Today I used irrecord to generate an own configfile.
First attempt failed:
irrecord detects the “gap” and then collects data.
But the alignment to a button is not possible (after 30 trials irrecord gives up):
Something went wrong: Cannot decode data
Too many errors.
Or try using the -f option.
Unrecoverable error: Cannot decode data
Giving up
Then tried with “-f” option - this created a weird config file (which works partly) and is really different than the default file for Apple Remote.
# Please take the time to finish this file as described in
# https://sourceforge.net/p/lirc-remotes/wiki/Checklist/
# and make it available to others by sending it to
# <lirc@bartelmus.de>
# This config file was automatically generated
# using lirc-0.10.1(default) on Fri Feb 14 13:36:29 2025
# Command line used: -f -d /dev/lirc0 korell_remote_control.conf
# Kernel version (uname -r): 6.6.62-v7l+
# Remote name (as of config file): korellapple
# Brand of remote device, the thing you hold in your hand:
# Remote device model nr:
# Remote device info url:
# Does remote device has a bundled capture device e. g., a
# usb dongle? :
# For bundled USB devices: usb vendor id, product id
# and device string (use dmesg or lsusb):
# Type of device controlled
# (TV, VCR, Audio, DVD, Satellite, Cable, HTPC, ...) :
# Device(s) controlled by this remote:
begin remote
name korellapple
flags RAW_CODES|CONST_LENGTH
eps 30
aeps 100
gap 108009
begin raw_codes
name KEY_RIGHT
9087 4447 579 542 579 1646
577 1646 605 1617 579 543
575 1649 574 1650 576 1645
575 1648 571 1653 573 1650
572 549 574 550 571 549
572 550 571 1652 568 1654
568 1655 566 1657 565 555
563 558 564 558 535 584
563 559 536 587 556 565
559 564 531 1692 530 589
534 589 531 590 531 1709
529
name KEY_LEFT
9085 4447 583 540 579 1643
583 1641 580 1643 582 540
583 1642 583 1640 576 1647
579 1644 580 1643 578 1645
578 544 576 544 575 546
576 545 571 1653 573 549
565 558 567 554 570 1652
567 554 567 554 566 556
566 555 564 557 564 558
538 583 564 1659 560 563
560 560 536 587 560 1677
559
name KEY_PLAY
9094 4442 586 535 587 1638
582 1640 586 209 189 152
196 889 584 538 585 1639
583 1641 584 1640 582 1642
577 1647 584 1639 585 538
582 539 578 544 581 541
575 1648 578 544 578 1647
575 1646 575 1649 576 1647
573 549 569 1655 571 550
566 556 569 553 568 553
568 1657 562 560 562 559
566 555 563 1678 560
name KEY_MENU
9091 4449 581 540 586 1636
585 1638 584 1640 583 538
581 1641 583 1638 582 1640
585 1638 580 1639 581 1641
580 541 576 544 579 542
582 538 580 1643 575 544
582 1638 584 538 585 535
582 539 578 544 577 542
578 543 576 543 578 543
577 544 576 1644 576 546
578 544 578 544 576 1660
576
name KEY_DOWN
9083 4450 583 537 581 1643
581 1642 581 1643 578 544
555 1668 580 1644 581 1642
580 1643 583 1641 581 1644
578 542 610 512 586 537
579 543 578 1646 577 1646
575 547 611 1613 579 1645
575 546 578 544 581 541
580 543 580 542 577 544
581 542 577 1647 573 549
575 546 576 546 575 1664
572
name KEY_UP
9094 4438 589 531 592 1632
591 1632 591 1634 589 532
593 1631 589 1637 590 1632
590 1634 618 1606 591 1635
585 535 593 528 594 529
590 531 589 1634 591 1634
592 1633 592 530 591 1633
589 531 593 530 591 530
591 531 590 533 588 531
588 534 589 1635 588 534
589 533 590 531 587 1654
586
end raw_codes
end remote
Created a new directory in the user config directory and selected this as config in module.
Works “OK”.
Some inconsistancies when pressing buttons and menu triggers stop/start and stop/start triggers nothing.
At least I will try to change the raw blocks so that start/stop will work.
Warm regards,
Ralf
Nope, doesn’t work as expected.
Obviously it is no exact science to catch these IR codes…
So switching home with play/pause didn’t change anything.
It seems, play/pause button is not catched correctly.
Have just tried to record a new config but this went even worse, so I stay with the given config and given constraints therein.
Thanks so far for feedback.
Warm regards,
Ralf
Recording the IR signals and creating a new profile is exactly what I would have recommended. Too bad that the self-recorded file does not work (completely).
