[PLUGIN] Touch Display
please connect to Volumio via SSH .
Then execute
cat /boot/config.txt
and
cat /boot/userconfig.txt
and post the output.
SSH - YES
@gvolt
Can you take a look
Did you run β€œWS_xinchDSI_MAIN.sh” on the current installation?
Please post the output of
and
cat /var/log/Xorg.0.log
fa7A
I have NOT installed any other drivers…
This error message always appears
According to the picture above you currently have version 3.3.6 of the Touch Display plugin installed. Uninstall it and install 3.3.7.
I have tried all versions, including a new Volumio image in between
Execute
systemctl status -l volumio-kiosk
and post the output. Please don’t post screenshots of such command’s output but copy the output from Volumio’s console, paste it into a post and format the pasted content using code tags for better readablity.
Has the Touch Display plugin been installed from the plugin store?
Has the password for root been changed?
Thank you very much for your help
Plugins loaded from the store
The password has not been changed
volumio-kiosk.service - Volumio Kiosk
   Loaded: loaded (/lib/systemd/system/volumio-kiosk.service; disabled; vendor p
   Active: active (running) since Fri 2024-01-19 18:23:52 CET; 1 weeks 5 days ag
 Main PID: 1033 (startx)
    Tasks: 76 (limit: 1563)
   CGroup: /system.slice/volumio-kiosk.service
           β”œβ”€1033 /bin/sh /usr/bin/startx /etc/X11/Xsession /opt/volumiokiosk.sh
           β”œβ”€1056 xinit /etc/X11/Xsession /opt/volumiokiosk.sh -- /usr/bin/X :0
           β”œβ”€1057 /usr/lib/xorg/Xorg :0 -nocursor -auth /tmp/serverauth.y7Qny0yC
           β”œβ”€1138 /bin/bash /opt/volumiokiosk.sh
           β”œβ”€1164 /usr/bin/ssh-agent /opt/volumiokiosk.sh
           β”œβ”€1171 /usr/bin/openbox --startup /usr/lib/arm-linux-gnueabihf/openbo
           β”œβ”€1172 /usr/lib/chromium-browser/chromium-browser-v7 --enable-pinch -
           β”œβ”€1208 /usr/lib/chromium-browser/crashpad_handler --monitor-self --mo
           β”œβ”€1210 /usr/lib/chromium-browser/crashpad_handler --no-periodic-tasks
           β”œβ”€1214 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --
           β”œβ”€1215 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --
           β”œβ”€1217 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --
           β”œβ”€1247 /usr/lib/chromium-browser/chromium-browser-v7 --type=utility -
           β”œβ”€1262 /usr/lib/chromium-browser/chromium-browser-v7 --type=gpu-proce
           β”œβ”€1264 /usr/lib/chromium-browser/chromium-browser-v7 --type=broker
           β”œβ”€1273 /usr/lib/chromium-browser/chromium-browser-v7 --type=utility -
           └─1287 /usr/lib/chromium-browser/chromium-browser-v7 --type=renderer
lines 1-23...skipping...
● volumio-kiosk.service - Volumio Kiosk
   Loaded: loaded (/lib/systemd/system/volumio-kiosk.service; disabled; vendor preset: enabled)
   Active: active (running) since Fri 2024-01-19 18:23:52 CET; 1 weeks 5 days ago
           β”œβ”€1033 /bin/sh /usr/bin/startx /etc/X11/Xsession /opt/volumiokiosk.sh -- -nocursor
           β”œβ”€1056 xinit /etc/X11/Xsession /opt/volumiokiosk.sh -- /usr/bin/X :0 -nocursor -auth /tmp/serverauth.y7Qny0yCQv
           β”œβ”€1057 /usr/lib/xorg/Xorg :0 -nocursor -auth /tmp/serverauth.y7Qny0yCQv
           β”œβ”€1171 /usr/bin/openbox --startup /usr/lib/arm-linux-gnueabihf/openbox-autostart OPENBOX
           β”œβ”€1172 /usr/lib/chromium-browser/chromium-browser-v7 --enable-pinch --simulate-outdated-no-au=Tue, 31 Dec 2099 23:59:
           β”œβ”€1208 /usr/lib/chromium-browser/crashpad_handler --monitor-self --monitor-self-annotation=ptype=crashpad-handler --d
           β”œβ”€1210 /usr/lib/chromium-browser/crashpad_handler --no-periodic-tasks --monitor-self-annotation=ptype=crashpad-handle
           β”œβ”€1214 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --no-zygote-sandbox --force-device-scale-factor=1
           β”œβ”€1215 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --force-device-scale-factor=1 --enable-crashpad --
           β”œβ”€1217 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --force-device-scale-factor=1 --enable-crashpad --
           β”œβ”€1247 /usr/lib/chromium-browser/chromium-browser-v7 --type=utility --utility-sub-type=network.mojom.NetworkService -
           β”œβ”€1262 /usr/lib/chromium-browser/chromium-browser-v7 --type=gpu-process --field-trial-handle=15721063334234145369,943
           β”œβ”€1273 /usr/lib/chromium-browser/chromium-browser-v7 --type=utility --utility-sub-type=storage.mojom.StorageService -
           └─1287 /usr/lib/chromium-browser/chromium-browser-v7 --type=renderer --disable-breakpad --force-device-scale-factor=1
Jan 19 18:23:53 volumio startx[1033]:         Before reporting problems, check http://wiki.x.org
Jan 19 18:23:53 volumio startx[1033]:         to make sure that you have the latest version.
