Browser restrictions don’t allow self starting analyzer because the audio stream has to be user initiated. Otherwise you will see hidden advertisements audio running on the webpage.
But I will check and see if I can make it work.
1.0.69 added with night time icon, language translation, and location fix. ![]()
I’m incredibly impressed by your dedication. Thank you very much. Best regards.
After activating the plugin, my music stops playing. It starts, but I can’t hear it. So I have to deactivate the plugin and then it plays again. Does anyone have the same problem?
The spectrum analyzer on radio stations works beautifully, but on Tidal and Spotify it cuts off slightly, you can show which one is responsible for this.
Send a screenshot. I don’t have subscription to those or Volumio so I will have to see.
Have you tried the latest version and rebooting the Volumio after installing it.
I always have the latest version (of course, I restart Volumio after installation)
Message was for miros
Probably too much load on your CPU ![]()
Razbery pi 5 16 GB ![]()
This plugin is indeed demanding. I have the most powerful version of the Raspberry Pi and I’ve never had this effect. Thanks for the replies. But I don’t just listen to the radio,
Can you check the CPU again after disabling Spectrum Analyzer and rebooting Volumio?
I think the background process that streams the audio for analyzer is eating CPU.
It drops to 63%, which is still a lot, but I like your weather plugin (full screen) and spectrum analyzer. Unfortunately, it doesn’t work well on TIDAL and Spotify. I like it a lot, but
Thanks to all for helping test this.
1.0.69 is now released as stable and should be available to all users.
1.0.71 BETA is out there with a new Casio 80s Theme ![]()
My dad was a geek in the 80s and had several Casio watches and calculators.
