I decided the whole Raspberry Pi thing was too complicated so I junked it and implemented my project with an Arduino ESP32.
Hi. I hope, this belongs here:
I am searching for nice looking physical buttons for controlling the volumio functions. Does anybody know where to get play/pause next&prev style buttons?
Many thanks and all the best
So do we need resistors or not?
Im running an IQaudio DAC Pro and my understanding I cant use some GPIO pins as the hat uses them, this also included the 5v and 3v line so can I still use the plugin if the hat uses the 3v?
Push-buttons connected to GPIOs can work without pull-up or pull-down resistors.
The input configuration and the internal pull-up can be enabled in /boot/userconfig.txt
You can find a lot of push buttons on Aliexpress (already tested, they are good)
Some sellers offer button customization (not tested) :
Has anyone tested the response time to the button pushes? I am thinking of using a micro to control a rotary (yes I know volumio can do this, but I need other stuff done). I would like to know how quickly I can send volume pulses to Volumio.
did you find a solution for this?
Is this still active? Where can I download the plugin?
Sadly the plug-in file gpio-buttons.zip is not available anymore.
Is here somebody who had it and can share it with me?
I had some issues with my old setup and wanted to install a fresh copy.
sudo apt-get update
sudo apt-get -y install build-essential
cd ~
wget http://plugins.volumio.org/plugins/volumio/armhf/system_controller/gpio-buttons/gpio-buttons.zip
mkdir ./gpio-buttons
miniunzip gpio-buttons.zip -d ./gpio-buttons
cd gpio-buttons
npm install --save onoff@6.0.0
volumio plugin install
cd .. && rm -R ./gpio-buttons && rm -R ./gpio-buttons.zip
Just tried, and installed succesfully.
i just retry several times and everything seems ok until the plugin failed to be active when i push the âon/offâ button of the plugin screenâŠ
Please provide more details, as I canât understand what the exact issue is.
in fact i installed button plugin by following your instructions, it work so i can see the plugin in volumio but i canât make it start, when i try it say : the plugin failled to start, please update it or contact the plugin developerâŠ
Strange,
that are the exact steps I did to make it work.
try via SSH:
cd /data/plugins/system_controller/gpio-buttons
Thank you but doesnât work, iâll try on a fresh install !
Would you share some system logs please?
The exact error might point to what happened in your case.
BTW, perfect example for the push towards proper vetted plugins in the plugin store
Users should just be able to click click and go, and not mess with commands that they might get wrongâŠ
thanks you, i tried on a fresh install and it worked great, now iâm ok with that !
Any word on when this plugin will be available in the Volumio 3 plugin store?
While streaming through Spotify Connect, when I push the Play/Pause button, it pauses correctly, but then when I push the Play/Pause button again, it starts to play the last track I played off my local NAS.
Is there a way to change this behavior?
