf.
Preparing to unpack .../18-libutempter0_1.1.6-3_armhf.deb ...
Unpacking libutempter0:armhf (1.1.6-3) ...
Selecting previously unselected package libwacom-bin.
Preparing to unpack .../19-libwacom-bin_0.32-1_armhf.deb ...
Unpacking libwacom-bin (0.32-1) ...
Selecting previously unselected package libxt6:armhf.
Preparing to unpack .../20-libxt6_1%3a1.1.5-1+b3_armhf.deb ...
Unpacking libxt6:armhf (1:1.1.5-1+b3) ...
Selecting previously unselected package libxmu6:armhf.
Preparing to unpack .../21-libxmu6_2%3a1.1.2-2+b3_armhf.deb ...
Unpacking libxmu6:armhf (2:1.1.2-2+b3) ...
Selecting previously unselected package libxpm4:armhf.
Preparing to unpack .../22-libxpm4_1%3a3.5.12-1+deb10u2_armhf.deb ...
Unpacking libxpm4:armhf (1:3.5.12-1+deb10u2) ...
Selecting previously unselected package libxaw7:armhf.
Preparing to unpack .../23-libxaw7_2%3a1.0.13-1+b2_armhf.deb ...
Unpacking libxaw7:armhf (2:1.0.13-1+b2) ...
Selecting previously unselected package libxcomposite1:armhf.
Preparing to unpack .../24-libxcomposite1_1%3a0.4.4-2_armhf.deb ...
Unpacking libxcomposite1:armhf (1:0.4.4-2) ...
Selecting previously unselected package libxfont2:armhf.
Preparing to unpack .../25-libxfont2_1%3a2.0.3-1_armhf.deb ...
Unpacking libxfont2:armhf (1:2.0.3-1) ...
Selecting previously unselected package libxft2:armhf.
Preparing to unpack .../26-libxft2_2.3.2-2_armhf.deb ...
Unpacking libxft2:armhf (2.3.2-2) ...
Selecting previously unselected package libxkbfile1:armhf.
Preparing to unpack .../27-libxkbfile1_1%3a1.0.9-2_armhf.deb ...
Unpacking libxkbfile1:armhf (1:1.0.9-2) ...
Selecting previously unselected package x11-utils.
Preparing to unpack .../28-x11-utils_7.7+4_armhf.deb ...
Unpacking x11-utils (7.7+4) ...
Selecting previously unselected package x11-xkb-utils.
Preparing to unpack .../29-x11-xkb-utils_7.7+4_armhf.deb ...
Unpacking x11-xkb-utils (7.7+4) ...
Selecting previously unselected package xbitmaps.
Preparing to unpack .../30-xbitmaps_1.1.1-2_all.deb ...
Unpacking xbitmaps (1.1.1-2) ...
Selecting previously unselected package xfonts-encodings.
Preparing to unpack .../31-xfonts-encodings_1%3a1.0.4-2_all.deb ...
Unpacking xfonts-encodings (1:1.0.4-2) ...
Selecting previously unselected package xfonts-utils.
Preparing to unpack .../32-xfonts-utils_1%3a7.7+6_armhf.deb ...
Unpacking xfonts-utils (1:7.7+6) ...
Selecting previously unselected package xfonts-base.
Preparing to unpack .../33-xfonts-base_1%3a1.0.5_all.deb ...
Unpacking xfonts-base (1:1.0.5) ...
Selecting previously unselected package xinit.
Preparing to unpack .../34-xinit_1.4.0-1_armhf.deb ...
Unpacking xinit (1.4.0-1) ...
Selecting previously unselected package xserver-common.
Preparing to unpack .../35-xserver-common_2%3a1.20.4-1+rpt4+deb10u9_all.deb ...
Unpacking xserver-common (2:1.20.4-1+rpt4+deb10u9) ...
Selecting previously unselected package xserver-xorg-core.
Preparing to unpack .../36-xserver-xorg-core_2%3a1.20.4-1+rpt4+deb10u9_armhf.deb ...
Unpacking xserver-xorg-core (2:1.20.4-1+rpt4+deb10u9) ...
Selecting previously unselected package xserver-xorg-video-amdgpu.
Preparing to unpack .../37-xserver-xorg-video-amdgpu_18.1.99+git20190207-1_armhf.deb ...
Unpacking xserver-xorg-video-amdgpu (18.1.99+git20190207-1) ...
Selecting previously unselected package xserver-xorg-video-radeon.
Preparing to unpack .../38-xserver-xorg-video-radeon_1%3a19.0.1-1_armhf.deb ...
Unpacking xserver-xorg-video-radeon (1:19.0.1-1) ...
Selecting previously unselected package xserver-xorg-video-ati.
Preparing to unpack .../39-xserver-xorg-video-ati_1%3a19.0.1-1_armhf.deb ...
Unpacking xserver-xorg-video-ati (1:19.0.1-1) ...
Selecting previously unselected package xserver-xorg-video-fbdev.
Preparing to unpack .../40-xserver-xorg-video-fbdev_1%3a0.5.0-1+b2_armhf.deb ...
Unpacking xserver-xorg-video-fbdev (1:0.5.0-1+b2) ...
Selecting previously unselected package xserver-xorg-video-nouveau.
Preparing to unpack .../41-xserver-xorg-video-nouveau_1%3a1.0.16-1_armhf.deb ...
Unpacking xserver-xorg-video-nouveau (1:1.0.16-1) ...
Selecting previously unselected package xserver-xorg-video-vesa.
Preparing to unpack .../42-xserver-xorg-video-vesa_1%3a2.4.0-1+b1_armhf.deb ...
Unpacking xserver-xorg-video-vesa (1:2.4.0-1+b1) ...
Selecting previously unselected package xserver-xorg-video-all.
