[PLUGIN] IR Remote Controller feedback thread
Hey @SimonE,
Formatted like this?
#!/bin/bash
# Set XAUTHORITY and DISPLAY environment variables
export XAUTHORITY=~volumio/.Xauthority
export DISPLAY=:0
# Run the xset q command to get DPMS information
output=$(xset q)
# Check each line of the output for DPMS status
if [[ $output == *"Monitor is On"* ]]; then
     echo "Monitor is ON => Turning OFF"
     xset dpms force off
     uhubctl -p 1 -a off
elif [[ $output == *"Monitor is Off"* ]]; then
     echo "Monitor is OFF => Turning ON!"
     xset dpms force on
     uhubctl -p 1 -a on
else
     echo "Unable to determine monitor status"
fi
Use in between triple back-ticks: ```
Yes, that’s it! This works to wake the USB port and Volumio recognises my DAC straight away.
When I switched from a Pi4 to a Pi5 the original uhubctl command broke. I knew the USB power setup is weird on the Pi5. This version works to wake the USB port and Volumio recognises my DAC straight away.
Ah no, sorry, that’s the old code I copied! The new (Pi5) version is:
#!/bin/bash
export DISPLAY=:0
output=$(xset q)
     xset dpms force off
     uhubctl -l 3 -a 0
     xset dpms force on
     uhubctl -l 3 -a 1
else
fi