You could try just recording the signal of a single (not yet working) key and then modify the previously recorded file with the code for the newly recorded key.
Which steps did you follow, not want to be a smart ass, but just checking. As I did do a record yesterday for a crappy Chinese remote, which didn’t run into errors.
These 2 commands shouldn’t be necessary, but better safe then sorry:
sudo apt-get update && sudo apt-get install lirc
sudo service lirc stop
cd ~
Get the available buttons/key names: irrecord --list-namespace
Check if the remote commands are received sudo mode2 -d /dev/lirc0
Dear @gvolt , Yes - this is a nice idea - thanks for this!
Will eventually do this next weekend.
Tomorrow a BT device will arrive - will give this a try.
(The Apple Remote REALLY looks nice and smart - but the sensor hast to be visible to it - disadvantage because the pi in his final destination will be enclosed in a wardrobe.
I can imagine that BT will pass this and would be nicer.
(First try of pairing Amazon Fire Remote via BT failed as well, because I am not able to get a device dirver installed. BT remote IS connected, but I cannot find the device.
(Hope that this disappears with a BT device with an USB dongle).
Thanks anyway for your good idea and your effort.
Ralf
volumio@volumio:~$ sudo apt-get install lirc
Reading package lists... Done
Building dependency tree
Reading state information... Done
lirc is already the newest version (0.10.1-6.3~deb10u1+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Really interesting - because you’ve advised this explicitely - I’ve defintively tried to stop the lirc service (as per somewhere found working instruction as well as you here).
But the service cannot be stopped:
Failed to stop lirc.service: Unit lirc.service not loaded.
so this is the only “difference” I’ve found - but for the recording the correct environment is present - lirc service is not running anyway…
I am a new Volumio fan. And now I decided to add IR Remote to the system with Raspberry Pi 4. I checked raw output from the mode command - I have output. When I check with irw command - no output.
I saw some posts from 2020 about Apple Remote A1294 issues, and now I think situation changed and before changing all the system files I’d prefer to ask community for the recent A1294 configuration experience and necessary steps that should be provided to make it work.
I have a problem with my IR receiver on my Pi running Volumio. I have a Pi 4 and the “KY-022 Set IR Receiver Infrared Sensor Module CHQ1838” from AZDelivery. The IR Remote plugin is installed in Volumio. I’m using pins 1 (+3.3 V), 6 (GND), and 11 (GPIO17). The remote is the Apple Remote A1156. Both the A1156 and GPIO17 are selected in the plugin interface. Currently, the remote only has one working function, which is mute via the middle button (play/pause). Unmute is not possible. Where is the problem?
Control che file lircrc in the correct directory via ssh (se instructions elsewhere) anche check the following line:
begin
prog = irexec
button = KEY_PLAY
config = /usr/local/bin/volumio toggle
end
You need “toggle” in config line as you can see above (let us know what is in your string).
My complete configuration with A1156:
begin
prog = irexec
button = KEY_PLAY
end
begin
prog = irexec
button = KEY_RIGHT
config = /usr/local/bin/volumio next
end
begin
prog = irexec
button = KEY_LEFT
config = /usr/local/bin/volumio previous
end
begin
prog = irexec
button = KEY_UP
config = /usr/local/bin/volumio volume plus
end
begin
prog = irexec
button = KEY_DOWN
config = /usr/local/bin/volumio volume minus
end
Last is that you need to select A1156 alternate configuration in plugin (that worked for me)
thank you for your help. Your file is the same as the lircrc in /data/plugins/system_hardware/ir_controller/configurations/Apple Remote A1156 which seems to be loaded when “apple Remote A1156” is selected in the UI. I tried the mode2 as described in some other comments. The Result is:
[sudo] password for volumio:
Using driver default on device /dev/lirc0
Cannot initiate device /dev/lirc0
so it looks like my IR Receiver is not recognized by lirc at all. Is the Receiver not compatible with lirc? or is GPIO17 not okay to use for Lirc?
i messed it up, absolute beginner mistake. GPIO17 is used by the innomaker “Digi One” Hat i use. I had it on paper in front of me for days and messed it up. THX for all your help anyways.
So, this works fine now and i can ask about a feature i miss:
LONG PRESS does not work with lirc unless you use a python script? i Read about ir-keytable is capable of having this function? Is there a hope of changing the plugin from lirc to ir-keytable in the future?
if [[ $output == “Monitor is On” ]]; then
echo “Monitor is ON => Turning OFF”
xset dpms force off
uhubctl -p 1 -a off
elif [[ $output == “Monitor is Off” ]]; then
echo “Monitor is OFF => Turning ON!”
xset dpms force on
uhubctl -p 1 -a on
else
echo “Unable to determine monitor status”
fi