Preparing to unpack .../43-xserver-xorg-video-all_1%3a7.7+19+b8_armhf.deb ...
Unpacking xserver-xorg-video-all (1:7.7+19+b8) ...
Selecting previously unselected package xserver-xorg-input-libinput.
Preparing to unpack .../44-xserver-xorg-input-libinput_0.28.2-2_armhf.deb ...
Unpacking xserver-xorg-input-libinput (0.28.2-2) ...
Selecting previously unselected package xserver-xorg-input-all.
Preparing to unpack .../45-xserver-xorg-input-all_1%3a7.7+19+b8_armhf.deb ...
Unpacking xserver-xorg-input-all (1:7.7+19+b8) ...
Selecting previously unselected package xserver-xorg-input-wacom.
Preparing to unpack .../46-xserver-xorg-input-wacom_0.34.99.1-1+b6_armhf.deb ...
Unpacking xserver-xorg-input-wacom (0.34.99.1-1+b6) ...
Selecting previously unselected package xserver-xorg.
Preparing to unpack .../47-xserver-xorg_1%3a7.7+19+b8_armhf.deb ...
Unpacking xserver-xorg (1:7.7+19+b8) ...
Selecting previously unselected package xserver-xorg-legacy.
Preparing to unpack .../48-xserver-xorg-legacy_2%3a1.20.4-1+rpt4+deb10u9_armhf.deb ...
Unpacking xserver-xorg-legacy (2:1.20.4-1+rpt4+deb10u9) ...
Selecting previously unselected package xterm.
Preparing to unpack .../49-xterm_344-1+deb10u2_armhf.deb ...
Unpacking xterm (344-1+deb10u2) ...
Setting up xinit (1.4.0-1) ...
Setting up libwayland-server0:armhf (1.16.0-1) ...
Setting up libpciaccess0:armhf (0.14-1) ...
Setting up libxft2:armhf (2.3.2-2) ...
Setting up libxpm4:armhf (1:3.5.12-1+deb10u2) ...
Setting up libgbm1:armhf (19.3.2-1~bpo10+1~rpt4) ...
Setting up libxxf86dga1:armhf (2:1.1.4-1) ...
Setting up libunwind8:armhf (1.2.1-10~deb10u1) ...
Setting up libfontenc1:armhf (1:1.1.3-1) ...
Setting up libegl-mesa0:armhf (19.3.2-1~bpo10+1~rpt4) ...
Setting up libepoxy0:armhf (1.5.3-0.1) ...
Setting up xfonts-encodings (1:1.0.4-2) ...
Setting up libxt6:armhf (1:1.1.5-1+b3) ...
Setting up libmtdev1:armhf (1.1.5-1+b2) ...
Setting up libutempter0:armhf (1.1.6-3) ...
Setting up libegl1:armhf (1.3.0-7~bpo10+1) ...
Setting up libxkbfile1:armhf (1:1.0.9-2) ...
Setting up keyboard-configuration (1.193~deb10u1) ...
Setting up libxcomposite1:armhf (1:0.4.4-2) ...
Setting up libxfont2:armhf (1:2.0.3-1) ...
Setting up libevdev2:armhf (1.6.0+dfsg-1) ...
Setting up libgudev-1.0-0:armhf (232-2+rpi1) ...
Setting up xbitmaps (1.1.1-2) ...
Setting up libwacom-common (0.32-1) ...
Setting up libxmu6:armhf (2:1.1.2-2+b3) ...
Setting up libxaw7:armhf (2:1.0.13-1+b2) ...
Setting up xfonts-utils (1:7.7+6) ...
Setting up libegl1-mesa:armhf (19.3.2-1~bpo10+1~rpt4) ...
Setting up xfonts-base (1:1.0.5) ...
Setting up x11-utils (7.7+4) ...
Setting up xterm (344-1+deb10u2) ...
update-alternatives: using /usr/bin/xterm to provide /usr/bin/x-terminal-emulator (x-terminal-emulator) in auto mode
update-alternatives: using /usr/bin/lxterm to provide /usr/bin/x-terminal-emulator (x-terminal-emulator) in auto mode
Setting up libwacom2:armhf (0.32-1) ...
Setting up x11-xkb-utils (7.7+4) ...
Setting up libinput-bin (1.12.6-2+deb10u1) ...
Setting up libwacom-bin (0.32-1) ...
Setting up xserver-common (2:1.20.4-1+rpt4+deb10u9) ...
Setting up xserver-xorg-legacy (2:1.20.4-1+rpt4+deb10u9) ...
Setting up libinput10:armhf (1.12.6-2+deb10u1) ...
Setting up xserver-xorg-core (2:1.20.4-1+rpt4+deb10u9) ...
Setting up xserver-xorg-video-radeon (1:19.0.1-1) ...
Setting up xserver-xorg-input-wacom (0.34.99.1-1+b6) ...
Setting up xserver-xorg-video-fbdev (1:0.5.0-1+b2) ...
Setting up xserver-xorg-video-vesa (1:2.4.0-1+b1) ...
Setting up xserver-xorg-video-amdgpu (18.1.99+git20190207-1) ...
Setting up xserver-xorg (1:7.7+19+b8) ...
Setting up xserver-xorg-video-nouveau (1:1.0.16-1) ...
Setting up xserver-xorg-input-libinput (0.28.2-2) ...
Setting up xserver-xorg-video-ati (1:19.0.1-1) ...
Setting up xserver-xorg-video-all (1:7.7+19+b8) ...
Setting up xserver-xorg-input-all (1:7.7+19+b8) ...
Processing triggers for man-db (2.8.5-2+deb10u1) ...