Jan 19 18:23:53 volumio startx[1033]: Markers: (--) probed, (**) from config file, (==) default setting,
Jan 19 18:23:53 volumio startx[1033]:         (++) from command line, (!!) notice, (II) informational,
Jan 19 18:23:53 volumio startx[1033]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jan 19 18:23:53 volumio startx[1033]: (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 19 18:23:53 2024
lines 1-30...skipping...
Jan 19 18:23:53 volumio startx[1033]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Jan 19 18:23:53 volumio startx[1033]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Jan 19 18:23:56 volumio startx[1033]: [1B blob data]
Jan 19 18:23:57 volumio startx[1033]: waiting for X server to begin accepting connections .
This is how I did it
  1. installed Volumio and β€œsimply” configured it
  • System restart
  1. installed and activated the Touch Display 3.37 plugin from the store
  • System restart
  1. changed the userconfig.txt :
    dtoverlay=vc4-kms-v3d
    dtoverlay=vc4-kms-dsi-waveshare-panel,7_9_inch,rotation=90
  • System restart
  1. peppy_screensaver_beta_1.3.9 installed and activated
sudo bash -c 'cat << EOF >  /etc/X11/xorg.conf.d/99-vc4.conf
Section "OutputClass"
    Identifier "vc4"
    MatchDriver "vc4"
    Driver "modesetting"
    Option "PrimaryGPU" "true"
EndSection
EOF'
  • System restart
Is it not a problem with date? I see every where JAN 19. The same date I was if had problem with Touch Display plugin.
Jan 19 18:53:43
Problem was solved after changing time and date.
What time is it if you put command:
date
Yes, I noticed that too.
@Franky_Byte
Seeing this I am wondering why β€œXorg.0.log” has not been found when you ran
Please post the result of
ls -al /var/log
volumio@volumio:~$ date
Thu Feb 1 10:21:05 CET 2024
volumio@volumio:~$
volumio@volumio:~$ cat /var/log/Xorg.0.log
[    42.131]
X.Org X Server 1.20.4
[    42.131] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[    42.131] Current Operating System: Linux volumio 6.1.70-v7+ #1712 SMP Tue Jan  2 18:26:39 GMT 2024 armv7l
[    42.131] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[    42.131] Build Date: 04 April 2023  07:50:56AM
[    42.131] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[    42.131] Current version of pixman: 0.36.0
[    42.131]    Before reporting problems, check http://wiki.x.org
[    42.131] Markers: (--) probed, (**) from config file, (==) default setting,
[    42.131] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 19 18:23:51 2024
[    42.165] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    42.165] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    42.174] (==) No Layout section.  Using the first Screen section.
[    42.174] (==) No screen section available. Using defaults.
[    42.174] (**) |-->Screen "Default Screen Section" (0)
[    42.174] (**) |   |-->Monitor "<default monitor>"
[    42.185] (==) No monitor specified for screen "Default Screen Section".
[    42.185] (==) Automatically adding devices
[    42.185] (==) Automatically enabling devices
[    42.185] (==) Automatically adding GPU devices
[    42.197] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    42.203] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    42.203]    Entry deleted from font path.
[    42.211] (==) FontPath set to:
        /usr/share/fonts/X11/misc,
        /usr/share/fonts/X11/Type1,
        /usr/share/fonts/X11/100dpi,
        /usr/share/fonts/X11/75dpi,
        built-ins
[    42.211] (==) ModulePath set to "/usr/lib/xorg/modules"
[    42.211] (II) The server relies on udev to provide the list of input devices.
