Overview
I’ve developed a plugin to bring FM and DAB/DAB+ radio support to Volumio 4 using affordable RTL-SDR USB dongles. The plugin enables automatic station scanning, station management, and seamless integration with Volumio’s Browse interface.
Current Status: Stable 1.3.8
This is a stable release with FM and DAB/DAB+ radio fully functional.
Features
Working (FM Radio):
  • Automatic FM station scanning with configurable sensitivity (5 levels)
  • DAB/DAB+ radio support
  • Station database with persistence across reboots
  • Browse integration with custom FM/DAB Radio tile
  • Manual frequency tuning (88.0 - 108.0 MHz)
  • Adjustable FM gain control
  • Clean station switching with proper UI updates
  • Additional language translations
  • Station naming/favorites
  • Signal strength indicators
Screenshots
The FM/DAB Radio tile appears in Volumio’s Browse page with a custom icon.
Configuration options for FM/DAB enable toggles, gain controls, and scan sensitivity.
Manual frequency entry and station scanning buttons.
23 FM stations automatically discovered and ready to play.
Hardware Requirements
Compatible RTL-SDR Dongles:
  • RTL2832U-based USB DVB-T dongles
  • R820T/R820T2 tuner chipsets recommended
  • Most generic “RTL-SDR” dongles from online retailers work
  • Tested with: Realtek RTL2832U reference designs
Tested Platforms:
  • Raspberry Pi 4
  • Raspberry Pi 5
  • x86 systems (Dell Latitude 3189 confirmed working)
NOT Compatible:
  • Raspberry Pi Zero/Zero W (insufficient CPU)
  • Systems without USB ports
  • Non-RTL2832U SDR devices
Installation
Current Status:
This plugin is in the official Volumio plugin store. Manual steps below are for the reference only.
Manual Install from GitHub:
Grab plugin from GitHub:
git clone https://github.com/volumio/volumio-plugins-sources-bookworm.git --depth=1
cd volumio-plugins-sources-bookworm/rtlsdr_radio
# Install plugin
volumio plugin install
# Restart Volumio
sudo systemctl restart volumio
First Time Setup:
  1. Navigate to: Settings > Plugins > Installed Plugins > RTL-SDR Radio
  2. Enable the plugin
  3. Configure FM Gain (default 70 works for most setups)
  4. Set FM Scan Sensitivity (start with “Balanced”)
  5. Click “Scan FM Stations” button
  6. Wait ~10 seconds for scan to complete
  7. Navigate to Browse > FM/DAB Radio to see your stations
Technical Details
Scanning Algorithm:
  • 8-hop multi-pass frequency sweep (88-108 MHz)
  • Configurable sensitivity thresholds
  • Station database saved to /data/plugins/music_service/rtlsdr_radio/
  • Automatic cleanup delay prevents hardware conflicts
Audio Pipeline:
  • rtl_fm decoder: WFM demodulation, 180k sample rate, 48k resample
  • Direct pipe to ALSA (aplay -D volumio)
  • 16-bit signed little-endian format
  • Mono channel output
Dependencies:
  • rtl-sdr package (rtl_fm binary)
  • ALSA utilities (aplay)
  • Standard Linux kernel DVB drivers
Known Limitations
  • FM Scanning takes ~20 seconds
  • DAB Scanning takes ~5 minutes
  • Station switching has ~0.7s delay (hardware limitation)
How to Report Issues:
Please post in this thread with:
  • Your hardware (Pi model, RTL-SDR dongle)
  • Volumio version
  • Issue description
  • Relevant logs
Roadmap
Phase 1 (Previous):
  • FM radio playback
  • Automatic station scanning
  • Station database persistence
Phase 2 (Current):
  • DAB/DAB+ support
  • Station naming/editing
  • Favorites system
  • Additional languages
Phase 3 (Future):
  • RDS/RBDS data display
  • Scheduled recordings
  • EPG integration (DAB)
  • Multiple tuner support
Is it possible to add RTL-SDR tuner support to receive DAB/FM? That would be a perfect match. rAudio has such a feature, maybe they’ll reveal how they did it? ;p GitHub - rern/rAudio: Raspberry Pi audio player: AirPlay, Audio CD, Bluetooth, DAB radio, DSP, Internet rafio, Multi-room, Spotify Connect, UPnP/DLNA
Hey @SO3D,
Can you start a new thread under Suggest a feature category please?