Processing triggers for fontconfig (2.13.1-2) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
libglu1-mesa x11-apps x11-session-utils x11-xserver-utils xfonts-100dpi
xfonts-75dpi xfonts-scalable xorg-docs-core
Suggested packages:
mesa-utils nickle cairo-5c xorg-docs x11-xfs-utils
xfonts-75dpi xfonts-scalable xorg xorg-docs-core
0 upgraded, 9 newly installed, 0 to remove and 158 not upgraded.
Need to get 0 B/8497 kB of archives.
After this operation, 11.5 MB of additional disk space will be used.
Selecting previously unselected package libglu1-mesa:armhf.
(Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 36942 files and directories currently installed.)
Preparing to unpack .../0-libglu1-mesa_9.0.0-2.1_armhf.deb ...
Unpacking libglu1-mesa:armhf (9.0.0-2.1) ...
Selecting previously unselected package x11-apps.
Preparing to unpack .../1-x11-apps_7.7+7_armhf.deb ...
Unpacking x11-apps (7.7+7) ...
Selecting previously unselected package x11-session-utils.
Preparing to unpack .../2-x11-session-utils_7.7+3_armhf.deb ...
Unpacking x11-session-utils (7.7+3) ...
Selecting previously unselected package x11-xserver-utils.
Preparing to unpack .../3-x11-xserver-utils_7.7+8+rpt1_armhf.deb ...
Unpacking x11-xserver-utils (7.7+8+rpt1) ...
Selecting previously unselected package xfonts-100dpi.
Preparing to unpack .../4-xfonts-100dpi_1%3a1.0.4+nmu1_all.deb ...
Unpacking xfonts-100dpi (1:1.0.4+nmu1) ...
Selecting previously unselected package xfonts-75dpi.
Preparing to unpack .../5-xfonts-75dpi_1%3a1.0.4+nmu1_all.deb ...
Unpacking xfonts-75dpi (1:1.0.4+nmu1) ...
Selecting previously unselected package xfonts-scalable.
Preparing to unpack .../6-xfonts-scalable_1%3a1.0.3-1.1_all.deb ...
Unpacking xfonts-scalable (1:1.0.3-1.1) ...
Selecting previously unselected package xorg-docs-core.
Preparing to unpack .../7-xorg-docs-core_1%3a1.7.1-1.1_all.deb ...
Unpacking xorg-docs-core (1:1.7.1-1.1) ...
Selecting previously unselected package xorg.
Preparing to unpack .../8-xorg_1%3a7.7+19+b8_armhf.deb ...
Unpacking xorg (1:7.7+19+b8) ...
Setting up xfonts-100dpi (1:1.0.4+nmu1) ...
Setting up x11-apps (7.7+7) ...
Setting up x11-xserver-utils (7.7+8+rpt1) ...
Setting up xorg-docs-core (1:1.7.1-1.1) ...
Setting up x11-session-utils (7.7+3) ...
Setting up libglu1-mesa:armhf (9.0.0-2.1) ...
Setting up xfonts-75dpi (1:1.0.4+nmu1) ...
Setting up xfonts-scalable (1:1.0.3-1.1) ...
Setting up xorg (1:7.7+19+b8) ...
adwaita-icon-theme at-spi2-core dconf-gsettings-backend dconf-service
giblib1 glib-networking glib-networking-common glib-networking-services
gnome-icon-theme gsettings-desktop-schemas gtk-update-icon-cache
hicolor-icon-theme libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data
libatspi2.0-0 libcairo-gobject2 libcolord2 libdconf1 libgail-common
libgail18 libgif7 libgtk-3-0 libgtk-3-bin libgtk-3-common libgtk2.0-0
libgtk2.0-bin libgtk2.0-common libimlib2 libjson-glib-1.0-0
libjson-glib-1.0-common liblcms2-2 libobrender32v5 libobt2v5
libpangoxft-1.0-0 libproxy1v5 librest-0.7-0 libsoup-gnome2.4-1 libsoup2.4-1
libstartup-notification0 libxcb-util0 obconf obsession scrot
Suggested packages:
colord gvfs liblcms2-utils fonts-dejavu libxml2-dev tint2
openbox-gnome-session openbox-kde-session
libstartup-notification0 libxcb-util0 obconf obsession openbox scrot
0 upgraded, 45 newly installed, 0 to remove and 158 not upgraded.
Need to get 0 B/34.9 MB of archives.
After this operation, 116 MB of additional disk space will be used.
Selecting previously unselected package hicolor-icon-theme.
(Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 37926 files and directories currently installed.)
Preparing to unpack .../00-hicolor-icon-theme_0.17-2_all.deb ...
Unpacking hicolor-icon-theme (0.17-2) ...
Selecting previously unselected package gtk-update-icon-cache.
Preparing to unpack .../01-gtk-update-icon-cache_3.24.5-1+rpt2_armhf.deb ...
No diversion 'diversion of /usr/sbin/update-icon-caches to /usr/sbin/update-icon-caches.gtk2 by libgtk-3-bin', none removed.
No diversion 'diversion of /usr/share/man/man8/update-icon-caches.8.gz to /usr/share/man/man8/update-icon-caches.gtk2.8.gz by libgtk-3-bin', none removed.
Unpacking gtk-update-icon-cache (3.24.5-1+rpt2) ...
Selecting previously unselected package adwaita-icon-theme.
Preparing to unpack .../02-adwaita-icon-theme_3.30.1-1_all.deb ...
Unpacking adwaita-icon-theme (3.30.1-1) ...
Selecting previously unselected package libatspi2.0-0:armhf.
Preparing to unpack .../03-libatspi2.0-0_2.30.0-7_armhf.deb ...
Unpacking libatspi2.0-0:armhf (2.30.0-7) ...
Selecting previously unselected package at-spi2-core.
Preparing to unpack .../04-at-spi2-core_2.30.0-7_armhf.deb ...
Unpacking at-spi2-core (2.30.0-7) ...