[    42.211] (II) Loader magic: 0x1fdf80
[    42.211] (II) Module ABI versions:
[    42.211]    X.Org ANSI C Emulation: 0.4
[    42.211]    X.Org Video Driver: 24.0
[    42.211]    X.Org XInput driver : 24.1
[    42.211]    X.Org Server Extension : 10.0
[    42.214] (--) using VT number 2
[    42.215] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    42.215] (II) no primary bus or device found
[    42.215] (II) LoadModule: "glx"
[    42.242] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    42.334] (II) Module glx: vendor="X.Org Foundation"
[    42.334]    compiled for 1.20.4, module version = 1.0.0
[    42.334]    ABI class: X.Org Server Extension, version 10.0
[    42.334] (==) Matched modesetting as autoconfigured driver 0
[    42.334] (==) Matched fbdev as autoconfigured driver 1
[    42.334] (==) Assigned the driver to the xf86ConfigLayout
[    42.334] (II) LoadModule: "modesetting"
[    42.336] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    42.353] (II) Module modesetting: vendor="X.Org Foundation"
[    42.353]    compiled for 1.20.4, module version = 1.20.4
[    42.353]    Module class: X.Org Video Driver
[    42.353]    ABI class: X.Org Video Driver, version 24.0
[    42.353] (II) LoadModule: "fbdev"
[    42.353] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    42.366] (II) Module fbdev: vendor="X.Org Foundation"
[    42.366]    compiled for 1.20.3, module version = 0.5.0
[    42.366]    Module class: X.Org Video Driver
[    42.366]    ABI class: X.Org Video Driver, version 24.0
[    42.366] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    42.366] (II) FBDEV: driver for framebuffer: fbdev
[    42.369] (WW) Falling back to old probe method for modesetting
[    42.369] (EE) open /dev/dri/card0: No such file or directory
[    42.369] (WW) Falling back to old probe method for fbdev
[    42.369] (II) Loading sub module "fbdevhw"
[    42.369] (II) LoadModule: "fbdevhw"
[    42.369] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    42.380] (II) Module fbdevhw: vendor="X.Org Foundation"
[    42.380]    compiled for 1.20.4, module version = 0.0.2
[    42.380]    ABI class: X.Org Video Driver, version 24.0
[    42.380] (II) FBDEV(0): using default device
[    42.380] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    42.380] (II) FBDEV(0): Creating default Display subsection in Screen section
[    42.380] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[    42.380] (==) FBDEV(0): RGB weight 888
[    42.380] (==) FBDEV(0): Default visual is TrueColor
[    42.380] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[    42.380] (II) FBDEV(0): hardware: simple (video memory: 1200kB)
[    42.380] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[    42.380] (II) FBDEV(0): checking modes against framebuffer device...
[    42.380] (II) FBDEV(0): checking modes against monitor...
[    42.380] (II) FBDEV(0): Virtual size is 640x480 (pitch 640)
[    42.380] (**) FBDEV(0):  Built-in mode "current"
[    42.381] (==) FBDEV(0): DPI set to (96, 96)
[    42.381] (II) Loading sub module "fb"
[    42.381] (II) LoadModule: "fb"
[    42.381] (II) Loading /usr/lib/xorg/modules/libfb.so
[    42.392] (II) Module fb: vendor="X.Org Foundation"
[    42.392]    compiled for 1.20.4, module version = 1.0.0
[    42.392]    ABI class: X.Org ANSI C Emulation, version 0.4
[    42.392] (**) FBDEV(0): using shadow framebuffer
[    42.392] (II) Loading sub module "shadow"
[    42.392] (II) LoadModule: "shadow"
[    42.392] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    42.397] (II) Module shadow: vendor="X.Org Foundation"
[    42.397]    compiled for 1.20.4, module version = 1.1.0
[    42.397]    ABI class: X.Org ANSI C Emulation, version 0.4
[    42.397] (II) UnloadModule: "modesetting"
[    42.397] (II) Unloading modesetting
[    42.397] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[    42.438] (==) FBDEV(0): Backing store enabled
[    42.447] (==) FBDEV(0): DPMS enabled
[    42.459] (II) Initializing extension Generic Event Extension
[    42.460] (II) Initializing extension SHAPE
[    42.461] (II) Initializing extension MIT-SHM
[    42.462] (II) Initializing extension XInputExtension
[    42.471] (II) Initializing extension XTEST
[    42.472] (II) Initializing extension BIG-REQUESTS
[    42.473] (II) Initializing extension SYNC
[    42.474] (II) Initializing extension XKEYBOARD
[    42.475] (II) Initializing extension XC-MISC
[    42.476] (II) Initializing extension SECURITY
[    42.477] (II) Initializing extension XFIXES
[    42.478] (II) Initializing extension RENDER
[    42.479] (II) Initializing extension RANDR
[    42.481] (II) Initializing extension COMPOSITE
[    42.503] (II) Initializing extension DAMAGE
[    42.504] (II) Initializing extension MIT-SCREEN-SAVER
[    42.505] (II) Initializing extension DOUBLE-BUFFER
[    42.506] (II) Initializing extension RECORD
[    42.507] (II) Initializing extension DPMS
[    42.508] (II) Initializing extension Present
[    42.509] (II) Initializing extension DRI3
[    42.509] (II) Initializing extension X-Resource
[    42.510] (II) Initializing extension XVideo
[    42.511] (II) Initializing extension XVideo-MotionCompensation
[    42.511] (II) Initializing extension SELinux
[    42.511] (II) SELinux: Disabled on system
[    42.511] (II) Initializing extension GLX
[    42.512] (II) AIGLX: Screen 0 is not DRI2 capable
[    44.740] (II) IGLX: Loaded and initialized swrast
[    44.740] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    44.740] (II) Initializing extension XFree86-VidModeExtension
[    44.741] (II) Initializing extension XFree86-DGA
[    44.742] (II) Initializing extension XFree86-DRI
[    44.750] (II) Initializing extension DRI2
volumio@volumio:~$ ls -al /var/log
total 34
drwxr-xr-x 4 volumio adm        220 Jan 19 18:23 .