Ordered one, let’s see how it goes.
Thanks @nerd
That was a difficult childbirth, to get the files in.
HW:
lsusb
Bus 004 Device 002: ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Ow, seems we need to reboot on first install, sudo systemctl restart volumio ain’t enough.
But pressing the scan button, gives the error:
Nov 06 18:57:00 rpi5-es9038q2m kernel: rtl2832_sdr rtl2832_sdr.2.auto: Registered as swradio0
Nov 06 18:57:00 rpi5-es9038q2m kernel: rtl2832_sdr rtl2832_sdr.2.auto: Realtek RTL2832 SDR attached
Nov 06 18:57:00 rpi5-es9038q2m kernel: rtl2832_sdr rtl2832_sdr.2.auto: SDR API is still slightly experimental and functionality changes may follow
Different USB radio thingy:
lsusb
Scan:
Hey @Wheaten,
RTL-SDR device access issue…
You may this error when trying to scan FM/DAB stations:
usb_claim_interface error -6 Failed to open rtlsdr device #0
The RTL-SDR dongle was detected by the system but the plugin couldn’t access it.
Cause:
Linux automatically loads DVB-T TV tuner drivers when it detects the RTL2838 chip. These drivers “claim” the device before our plugin can use it.
Fix:
The latest version now automatically blacklists the conflicting kernel modules during installation. This prevents the DVB-T drivers from loading and allows the plugin to access the device directly.
What this means:
  • fresh installs: works automatically, no user action needed
  • existing users with this error: update the plugin and it will fix itself
  • after installation: may need to unplug/replug the RTL-SDR dongle once
Latest version available in the plugin repository with this fix included.
A bit of progress.
Playing FM station:
Playing DAB+ station:
More to come,
Do you have details of a compatible device? I feel an order coming on…
@nerd
Just tested the plugin on a HP Elitedesk, the audio quality improved dramatically vs the rPi5.
Same dongle, same antenna and position.
Signal levels are stronger and absolutely no noise.
Quick update: the RTL-SDR Radio plugin has progressed significantly and is approaching beta quality.
Major additions since alpha
DAB/DAB+ is now fully working
Complete implementation with ensemble scanning, service discovery, and proper metadata handling.
Web station manager
Menu Item
A complete interface for managing your stations at http://your-volumio:3456/manage
  • Rename stations, mark favorites, hide unwanted ones
  • Recycle bin for deleted stations
  • Edit FM frequencies
  • Search functionality
  • Works great on mobile devices too
Smart rescan
Rescanning no longer wipes your customizations - favorites, custom names, and statistics are preserved when new stations are added.
What to test
If you’d like to help test before official beta:
Current version: 0.8.2
Repository: GitHub - foonerd/volumio-plugins-sources-bookworm
Branch: RTL-SDR
Key areas needing testing:
  • DAB/DAB+ stability and reception
  • Station manager interface
  • Different RTL-SDR dongle models
  • Long-term stability
Known platform differences
@Wheaten’s testing showed x86 systems (HP Elitedesk) provide significantly better audio quality than Pi 5 with identical hardware. Something to keep in mind when choosing your platform.
What’s working well
  • FM and DAB/DAB+ reception
  • Queue system for device access
  • Comprehensive logging and diagnostics
  • Complete internationalization (ready for translations)
Installation is still manual but should reach the official plugin repository once testing confirms stability.
Feedback and bug reports welcome.
Quite a lot has changed from the original concept. You can see the journey this plugin took in readme here:
Beta version is available in the plugin’s store.
Feedback welcome.
Are you able to recommend a suitable RTL-SDR USB dongle?
