display_rotate=1 -----> 3
in userconfig or Touch plugin?
userc
thanks Gelo5
thanks Wheaton
And what should @nerd do with the new monitor now?
enjoy it… ![]()
Use it to stir his coffee ![]()
First of all, I would like to thank you for the support, which was sometimes a bit tedious for everyone involved but excellent, which has now brought a great result for me and probably also for all Volumio “nerds”; Thanks and best regards, by
ReyNee from Radio-M1, the only one…
AOR, Melodic Mainstream & Classic Rock
Radio M1, the only one…
one of the pioneers of the private radio channel from the exposed site"Schwarzenstein(3368m)" to north/southtyrol- and southgermany and often by FM overreach to Sweden ;-with AOR radio program supplied.
M1 keep on rockin '…℗ m1-publishing
dedicated to Claus Fuehrer.
und international über die TuneIn App
http://tunein.com/radio/Radio-M1-s152326/
http://www.facebook.com/radiom1
℗ m1-publishing, dedicated to Claus Fuehrer.
DJ: M1-Publishing Association (Schwarzenstein)
now it works, backup your SD with “Win32DiskImager” !!!
yeah, yes Wheaton thank you…
Who is Wheaton???
From such excitement children can be… watch out ![]()
Hi. Can someone tell me: I bought a 1920x480 monitor (https://sl.aliexpress.ru/p?key=ar0DrJC). When connected to volumio x86, the sensor works (touchscreen). It does not respond to clicks on Pi4.
Userconfig.txt:
hdmi_timings=480 0 30 30 30 1920 0 6 6 6 0 0 0 60 0 55296000 8
hdmi_group=2
hdmi_mode=87
hdmi_drive=2
display_rotate=1
hdmi_force_mode=1
framebuffer_width=1920
framebuffer_height=480
max_framebuffer_width=1920
max_framebuffer_height=1920
Volumio ver. 3.757
Touch Display ver. 3.5.0
Raspberry Pi4 + ChipDipDAC
Is the image on the screen(Rpi)?
Is the USB cable connected from rpi to the Touch port?
A second USB cable is connected from the rpi to the power outlet (or a separate power supply)?
image on the screen ок
one port microusb in display connect to usb in pi4
No second usb port in display
Please check if running
sudo apt-get -y install xserver-xorg-input-evdev
sudo cp /usr/share/X11/xorg.conf.d/10-evdev.conf /etc/X11/xorg.conf.d/45-evdev.conf
and restarting the Touch Display plugin helps.