Selecting previously unselected package libdconf1:armhf.
Preparing to unpack .../05-libdconf1_0.30.1-2_armhf.deb ...
Unpacking libdconf1:armhf (0.30.1-2) ...
Selecting previously unselected package dconf-service.
Preparing to unpack .../06-dconf-service_0.30.1-2_armhf.deb ...
Unpacking dconf-service (0.30.1-2) ...
Selecting previously unselected package dconf-gsettings-backend:armhf.
Preparing to unpack .../07-dconf-gsettings-backend_0.30.1-2_armhf.deb ...
Unpacking dconf-gsettings-backend:armhf (0.30.1-2) ...
Selecting previously unselected package libgif7:armhf.
Preparing to unpack .../08-libgif7_5.1.4-3+deb10u1_armhf.deb ...
Unpacking libgif7:armhf (5.1.4-3+deb10u1) ...
Selecting previously unselected package libimlib2:armhf.
Preparing to unpack .../09-libimlib2_1.5.1-1_armhf.deb ...
Unpacking libimlib2:armhf (1.5.1-1) ...
Selecting previously unselected package giblib1:armhf.
Preparing to unpack .../10-giblib1_1.2.4-12_armhf.deb ...
Unpacking giblib1:armhf (1.2.4-12) ...
Selecting previously unselected package libproxy1v5:armhf.
Preparing to unpack .../11-libproxy1v5_0.4.15-5+deb10u1_armhf.deb ...
Unpacking libproxy1v5:armhf (0.4.15-5+deb10u1) ...
Selecting previously unselected package glib-networking-common.
Preparing to unpack .../12-glib-networking-common_2.58.0-2+deb10u2_all.deb ...
Unpacking glib-networking-common (2.58.0-2+deb10u2) ...
Selecting previously unselected package glib-networking-services.
Preparing to unpack .../13-glib-networking-services_2.58.0-2+deb10u2_armhf.deb ...
Unpacking glib-networking-services (2.58.0-2+deb10u2) ...
Selecting previously unselected package gsettings-desktop-schemas.
Preparing to unpack .../14-gsettings-desktop-schemas_3.28.1-1_all.deb ...
Unpacking gsettings-desktop-schemas (3.28.1-1) ...
Selecting previously unselected package glib-networking:armhf.
Preparing to unpack .../15-glib-networking_2.58.0-2+deb10u2_armhf.deb ...
Unpacking glib-networking:armhf (2.58.0-2+deb10u2) ...
Selecting previously unselected package gnome-icon-theme.
Preparing to unpack .../16-gnome-icon-theme_3.12.0-3_all.deb ...
Unpacking gnome-icon-theme (3.12.0-3) ...
Selecting previously unselected package libatk1.0-data.
Preparing to unpack .../17-libatk1.0-data_2.30.0-2_all.deb ...
Unpacking libatk1.0-data (2.30.0-2) ...
Selecting previously unselected package libatk1.0-0:armhf.
Preparing to unpack .../18-libatk1.0-0_2.30.0-2_armhf.deb ...
Unpacking libatk1.0-0:armhf (2.30.0-2) ...
Selecting previously unselected package libatk-bridge2.0-0:armhf.
Preparing to unpack .../19-libatk-bridge2.0-0_2.30.0-5_armhf.deb ...
Unpacking libatk-bridge2.0-0:armhf (2.30.0-5) ...
Selecting previously unselected package libcairo-gobject2:armhf.
Preparing to unpack .../20-libcairo-gobject2_1.16.0-4+rpt1+deb10u1_armhf.deb ...
Unpacking libcairo-gobject2:armhf (1.16.0-4+rpt1+deb10u1) ...
Selecting previously unselected package liblcms2-2:armhf.
Preparing to unpack .../21-liblcms2-2_2.9-3_armhf.deb ...
Unpacking liblcms2-2:armhf (2.9-3) ...
Selecting previously unselected package libcolord2:armhf.
Preparing to unpack .../22-libcolord2_1.4.3-4_armhf.deb ...
Unpacking libcolord2:armhf (1.4.3-4) ...
Selecting previously unselected package libgtk2.0-common.
Preparing to unpack .../23-libgtk2.0-common_2.24.32-3+rpt1_all.deb ...
Unpacking libgtk2.0-common (2.24.32-3+rpt1) ...
Selecting previously unselected package libgtk2.0-0:armhf.
Preparing to unpack .../24-libgtk2.0-0_2.24.32-3+rpt1_armhf.deb ...
Unpacking libgtk2.0-0:armhf (2.24.32-3+rpt1) ...
Selecting previously unselected package libgail18:armhf.
Preparing to unpack .../25-libgail18_2.24.32-3+rpt1_armhf.deb ...
Unpacking libgail18:armhf (2.24.32-3+rpt1) ...
Selecting previously unselected package libgail-common:armhf.
Preparing to unpack .../26-libgail-common_2.24.32-3+rpt1_armhf.deb ...
Unpacking libgail-common:armhf (2.24.32-3+rpt1) ...
Selecting previously unselected package libjson-glib-1.0-common.
Preparing to unpack .../27-libjson-glib-1.0-common_1.4.4-2_all.deb ...
Unpacking libjson-glib-1.0-common (1.4.4-2) ...
Selecting previously unselected package libjson-glib-1.0-0:armhf.
Preparing to unpack .../28-libjson-glib-1.0-0_1.4.4-2_armhf.deb ...
Unpacking libjson-glib-1.0-0:armhf (1.4.4-2) ...
Selecting previously unselected package libsoup2.4-1:armhf.
Preparing to unpack .../29-libsoup2.4-1_2.64.2-2_armhf.deb ...
Unpacking libsoup2.4-1:armhf (2.64.2-2) ...
Selecting previously unselected package libsoup-gnome2.4-1:armhf.