I’ve used this one for testing:
RTL-SDR Device Comparison for Volumio
Device Testing Disclaimer
Anyone can purchase a device, test it with this plugin, and post their results in this forum or GitHub discussions. Community-contributed test results help other users make informed decisions. When posting test results, please include:
  • Device model and specifications
  • FM reception results (working/not working)
  • DAB+ reception results (working/not working)
  • Any driver or compatibility issues encountered
  • Raspberry Pi model used for testing
Devices confirmed working through actual testing:
  • RTL-SDR Blog V3: Tested and working (FM and DAB+)
  • NooElec models: Confirmed working by community reports
  • Generic RTL2832U with TCXO: Expected to work based on chipset
Important Warning About RTL-SDR Blog V4
DO NOT USE RTL-SDR Blog V4 with this plugin
Issues confirmed by testing:
  • Requires driver compilation from source on Debian 12
  • DAB+ does not work reliably
  • Only FM reception confirmed working
  • Not compatible with standard Volumio environment
Use RTL-SDR Blog V3 instead - works perfectly with standard drivers
Device Comparison Table
Feature RTL-SDR V3 NooElec SMArt v5 NooElec SMArt XTR Generic RTL2832U
Price (EUR) 25-28 28-32 38-42 9-18
Chipset RTL2832U RTL2832U RTL2832U RTL2832U
Tuner R820T2 R820T2 R820T2 R820T2 or R820T
TCXO Accuracy 0.5 PPM 0.5 PPM 0.5 PPM None
Bias Tee Yes No Yes No
Software Bias Tee Yes N/A Yes N/A
Case Material Aluminum Aluminum Aluminum Plastic
Connector SMA SMA SMA MCX
Frequency Range 24-1766 MHz 25-1750 MHz 25-1750 MHz 24-1766 MHz
Sample Rate 2.56 MSPS 2.56 MSPS 2.56 MSPS 2.56 MSPS
Driver Support Standard Standard Standard Standard
FM Reception Excellent Excellent Excellent Good
DAB+ Reception Excellent Excellent Excellent Poor
Plugin Compatibility Perfect Perfect Perfect Limited
Recommended For Best Choice Alternative Premium Testing Only
Detailed Specifications
RTL-SDR Blog V3 (RECOMMENDED)
Specification Value
Price 25-28 EUR
Chipset RTL2832U
Tuner Rafael Micro R820T2
Frequency Range 24 MHz - 1766 MHz
Sample Rate Up to 2.56 MSPS
ADC Resolution 8-bit
TCXO Yes, 0.5 PPM
Bias Tee Yes, software controlled
USB 2.0
Connector SMA Female
Case Aluminum, shielded
ESD Protection Yes
Volumio Compatibility Perfect - standard drivers
FM Performance Excellent
DAB+ Performance Excellent
Works with Plugin Yes, all features
Recommended YES - Primary choice
NooElec NESDR SMArt v5
Specification Value
Price 28-32 EUR
Chipset RTL2832U
Frequency Range 25 MHz - 1750 MHz
TCXO Yes, 0.5 PPM
Bias Tee No
USB 2.0
ESD Protection Yes
Recommended Yes - Good alternative
NooElec NESDR SMArt XTR
Specification Value
Price 38-42 EUR
Chipset RTL2832U
TCXO Yes, 0.5 PPM
USB 2.0
ESD Protection Yes
Extended Filtering Yes
Recommended Yes - Premium option
Generic RTL2832U Dongles
Specification Value
Price 9-18 EUR
Chipset RTL2832U
Tuner R820T2 or R820T (old)
TCXO No
Bias Tee No
USB 2.0
Connector MCX (needs adapter)
Case Plastic, minimal shielding
ESD Protection No
Volumio Compatibility Works - standard drivers
FM Performance Fair to Good
DAB+ Performance Poor - Unreliable
Works with Plugin FM only
Recommended No - Testing only
Performance Comparison
Reception Quality Ratings
Signal Type RTL-SDR V3 NooElec SMArt NooElec XTR Generic
Strong FM 5/5 5/5 5/5 4/5
Weak FM 5/5 5/5 5/5 2/5
Strong DAB+ 5/5 5/5 5/5 3/5
Weak DAB+ 4/5 4/5 5/5 1/5
Frequency Stability 5/5 5/5 5/5 1/5
Build Quality 5/5 5/5 5/5 2/5
Volumio Compatibility 5/5 5/5 5/5 5/5
