OKEEEE
OH NOOO
I don’t think this issue is related to the display. I suggest to open a new dedicacted thread for this error.
another problem
I can’t turn the display
no matter if I do this :
dtoverlay=vc4-kms-v3d
dtoverlay=vc4-kms-dsi-waveshare-panel,7_9_inch,rotation=90
or this :
nitramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
force_eeprom_read=0
hdmi_group=2
hdmi_mode=87
hdmi_blanking=1
display_rotate=3
I have a display rotation problem
display_lcd_rotate=2
or
none of this works, the display always remains the same
remove everything where you added something with rotate
display_rotate=3
,rotation=90
,rotate=90
mkdir /home/volumio/.config/openbox
cat >> /home/volumio/.config/openbox/autostart <<EOL
xrandr --output DSI-1 --rotate right
EOL
reboot
unbelievable what you know
I’ve been reading everywhere for over an hour…
You are my hero
A thousand and one thanks
All credits goes to @gvolt.
In your case, make sure you create a backup of your SD, using Win32DiskImager. So if you mess up the installation, you don’t have to do this again.
Very good idea!
Also many thanks to @gvolt.
Hi!
I installed touch display beta 3.3.8. It works but it was impossible to play music. Play button doesn´t react at all.
I revert back to vers 3.3.7 but issue still remains.
The uninstall script of the plugin version 3.3.7 (and previous versions) damages the system of the current/newer Volumio versions. I discovered that only yesterday. The issue should be fixed in 3.3.8, but I think you will have to reinstall Volumio this time. Sorry for that.
Ok!
Nothing else to do. Thanks for quick answer.
So, on a fresh install I should go for TD version 3.3.8?
Best Regards / C
Yes, and only 3.3.8. ![]()
there is no way to fix the damage before uninstalling the 3.3.7 version?
Yes, by running
sed -i '8d; 12,14d' /data/plugins/user_interface/touch_display/uninstall.sh
before uninstalling / updating the plugin.
I was unable to update to v3.3.8 the normal way
I succeeded with this command.
Thank you.
Hi @gvolt ,
I tried to install 3.3.8 but was imposible. I uninstall first 3.3.7 but new ver. installed with fault:
I install one more time 3.3.7 use your command and install 3.3.8 but… Volumio not react on Play button.
Tried to back to 3.3.7 but still can’t play music.
Here are logs:
http://logs.volumio.org/volumio/7f6K5AS.html
Should I reinstall Volumio ??
please, disable peppy and retry
Nothing change, I have problem with change song or source, it takes time and not play.