Preparing to unpack .../30-libsoup-gnome2.4-1_2.64.2-2_armhf.deb ...
Unpacking libsoup-gnome2.4-1:armhf (2.64.2-2) ...
Selecting previously unselected package librest-0.7-0:armhf.
Preparing to unpack .../31-librest-0.7-0_0.8.1-1_armhf.deb ...
Unpacking librest-0.7-0:armhf (0.8.1-1) ...
Selecting previously unselected package libgtk-3-common.
Preparing to unpack .../32-libgtk-3-common_3.24.5-1+rpt2_all.deb ...
Unpacking libgtk-3-common (3.24.5-1+rpt2) ...
Selecting previously unselected package libgtk-3-0:armhf.
Preparing to unpack .../33-libgtk-3-0_3.24.5-1+rpt2_armhf.deb ...
Unpacking libgtk-3-0:armhf (3.24.5-1+rpt2) ...
Selecting previously unselected package libgtk-3-bin.
Preparing to unpack .../34-libgtk-3-bin_3.24.5-1+rpt2_armhf.deb ...
Unpacking libgtk-3-bin (3.24.5-1+rpt2) ...
Selecting previously unselected package libgtk2.0-bin.
Preparing to unpack .../35-libgtk2.0-bin_2.24.32-3+rpt1_armhf.deb ...
Unpacking libgtk2.0-bin (2.24.32-3+rpt1) ...
Selecting previously unselected package libobt2v5.
Preparing to unpack .../36-libobt2v5_3.6.1-8+rpt5_armhf.deb ...
Unpacking libobt2v5 (3.6.1-8+rpt5) ...
Selecting previously unselected package libpangoxft-1.0-0:armhf.
Preparing to unpack .../37-libpangoxft-1.0-0_1.42.4-8~deb10u1_armhf.deb ...
Unpacking libpangoxft-1.0-0:armhf (1.42.4-8~deb10u1) ...
Selecting previously unselected package libobrender32v5.
Preparing to unpack .../38-libobrender32v5_3.6.1-8+rpt5_armhf.deb ...
Unpacking libobrender32v5 (3.6.1-8+rpt5) ...
Selecting previously unselected package libxcb-util0:armhf.
Preparing to unpack .../39-libxcb-util0_0.3.8-3+b2_armhf.deb ...
Unpacking libxcb-util0:armhf (0.3.8-3+b2) ...
Selecting previously unselected package libstartup-notification0:armhf.
Preparing to unpack .../40-libstartup-notification0_0.12-6_armhf.deb ...
Unpacking libstartup-notification0:armhf (0.12-6) ...
Selecting previously unselected package obconf.
Preparing to unpack .../41-obconf_1%3a2.0.4+git20150213-2+rpt4_armhf.deb ...
Unpacking obconf (1:2.0.4+git20150213-2+rpt4) ...
Selecting previously unselected package openbox.
Preparing to unpack .../42-openbox_3.6.1-8+rpt5_armhf.deb ...
Unpacking openbox (3.6.1-8+rpt5) ...
Selecting previously unselected package scrot.
Preparing to unpack .../43-scrot_0.9-1_armhf.deb ...
Unpacking scrot (0.9-1) ...
Selecting previously unselected package obsession.
Preparing to unpack .../44-obsession_20140608-2_armhf.deb ...
Unpacking obsession (20140608-2) ...
Setting up liblcms2-2:armhf (2.9-3) ...
Setting up gtk-update-icon-cache (3.24.5-1+rpt2) ...
Setting up libproxy1v5:armhf (0.4.15-5+deb10u1) ...
Setting up libpangoxft-1.0-0:armhf (1.42.4-8~deb10u1) ...
Setting up hicolor-icon-theme (0.17-2) ...
Setting up libatspi2.0-0:armhf (2.30.0-7) ...
Setting up libxcb-util0:armhf (0.3.8-3+b2) ...
Setting up gnome-icon-theme (3.12.0-3) ...
update-alternatives: using /usr/share/icons/gnome/scalable/places/debian-swirl.svg to provide /usr/share/icons/gnome/scalable/places/start-here.svg (start-here.svg) in auto mode
Setting up libcolord2:armhf (1.4.3-4) ...
Setting up libdconf1:armhf (0.30.1-2) ...
Setting up adwaita-icon-theme (3.30.1-1) ...
update-alternatives: using /usr/share/icons/Adwaita/cursor.theme to provide /usr/share/icons/default/index.theme (x-cursor-theme) in auto mode
Setting up libobt2v5 (3.6.1-8+rpt5) ...
Setting up libgif7:armhf (5.1.4-3+deb10u1) ...
Setting up libatk1.0-data (2.30.0-2) ...
Setting up at-spi2-core (2.30.0-7) ...
Setting up libjson-glib-1.0-common (1.4.4-2) ...
Setting up libcairo-gobject2:armhf (1.16.0-4+rpt1+deb10u1) ...
Setting up libgtk2.0-common (2.24.32-3+rpt1) ...
Setting up libatk1.0-0:armhf (2.30.0-2) ...
Setting up glib-networking-common (2.58.0-2+deb10u2) ...
Setting up libstartup-notification0:armhf (0.12-6) ...
Setting up glib-networking-services (2.58.0-2+deb10u2) ...
Setting up libgtk2.0-0:armhf (2.24.32-3+rpt1) ...
Setting up dconf-service (0.30.1-2) ...
Setting up obsession (20140608-2) ...
Setting up libjson-glib-1.0-0:armhf (1.4.4-2) ...
Setting up libatk-bridge2.0-0:armhf (2.30.0-5) ...
Setting up libimlib2:armhf (1.5.1-1) ...
Setting up libgail18:armhf (2.24.32-3+rpt1) ...
