Yeah he’s not a reader ![]()
that was all at the very beginning
I have installed NO (!) drivers
in the meantime I have reinstalled the system
Everything as always, DOES NOT WORK
This error message ALWAYS comes up
… and in the reinstalled system did you try to install the Waveshare drivers?
Also please post the result of
/etc/X11/xorg.conf.d/99-vc4.conf
BTW: Did you try without the overlay’s rotation parameter?
volumio@volumio:~$ /etc/X11/xorg.conf.d/99-vc4.conf
-bash: /etc/X11/xorg.conf.d/99-vc4.conf: Permission denied
YES
Sorry, command has to be
cat /etc/X11/xorg.conf.d/99-vc4.conf
BTW: No need for yelling, IMHO.
If you didn’t install drivers, why did you post the 3rd image a couple of post ago?
As this clearly shows you tried to run the installer and it fails.
This leaves your Volumio installation in a unknown state.
That was days ago when I was testing all kinds of things
In the meantime it is a NEW image WITHOUT drivers, just like I wrote it !
ONLY THIS
This is how I did it
- installed Volumio and “simply” configured it
- System restart
- installed and activated the Touch Display 3.37 plugin from the store
- System restart
- changed the userconfig.txt :
dtoverlay=vc4-kms-v3d
dtoverlay=vc4-kms-dsi-waveshare-panel,7_9_inch,rotation=90
- System restart
- peppy_screensaver_beta_1.3.9 installed and activated
sudo bash -c 'cat << EOF > /etc/X11/xorg.conf.d/99-vc4.conf
Section "OutputClass"
Identifier "vc4"
MatchDriver "vc4"
Driver "modesetting"
Option "PrimaryGPU" "true"
EndSection
EOF'
- System restart
- Do a factory reset.
- Configure Volumio just the bare minimum
- Reboot
- add to /boot/userconfig.txt (as you didn’t answer this)
If you have a 7 inch screen:
dtoverlay=vc4-kms-dsi-waveshare-panel,7inch
if you have a 7.9 Inch
- reboot
- install the touch plugin and nothing else!!
- reboot
- After reboot post the log.
Please do exactly as instructed, nothing more or less.
I just did that,
In the meantime I have changed the Pi3, now it is a Pi3B+, before it was a Pi3B
but display still does not work
It is a ,7_9 Display !
Log ist to long
volumio@volumio:~$ cat /boot/config.txt
### DO NOT EDIT THIS FILE ###
initramfs volumio.initrd
include volumioconfig.txt
include userconfig.txt
volumio@volumio:~$ cat /boot/userconfig.txt
# Add your custom config.txt options to this file, which will be preserved durin g updates
display_lcd_rotate=2
volumio@volumio:~$
Its weird.
@gvolt
Seems kiosk started without issues:
Feb 01 13:41:06 volumio sudo[1017]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start volumio-kiosk.service
Feb 01 13:41:06 volumio sudo[1017]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 01 13:41:06 volumio volumio[830]: Error adding Membership: Error: addMembership EINVAL
Feb 01 13:41:06 volumio volumio[830]: info: Shairport-Sync Started
Feb 01 13:41:06 volumio systemd[1]: Started Volumio Kiosk.
Feb 01 13:41:06 volumio sudo[1017]: pam_unix(sudo:session): session closed for user root
Feb 01 13:41:06 volumio volumio[830]: info: CoreCommandRouter::volumioGetState
Feb 01 13:41:06 volumio volumio[830]: info: CorePlayQueue::getTrack 0
Feb 01 13:41:06 volumio volumio[830]: info: touch_display: systemctl start volumio-kiosk.service succeeded
And here something happens:
Feb 01 13:41:06 volumio startx[1019]: Current version of pixman: 0.36.0
Feb 01 13:41:06 volumio startx[1019]: Before reporting problems, check http://wiki.x.org
Feb 01 13:41:06 volumio startx[1019]: to make sure that you have the latest version.
