installation in progress here
you install âby defaultâ in shellinabox ?
yep.
No, it is compiled live in a shellinabox console
tried it 3 times, all 3 same error. The primo has default drivers for HDMI, the rpi doesn;t. Hence the error on âffmpeg-nextâ I thinkâŚ
Ok, iâm going to request help from blissify-rs creator, maybe time to mark a pause in the projet c:expressionless:
Itâs a shame that I 've turned my rpi3 into pihole dns server
Maybe i took too much risk to live compile for such a projectâŚ
Thank you for your support once again
and try to install Bliss as a package, instead of compiling etc. Very time consuming. Bliss would be a great addition to this.
I did like that to ease the deployment (itâs missed) and because a 15 min compilation is neglectible before a xx hours of library analysisâŚ
yeah I did read that once I finally found blissify ![]()
Hope youâll enjoy ![]()
In any case, I believe I understand Balbuze is claiming for pre compiled blissify packages ( Iâm pretty sure itâs part of official plugins requirement)
So Iâve to work on it, one for armhf, one for rpi, one for x86 isnât it ?
yes. Currently itâs cumbersome to get Bliss installed and the average user will run into issues, which will stop users to use it. Which is a shame as the Bliss addition is that what makes this very powerfull
did you fix the rpi version so I can run it?
no, I wonât if I need to provide precompiled binaries
For you test try in the console :
cargo install --features=rpi blissify
or
. "$HOME/.cargo/env"
That would be a pitty.
Maybe when passed the beta phase, add very clear instructions how to proceed with Bliss.
i do know a thing or 2 but with the install script running, I have no clue what is going wrong.
What is your take on this @balbuze
As said before and as requested by Balbuze, I will provide precompiled binaries with an arch detection logic, I will host them on my site or elsewhere and it will transparent for final user
Ok :-), guess I misread this line.
but if you want to test using the command line above it would be my pleasure ![]()
I will, needed to create a clean image first and a backup, with a scanned lib. Otherwise it takes me 2 hours to scan my NAS.