Setting up libgtk2.0-bin (2.24.32-3+rpt1) ...
Setting up libobrender32v5 (3.6.1-8+rpt5) ...
Setting up dconf-gsettings-backend:armhf (0.30.1-2) ...
Setting up libgail-common:armhf (2.24.32-3+rpt1) ...
Setting up giblib1:armhf (1.2.4-12) ...
Setting up openbox (3.6.1-8+rpt5) ...
update-alternatives: using /usr/bin/openbox to provide /usr/bin/x-window-manager (x-window-manager) in auto mode
update-alternatives: using /usr/bin/openbox-session to provide /usr/bin/x-session-manager (x-session-manager) in auto mode
Setting up scrot (0.9-1) ...
Setting up libgtk-3-common (3.24.5-1+rpt2) ...
Setting up gsettings-desktop-schemas (3.28.1-1) ...
Processing triggers for libglib2.0-0:armhf (2.58.3-2+deb10u4) ...
Processing triggers for shared-mime-info (1.10-1) ...
Setting up glib-networking:armhf (2.58.0-2+deb10u2) ...
Setting up libsoup2.4-1:armhf (2.64.2-2) ...
Setting up libsoup-gnome2.4-1:armhf (2.64.2-2) ...
Setting up librest-0.7-0:armhf (0.8.1-1) ...
Setting up libgtk-3-0:armhf (3.24.5-1+rpt2) ...
Setting up libgtk-3-bin (3.24.5-1+rpt2) ...
Setting up obconf (1:2.0.4+git20150213-2+rpt4) ...
Creating /etc/X11/xorg.conf.d dir
Creating Xorg configuration
Installing Chromium
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
chromium-browser : Depends: chromium-codecs-ffmpeg-extra (= 92.0.4515.98~buster-rpt2) but it is not going to be installed or
chromium-codecs-ffmpeg (= 92.0.4515.98~buster-rpt2) but it is not going to be installed
Depends: libraspberrypi0 but it is not installable
Recommends: chromium-browser-l10n but it is not going to be installed
Installation of Chromium failed
Cleaning up...
adwaita-icon-theme* at-spi2-core* dconf-gsettings-backend* dconf-service*
giblib1* glib-networking* glib-networking-common* glib-networking-services*
gnome-icon-theme* gsettings-desktop-schemas* gtk-update-icon-cache*
hicolor-icon-theme* libatk-bridge2.0-0* libatk1.0-0* libatk1.0-data*
libatspi2.0-0* libcairo-gobject2* libcolord2* libdconf1* libgail-common*
libgail18* libgif7* libgtk-3-0* libgtk-3-bin* libgtk-3-common* libgtk2.0-0*
libgtk2.0-bin* libgtk2.0-common* libimlib2* libjson-glib-1.0-0*
libjson-glib-1.0-common* liblcms2-2* libobrender32v5* libobt2v5*
libpangoxft-1.0-0* libproxy1v5* librest-0.7-0* libsoup-gnome2.4-1*
libsoup2.4-1* libstartup-notification0* libxcb-util0* obconf* obsession*
openbox* scrot*
0 upgraded, 0 newly installed, 45 to remove and 158 not upgraded.
After this operation, 116 MB disk space will be freed.
(Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 51717 files and directories currently installed.)
Removing libgtk2.0-bin (2.24.32-3+rpt1) ...
Removing libgail-common:armhf (2.24.32-3+rpt1) ...
Removing libgail18:armhf (2.24.32-3+rpt1) ...
Removing obconf (1:2.0.4+git20150213-2+rpt4) ...
Removing at-spi2-core (2.30.0-7) ...
Removing libgtk-3-bin (3.24.5-1+rpt2) ...
Removing scrot (0.9-1) ...
Removing giblib1:armhf (1.2.4-12) ...
Removing gnome-icon-theme (3.12.0-3) ...
update-alternatives: using /usr/share/icons/gnome/scalable/places/gnome-foot.svg to provide /usr/share/icons/gnome/scalable/places/start-here.svg (start-here.svg) in auto mode
update-alternatives: warning: skip creation of /usr/share/icons/gnome/256x256/places/start-here.png because associated file /usr/share/icons/gnome/256x256/places/gnome-foot.png (of link group start-here.svg) doesn't exist
Removing openbox (3.6.1-8+rpt5) ...
Removing libobrender32v5 (3.6.1-8+rpt5) ...
Removing libimlib2:armhf (1.5.1-1) ...
Removing libgif7:armhf (5.1.4-3+deb10u1) ...
Removing libobt2v5 (3.6.1-8+rpt5) ...
Removing libpangoxft-1.0-0:armhf (1.42.4-8~deb10u1) ...
Removing libstartup-notification0:armhf (0.12-6) ...
Removing libxcb-util0:armhf (0.3.8-3+b2) ...
Removing obsession (20140608-2) ...
Removing libgtk2.0-0:armhf (2.24.32-3+rpt1) ...
Removing libgtk-3-0:armhf (3.24.5-1+rpt2) ...
Removing adwaita-icon-theme (3.30.1-1) ...
Removing libgtk-3-common (3.24.5-1+rpt2) ...
Removing librest-0.7-0:armhf (0.8.1-1) ...
Removing libsoup-gnome2.4-1:armhf (2.64.2-2) ...
Removing libsoup2.4-1:armhf (2.64.2-2) ...
Removing glib-networking:armhf (2.58.0-2+deb10u2) ...
Removing gsettings-desktop-schemas (3.28.1-1) ...
Removing dconf-gsettings-backend:armhf (0.30.1-2) ...
Removing dconf-service (0.30.1-2) ...
Removing glib-networking-services (2.58.0-2+deb10u2) ...
Removing glib-networking-common (2.58.0-2+deb10u2) ...
Removing gtk-update-icon-cache (3.24.5-1+rpt2) ...