Feb 01 13:41:06 volumio startx[1019]: Markers: (--) probed, (**) from config file, (==) default setting,
Feb 01 13:41:06 volumio startx[1019]: (++) from command line, (!!) notice, (II) informational,
Feb 01 13:41:06 volumio startx[1019]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 01 13:41:06 volumio startx[1019]: (==) Log file: "/home/volumio/.local/share/xorg/Xorg.0.log", Time: Thu Feb 1 13:41:06 2024
Feb 01 13:41:06 volumio startx[1019]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Feb 01 13:41:06 volumio startx[1019]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Feb 01 13:41:06 volumio volumio[830]: info: touch_display: Using Xserver unix domain socket /tmp/.X11-unix/X0
Feb 01 13:41:06 volumio startx[1019]: (EE)
Feb 01 13:41:06 volumio startx[1019]: Fatal server error:
Feb 01 13:41:06 volumio startx[1019]: (EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
Feb 01 13:41:06 volumio startx[1019]: Please consult the The X.Org Foundation support
Feb 01 13:41:06 volumio startx[1019]: at http://wiki.x.org
Feb 01 13:41:06 volumio startx[1019]: for help.
Feb 01 13:41:06 volumio startx[1019]: (EE) Please also check the log file at "/home/volumio/.local/share/xorg/Xorg.0.log" for additional information.
Feb 01 13:41:06 volumio startx[1019]: (EE) Server terminated with error (1). Closing log file.
@Franky_Byte
Can you post the output of:
cat /home/volumio/.local/share/xorg/Xorg.0.log
@Franky_Byte
and the output of
ls -al /dev/tty*
Welcome to Volumio for Raspberry Pi (6.1.69-v7+ armv7l)
volumio@volumio:~$ cat /home/volumio/.local/share/xorg/Xorg.0.log
[ 38.925]
X.Org X Server 1.20.4
[ 38.926] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 38.926] Current Operating System: Linux volumio 6.1.69-v7+ #1710 SMP Thu Dec 21 13:14:13 GMT 2023 armv7l
[ 38.926] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 38.926] Build Date: 04 April 2023 07:50:56AM
[ 38.926] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 38.926] Current version of pixman: 0.36.0
[ 38.926] Before reporting problems, check http://wiki.x.org
[ 38.926] Markers: (--) probed, (**) from config file, (==) default setting,
[ 38.926] (==) Log file: "/home/volumio/.local/share/xorg/Xorg.0.log", Time: Thu Feb 1 15:44:54 2024
[ 38.934] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 38.934] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 38.938] (==) No Layout section. Using the first Screen section.
[ 38.938] (==) No screen section available. Using defaults.
[ 38.938] (**) |-->Screen "Default Screen Section" (0)
[ 38.938] (**) | |-->Monitor "<default monitor>"
[ 38.944] (==) No monitor specified for screen "Default Screen Section".
[ 38.945] (==) Automatically adding devices
[ 38.945] (==) Automatically enabling devices
[ 38.945] (==) Automatically adding GPU devices
[ 38.951] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 38.964] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 38.964] Entry deleted from font path.
[ 38.965] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 38.965] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 38.965] (II) The server relies on udev to provide the list of input devices.
[ 38.965] (II) Loader magic: 0x1fdf80
[ 38.965] (II) Module ABI versions:
[ 38.965] X.Org ANSI C Emulation: 0.4
[ 38.965] X.Org Video Driver: 24.0
[ 38.965] X.Org XInput driver : 24.1
[ 38.966] X.Org Server Extension : 10.0
[ 39.039] (EE) systemd-logind: failed to get session: PID 1092 does not belong to any known session
[ 39.042] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 39.045] (**) OutputClass "vc4" setting /dev/dri/card0 as PrimaryGPU
[ 39.045] (II) LoadModule: "glx"
[ 39.049] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 39.095] (II) Module glx: vendor="X.Org Foundation"
[ 39.095] compiled for 1.20.4, module version = 1.0.0
[ 39.095] ABI class: X.Org Server Extension, version 10.0
[ 39.095] (II) Applying OutputClass "vc4" to /dev/dri/card0
[ 39.095] loading driver: modesetting
[ 39.095] (==) Matched modesetting as autoconfigured driver 0
[ 39.095] (==) Matched fbdev as autoconfigured driver 1
[ 39.095] (==) Assigned the driver to the xf86ConfigLayout
[ 39.095] (II) LoadModule: "modesetting"
[ 39.096] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 39.100] (II) Module modesetting: vendor="X.Org Foundation"
[ 39.100] compiled for 1.20.4, module version = 1.20.4
[ 39.101] Module class: X.Org Video Driver
[ 39.101] ABI class: X.Org Video Driver, version 24.0
[ 39.101] (II) LoadModule: "fbdev"
[ 39.101] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 39.103] (II) Module fbdev: vendor="X.Org Foundation"
[ 39.103] compiled for 1.20.3, module version = 0.5.0
[ 39.103] Module class: X.Org Video Driver
[ 39.103] ABI class: X.Org Video Driver, version 24.0
[ 39.103] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 39.103] (II) FBDEV: driver for framebuffer: fbdev
[ 39.103] (EE)
Fatal server error:
[ 39.103] (EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
[ 39.103] (EE)
[ 39.103] (EE)
for help.