drwxr-xr-x 1 root    root      1024 Jan 19 18:14 ..
-rw-r--r-- 1 root    root      8700 Jan 19 18:23 Xorg.0.log
-rw-r--r-- 1 volumio volumio      0 Jan 19 18:23 albumart.log
-rw------- 1 root    root      5715 Jan 19 18:23 boot.log
-rw-rw---- 1 root    utmp         0 Jan 19 18:23 btmp
-rw-rw-r-- 1 root    utmp    292292 Feb  1 10:21 lastlog
-rw-r--r-- 1 root    root        60 Jan 19 18:23 mpd.log
drwx------ 2 root    root        40 Jan 19 18:23 private
drwxr-xr-x 3 root    root       180 Jan 19 18:23 samba
-rw-rw-r-- 1 root    utmp      1920 Feb  1 10:21 wtmp
volumio@volumio:~$
Since this message please check β€œsystemctl status” again with
systemctl status -l --no-pager volumio-kiosk
permitted by applicable law.
Welcome to Volumio for Raspberry Pi (6.1.69-v7+ armv7l)
volumio@volumio:~$ systemctl status -l --no-pager volumio-kiosk
   Active: failed (Result: exit-code) since Thu 2024-02-01 11:18:17 CET; 3min 20s ago
  Process: 1066 ExecStart=/usr/bin/startx /etc/X11/Xsession /opt/volumiokiosk.sh -- -nocursor (code=exited, status=1/FAILURE)
 Main PID: 1066 (code=exited, status=1/FAILURE)
Feb 01 11:18:02 volumio startx[1066]:          at http://wiki.x.org
Feb 01 11:18:02 volumio startx[1066]:  for help.
Feb 01 11:18:02 volumio startx[1066]: (EE) Please also check the log file at "/home/volumio/.local/share/xorg/Xorg.0.log" for additional information.
Feb 01 11:18:02 volumio startx[1066]: (EE) Server terminated with error (1). Closing log file.
Feb 01 11:18:17 volumio startx[1066]: xinit: giving up
Feb 01 11:18:17 volumio startx[1066]: xinit: unable to connect to X server: Cannot assign requested address
Feb 01 11:18:17 volumio startx[1066]: xinit: server error
Feb 01 11:18:17 volumio systemd[1]: volumio-kiosk.service: Main process exited, code=exited, status=1/FAILURE
Feb 01 11:18:17 volumio systemd[1]: volumio-kiosk.service: Failed with result 'exit-code'.
volumio@volumio:~$
Thanks. Please stop the Touch Display plugin. Then execute
rm /home/volumio/.Xauthority
and start the plugin again.
If this does not help remove the rotation parameter from β€œdtoverlay=vc4-kms-dsi-waveshare-panel,7_9_inch” in your β€œ/boot/userconfig.txt” and reboot.
Strange though, had the same issues but solved it with: (WS DSI 2_8 inch).
Added to userconfig.txt.
dtoverlay=vc4-kms-dsi-waveshare-panel,2_8_inch
cmdline.txt:
in front : video=DSI-1:480x640e,rotate=270
at end: fbcon=rotate:1
Then the X_Server error showed up, which got solved by running:
    Identifier "vc4"
    MatchDriver "vc4"
EndSection
EOF'
I can see from this screenshot that you tried to install the waveshare drivers…
@Darmur
Already instructed @Franky_Byte to start with a clean install due to those waveshares drivers, which fails due to kernel version ised within Volumio.
yes I know, but that screenshot is posted right after the claim that no other drivers were installed