Removing hicolor-icon-theme (0.17-2) ...
Removing libatk-bridge2.0-0:armhf (2.30.0-5) ...
Removing libatk1.0-0:armhf (2.30.0-2) ...
Removing libatk1.0-data (2.30.0-2) ...
Removing libatspi2.0-0:armhf (2.30.0-7) ...
Removing libcairo-gobject2:armhf (1.16.0-4+rpt1+deb10u1) ...
Removing libcolord2:armhf (1.4.3-4) ...
Removing libdconf1:armhf (0.30.1-2) ...
Removing libgtk2.0-common (2.24.32-3+rpt1) ...
Removing libjson-glib-1.0-0:armhf (1.4.4-2) ...
Removing libjson-glib-1.0-common (1.4.4-2) ...
Removing liblcms2-2:armhf (2.9-3) ...
Removing libproxy1v5:armhf (0.4.15-5+deb10u1) ...
No schema files found: removed existing output file.
(Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 37946 files and directories currently installed.)
Purging configuration files for libgtk-3-0:armhf (3.24.5-1+rpt2) ...
Purging configuration files for libgtk2.0-0:armhf (2.24.32-3+rpt1) ...
Purging configuration files for obsession (20140608-2) ...
Purging configuration files for adwaita-icon-theme (3.30.1-1) ...
Purging configuration files for openbox (3.6.1-8+rpt5) ...
Purging configuration files for at-spi2-core (2.30.0-7) ...
Purging configuration files for libgtk2.0-common (2.24.32-3+rpt1) ...
Purging configuration files for libgtk-3-common (3.24.5-1+rpt2) ...
keyboard-configuration* libegl-mesa0* libegl1* libegl1-mesa* libepoxy0*
libevdev2* libfontenc1* libgbm1* libglu1-mesa* libgudev-1.0-0* libinput-bin*
libinput10* libmtdev1* libpciaccess0* libunwind8* libutempter0*
libwacom-bin* libwacom-common* libwacom2* libwayland-server0* libxaw7*
libxcomposite1* libxfont2* libxft2* libxkbfile1* libxmu6* libxpm4* libxt6*
libxxf86dga1* x11-apps* x11-session-utils* x11-utils* x11-xkb-utils*
x11-xserver-utils* xbitmaps* xfonts-100dpi* xfonts-75dpi* xfonts-base*
xfonts-encodings* xfonts-scalable* xfonts-utils* xinit* xorg*
xorg-docs-core* xserver-common* xserver-xorg* xserver-xorg-core*
xserver-xorg-input-all* xserver-xorg-input-libinput*
xserver-xorg-input-wacom* xserver-xorg-legacy* xserver-xorg-video-all*
xserver-xorg-video-amdgpu* xserver-xorg-video-ati* xserver-xorg-video-fbdev*
xserver-xorg-video-nouveau* xserver-xorg-video-radeon*
xserver-xorg-video-vesa* xterm*
0 upgraded, 0 newly installed, 59 to remove and 158 not upgraded.
After this operation, 43.5 MB disk space will be freed.
Removing xorg (1:7.7+19+b8) ...
Removing xserver-xorg (1:7.7+19+b8) ...
Removing xserver-xorg-video-all (1:7.7+19+b8) ...
Removing xserver-xorg-video-vesa (1:2.4.0-1+b1) ...
Removing xserver-xorg-video-ati (1:19.0.1-1) ...
Removing xserver-xorg-video-radeon (1:19.0.1-1) ...
Removing xserver-xorg-input-wacom (0.34.99.1-1+b6) ...
Removing xserver-xorg-video-nouveau (1:1.0.16-1) ...
Removing xserver-xorg-video-fbdev (1:0.5.0-1+b2) ...
Removing xserver-xorg-input-all (1:7.7+19+b8) ...
Removing xserver-xorg-input-libinput (0.28.2-2) ...
Removing libinput10:armhf (1.12.6-2+deb10u1) ...
Removing libinput-bin (1.12.6-2+deb10u1) ...
Removing libevdev2:armhf (1.6.0+dfsg-1) ...
Removing xfonts-scalable (1:1.0.3-1.1) ...
Removing xfonts-base (1:1.0.5) ...
Removing x11-utils (7.7+4) ...
Removing xserver-xorg-video-amdgpu (18.1.99+git20190207-1) ...
Removing libglu1-mesa:armhf (9.0.0-2.1) ...
Removing libwacom-bin (0.32-1) ...
Removing libwacom2:armhf (0.32-1) ...
Removing libgudev-1.0-0:armhf (232-2+rpi1) ...
Removing libmtdev1:armhf (1.1.5-1+b2) ...
Removing xterm (344-1+deb10u2) ...
Removing libutempter0:armhf (1.1.6-3) ...
Removing libwacom-common (0.32-1) ...
Removing x11-xserver-utils (7.7+8+rpt1) ...
Removing xserver-xorg-legacy (2:1.20.4-1+rpt4+deb10u9) ...
Removing libxcomposite1:armhf (1:0.4.4-2) ...
Removing x11-apps (7.7+7) ...
Removing libxft2:armhf (2.3.2-2) ...
Removing x11-session-utils (7.7+3) ...
Removing xbitmaps (1.1.1-2) ...
Removing xfonts-100dpi (1:1.0.4+nmu1) ...
Removing xfonts-75dpi (1:1.0.4+nmu1) ...
Removing xinit (1.4.0-1) ...
Removing xorg-docs-core (1:1.7.1-1.1) ...
Removing xserver-xorg-core (2:1.20.4-1+rpt4+deb10u9) ...
Removing libepoxy0:armhf (1.5.3-0.1) ...
Removing xfonts-utils (1:7.7+6) ...
Removing libpciaccess0:armhf (0.14-1) ...