[ 39.103] (EE) Please also check the log file at "/home/volumio/.local/share/xorg/Xorg.0.log" for additional information.
[ 39.103] (EE)
[ 39.105] (WW) xf86CloseConsole: KDSETMODE failed: Bad file descriptor
[ 39.105] (WW) xf86CloseConsole: VT_GETMODE failed: Bad file descriptor
[ 39.105] (EE) Server terminated with error (1). Closing log file.
volumio@volumio:~$
volumio@volumio:~$ ls -al /dev/tty*
crw-rw-rw- 1 root tty 5, 0 Feb 1 15:44 /dev/tty
crw--w---- 1 root tty 4, 0 Feb 1 15:44 /dev/tty0
crw--w---- 1 root tty 4, 1 Feb 1 15:44 /dev/tty1
crw--w---- 1 root tty 4, 10 Feb 1 15:44 /dev/tty10
crw--w---- 1 root tty 4, 11 Feb 1 15:44 /dev/tty11
crw--w---- 1 root tty 4, 12 Feb 1 15:44 /dev/tty12
crw--w---- 1 root tty 4, 13 Feb 1 15:44 /dev/tty13
crw--w---- 1 root tty 4, 14 Feb 1 15:44 /dev/tty14
crw--w---- 1 root tty 4, 15 Feb 1 15:44 /dev/tty15
crw--w---- 1 root tty 4, 16 Feb 1 15:44 /dev/tty16
crw--w---- 1 root tty 4, 17 Feb 1 15:44 /dev/tty17
crw--w---- 1 root tty 4, 18 Feb 1 15:44 /dev/tty18
crw--w---- 1 root tty 4, 19 Feb 1 15:44 /dev/tty19
crw--w---- 1 root tty 4, 2 Feb 1 15:44 /dev/tty2
crw--w---- 1 root tty 4, 20 Feb 1 15:44 /dev/tty20
crw--w---- 1 root tty 4, 21 Feb 1 15:44 /dev/tty21
crw--w---- 1 root tty 4, 22 Feb 1 15:44 /dev/tty22
crw--w---- 1 root tty 4, 23 Feb 1 15:44 /dev/tty23
crw--w---- 1 root tty 4, 24 Feb 1 15:44 /dev/tty24
crw--w---- 1 root tty 4, 25 Feb 1 15:44 /dev/tty25
crw--w---- 1 root tty 4, 26 Feb 1 15:44 /dev/tty26
crw--w---- 1 root tty 4, 27 Feb 1 15:44 /dev/tty27
crw--w---- 1 root tty 4, 28 Feb 1 15:44 /dev/tty28
crw--w---- 1 root tty 4, 29 Feb 1 15:44 /dev/tty29
crw--w---- 1 root tty 4, 3 Feb 1 15:44 /dev/tty3
crw--w---- 1 root tty 4, 30 Feb 1 15:44 /dev/tty30
crw--w---- 1 root tty 4, 31 Feb 1 15:44 /dev/tty31
crw--w---- 1 root tty 4, 32 Feb 1 15:44 /dev/tty32
crw--w---- 1 root tty 4, 33 Feb 1 15:44 /dev/tty33
crw--w---- 1 root tty 4, 34 Feb 1 15:44 /dev/tty34
crw--w---- 1 root tty 4, 35 Feb 1 15:44 /dev/tty35
crw--w---- 1 root tty 4, 36 Feb 1 15:44 /dev/tty36
crw--w---- 1 root tty 4, 37 Feb 1 15:44 /dev/tty37
crw--w---- 1 root tty 4, 38 Feb 1 15:44 /dev/tty38
crw--w---- 1 root tty 4, 39 Feb 1 15:44 /dev/tty39
crw--w---- 1 root tty 4, 4 Feb 1 15:44 /dev/tty4
crw--w---- 1 root tty 4, 40 Feb 1 15:44 /dev/tty40
crw--w---- 1 root tty 4, 41 Feb 1 15:44 /dev/tty41
crw--w---- 1 root tty 4, 42 Feb 1 15:44 /dev/tty42
crw--w---- 1 root tty 4, 43 Feb 1 15:44 /dev/tty43
crw--w---- 1 root tty 4, 44 Feb 1 15:44 /dev/tty44
crw--w---- 1 root tty 4, 45 Feb 1 15:44 /dev/tty45
crw--w---- 1 root tty 4, 46 Feb 1 15:44 /dev/tty46
crw--w---- 1 root tty 4, 47 Feb 1 15:44 /dev/tty47
crw--w---- 1 root tty 4, 48 Feb 1 15:44 /dev/tty48
crw--w---- 1 root tty 4, 49 Feb 1 15:44 /dev/tty49
crw--w---- 1 root tty 4, 5 Feb 1 15:44 /dev/tty5
crw--w---- 1 root tty 4, 50 Feb 1 15:44 /dev/tty50
crw--w---- 1 root tty 4, 51 Feb 1 15:44 /dev/tty51
crw--w---- 1 root tty 4, 52 Feb 1 15:44 /dev/tty52
crw--w---- 1 root tty 4, 53 Feb 1 15:44 /dev/tty53
crw--w---- 1 root tty 4, 54 Feb 1 15:44 /dev/tty54
crw--w---- 1 root tty 4, 55 Feb 1 15:44 /dev/tty55
crw--w---- 1 root tty 4, 56 Feb 1 15:44 /dev/tty56
crw--w---- 1 root tty 4, 57 Feb 1 15:44 /dev/tty57
crw--w---- 1 root tty 4, 58 Feb 1 15:44 /dev/tty58
crw--w---- 1 root tty 4, 59 Feb 1 15:44 /dev/tty59
crw--w---- 1 root tty 4, 6 Feb 1 15:44 /dev/tty6
crw--w---- 1 root tty 4, 60 Feb 1 15:44 /dev/tty60
crw--w---- 1 root tty 4, 61 Feb 1 15:44 /dev/tty61
crw--w---- 1 root tty 4, 62 Feb 1 15:44 /dev/tty62
crw--w---- 1 root tty 4, 63 Feb 1 15:44 /dev/tty63
crw--w---- 1 root tty 4, 7 Feb 1 15:44 /dev/tty7
crw--w---- 1 root tty 4, 8 Feb 1 15:44 /dev/tty8
crw--w---- 1 root tty 4, 9 Feb 1 15:44 /dev/tty9
crw------- 1 root root 5, 3 Feb 1 15:44 /dev/ttyprintk
volumio@volumio:~$
Please post the result of
apt list --installed | grep xserver-xorg-legacy
permitted by applicable law.
volumio@volumio:~$ apt list --installed | grep xserver-xorg-legacy
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
xserver-xorg-legacy/oldoldstable,now 2:1.20.4-1+rpt4+deb10u9 armhf [installed,au tomatic]
volumio@volumio:~$
Please post the output of
ls -al /usr/lib/xorg
and
cat /etc/X11/Xwrapper.config
volumio@volumio:~$ ls -al /usr/lib/xorg
total 1977
drwxr-xr-x 3 root root 1024 Feb 2 16:50 .
drwxr-xr-x 1 root root 1024 Feb 2 16:52 ..
-rwxr-xr-x 1 root root 1982048 Apr 4 2023 Xorg
-rwsr-sr-x 1 root root 9808 Apr 4 2023 Xorg.wrap
drwxr-xr-x 5 root root 1024 Feb 2 16:50 modules
-rw-r--r-- 1 root root 25699 Apr 4 2023 protocol.txt
volumio@volumio:~$
and
volumio@volumio:~$ cat /etc/X11/Xwrapper.config
# Xwrapper.config (Debian X Window System server wrapper configuration file)
# This file was generated by the post-installation script of the
# xserver-xorg-legacy package using values from the debconf database.
# See the Xwrapper.config(5) manual page for more information.
# This file is automatically updated on upgrades of the xserver-xorg-legacy
# package *only* if it has not been modified since the last upgrade of that
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command as root:
# dpkg-reconfigure xserver-xorg-legacy
allowed_users=anybody
volumio@volumio:~$
Please run
sudo bash -c 'echo "needs_root_rights=yes" >> /etc/X11/Xwrapper.config'
then stop and start the Touch Display plugin.