Removing libunwind8:armhf (1.2.1-10~deb10u1) ...
Removing xserver-common (2:1.20.4-1+rpt4+deb10u9) ...
Removing x11-xkb-utils (7.7+4) ...
Removing libxaw7:armhf (2:1.0.13-1+b2) ...
Removing libxfont2:armhf (1:2.0.3-1) ...
Removing libxkbfile1:armhf (1:1.0.9-2) ...
Removing libxmu6:armhf (2:1.1.2-2+b3) ...
Removing libxpm4:armhf (1:3.5.12-1+deb10u2) ...
Removing libxt6:armhf (1:1.1.5-1+b3) ...
Removing xfonts-encodings (1:1.0.4-2) ...
dpkg: warning: while removing xfonts-encodings, directory '/usr/share/fonts/X11/encodings/large' not empty so not removed
Removing libfontenc1:armhf (1:1.1.3-1) ...
(Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 35603 files and directories currently installed.)
Purging configuration files for xinit (1.4.0-1) ...
Purging configuration files for xfonts-100dpi (1:1.0.4+nmu1) ...
dpkg: warning: while removing xfonts-100dpi, directory '/usr/share/fonts/X11/100dpi' not empty so not removed
Purging configuration files for xserver-xorg (1:7.7+19+b8) ...
Purging configuration files for xserver-xorg-core (2:1.20.4-1+rpt4+deb10u9) ...
rm: cannot remove '/var/log/Xorg.*.log': No such file or directory
rm: cannot remove '/var/log/Xorg.*.log.old': No such file or directory
Purging configuration files for x11-apps (7.7+7) ...
Purging configuration files for xfonts-utils (1:7.7+6) ...
dpkg: warning: while removing xfonts-utils, directory '/usr/share/fonts/X11/util' not empty so not removed
Purging configuration files for x11-xserver-utils (7.7+8+rpt1) ...
Purging configuration files for libfontenc1:armhf (1:1.1.3-1) ...
Purging configuration files for xfonts-base (1:1.0.5) ...
dpkg: warning: while removing xfonts-base, directory '/usr/share/fonts/X11/misc' not empty so not removed
Purging configuration files for x11-utils (7.7+4) ...
Purging configuration files for x11-session-utils (7.7+3) ...
Purging configuration files for libglu1-mesa:armhf (9.0.0-2.1) ...
Purging configuration files for xterm (344-1+deb10u2) ...
Purging configuration files for xfonts-75dpi (1:1.0.4+nmu1) ...
dpkg: warning: while removing xfonts-75dpi, directory '/usr/share/fonts/X11/75dpi' not empty so not removed
Purging configuration files for xserver-xorg-legacy (2:1.20.4-1+rpt4+deb10u9) ...
Purging configuration files for xfonts-scalable (1:1.0.3-1.1) ...
dpkg: warning: while removing xfonts-scalable, directory '/usr/share/fonts/X11/Type1' not empty so not removed
Deleting /etc/X11/xorg.conf.d/95-touch_display-plugin.conf
Deleting /etc/X11/xorg.conf.d/99-vc4.conf
Done
Removing temporary directory /tmp/touch_display-yiaBhdO8Wt
Please read a few post back till your post.
Hi. What if none of these apply - that is, time and date are correct, no credentials have been changed from default, and the error occurs?
Try changing the repository mirror as described here
hi wheaten! im having a hardtime to install touch display plugin this is something not happen before.
RPI3b+
ver 3.779 and latest ver also.
7 inch touch display from http://www.lcdwiki.com/res/MPI7002/7inch_HDMI_Display-C_User_Manual(En).pdf
Unpacking plugin
Reading package lists…
Building dependency tree…
Reading state information…
Reading package lists…/lib/systemd/system/volumio-kiosk.service
Done
Removing temporary directory /tmp/touch_display-FrTYionvel
thank you.
Uninstall “Touch Display” if possible, reboot and install again.
Sometimes this error occurs. Till this day no clue why.
Thanks wheaten it is working now. However, after a few minutes the screen went to bluescreen if i touch the screen again it went back to normal again.
this prob. caused by installing unsupported drivers.
Also not sure why you didn’t install the touch display form the plugin store?
Добрый день, у меня не устанавливается плагин на дисплей, RPI4b. Перезагрузки не помогают, VERSION: 3.795.
Good day, I can’t install the plugin on the display, RPI4b. Reboots don’t help, VERSION: 3.795.
Last modification reported: Wed, 12 Mar 2025 10:15:17 +0000
Fetched 23.2 kB in 8s (2908 B/s)
Cleaning up…
Package ‘fonts-arphic-ukai’ is not installed, so not removed
Package ‘fonts-arphic-gbsn00lp’ is not installed, so not removed
Package ‘fonts-unfonts-core’ is not installed, so not removed
Package ‘fonts-ipafont’ is not installed, so not removed
Package ‘fonts-vlgothic’ is not installed, so not removed
Package ‘fonts-thai-tlwg-ttf’ is not installed, so not removed
Package ‘chromium-browser’ is not installed, so not removed
Package ‘openbox’ is not installed, so not removed
Package ‘xinit’ is not installed, so not removed
Done
Removing temporary directory /tmp/touch_display-T7dE4uuLiA
Hey @galushchenko.nikolai,
From your report, I can not determine, whether you are discussing problem with hardware: Official Raspberry Pi Touch Display or whether this is related to plugin: Touch Display.
Can you clarify please?
Especially on Pi4 models these errors are often caused by incorrectly set system time/date. So, at first check date and time of your Volumio system. For correcting them see Waveshare 7" hdmi lcd (B) touch screen problem - #15 by Wheaten
Another reason can be unreachable repositories, e.g. because of DNS blocking. Sometimes changing the repository mirror as described here helps.