Plugin Compatibility 5/5 5/5 5/5 2/5
Rating Scale:
  • 5/5 = Excellent
  • 4/5 = Very Good
  • 3/5 = Good
  • 2/5 = Poor
  • 1/5 = Very Poor / Not Working
Feature Availability
Feature RTL-SDR V3 NooElec SMArt NooElec XTR Generic
TCXO (0.5 PPM) Yes Yes Yes No
Software Bias Tee Control Yes - Yes -
SMA Connector Yes Yes Yes No (MCX)
Aluminum Case Yes Yes Yes No
Shielding Excellent Good Excellent Poor
ESD Protection Yes Yes Yes No
Extended Filtering No No Yes No
Standard Drivers Yes Yes Yes Yes
DAB+ Working Yes Yes Yes No
Cost Analysis
Initial Purchase Cost
Item RTL-SDR V3 NooElec SMArt NooElec XTR Generic
Dongle 26 EUR 30 EUR 40 EUR 14 EUR
SMA Adapter - - - 3 EUR
Total 26 EUR 30 EUR 40 EUR 17 EUR
Complete Setup Cost
Item Budget Recommended Premium
Dongle Generic (14 EUR) RTL-SDR V3 (26 EUR) NooElec XTR (40 EUR)
Antenna DIY Dipole (2 EUR) FM/DAB Combined (32 EUR) Outdoor + LNA (65 EUR)
Cables Basic (5 EUR) Quality (14 EUR) Premium (23 EUR)
Total 21 EUR 72 EUR 128 EUR
FM Quality Fair Excellent Excellent
DAB+ Quality Poor Excellent Excellent
Volumio/Debian Compatibility
Raspberry Pi Compatibility
All dongles work with all Raspberry Pi models supported by Volumio:
Pi Model USB Standard Max Current RTL-SDR V3 NooElec Generic
Pi 5 USB 3.0 1.6A Perfect Perfect OK
Pi 4 USB 3.0/2.0 1.2A Perfect Perfect OK
Pi 400 USB 3.0/2.0 1.2A Perfect Perfect OK
Pi 500 USB 3.0 1.6A Perfect Perfect OK
CM4 Via IO Board Variable Perfect Perfect OK
CM5 Via IO Board Variable Perfect Perfect OK
Pi 3B+ USB 2.0 1.2A Good Good OK
Zero 2 W USB 2.0 Limited Hub Needed Hub Needed Maybe
Power Requirements:
  • RTL-SDR Draw: ~300 mA
  • Pi 4/5 USB Port: 600 mA limit
  • Sufficient margin on all Pi 4/5 models
Driver Installation on Volumio (Debian 12)
RTL-SDR Blog V3, NooElec Models, Generic Dongles:
Standard drivers work out of box. If rtl-sdr tools not installed:
sudo apt-get update
sudo apt-get install rtl-sdr
Verify Installation:
rtl_test -t
Should show device detected without errors.
Feature Support
FM Scanning Yes Yes Yes Yes
FM Playback Yes Yes Yes Yes
DAB+ Scanning Yes Yes Yes No
DAB+ Playback Yes Yes Yes No
Station Management Yes Yes Yes Limited
Favorites Yes Yes Yes Limited
Manual Testing Yes Yes Yes Limited
Per-row Save Yes Yes Yes Yes
Software Tool Support
Tool RTL-SDR V3 NooElec SMArt NooElec XTR Generic
rtl_fm Yes Yes Yes Yes
rtl_power Yes Yes Yes Yes
dab-cmdline Yes Yes Yes No
GQRX Yes Yes Yes Yes
Frequency Stability Comparison
Dongle Type TCXO PPM Accuracy Drift/Hour Drift/Temp DAB+ Usable
RTL-SDR V3 Yes 0.5 <2 Hz Very Low Yes
NooElec SMArt Yes 0.5 <2 Hz Very Low Yes
NooElec XTR Yes 0.5 <2 Hz Very Low Yes
Generic No 100+ 50-200 Hz High No
Why TCXO Matters for DAB+:
  • FM bandwidth: 200 kHz (tolerates drift)
  • DAB+ bandwidth: 1.5 MHz (requires stability)
  • Without TCXO: Stations drift away, constant retuning needed
  • With TCXO: Stable reception, set and forget
Antenna Requirements
For FM (87.5-108 MHz)
Antenna Type Cost Indoor Outdoor Gain Performance
DIY Wire Dipole 2 EUR Maybe Yes 0dB Fair
Commercial FM 14-28 EUR Yes Yes 2dB Good
Combined FM/DAB 32-55 EUR Maybe Yes 3dB Excellent
FM Dipole Specifications:
  • Length: 1.5 meters total (75cm each arm)
  • Material: Wire or telescopic
  • Impedance: 50 or 75 ohm
  • Connection: SMA connector
For DAB+ (174-230 MHz)
Commercial DAB 23-46 EUR No Yes 4dB Good
Log-Periodic 46-92 EUR No Yes 6dB Excellent
DAB+ Dipole Specifications:
  • Length: 1.3 meters total (65cm each arm)
  • Material: Wire or elements
  • Mounting: Outdoor preferred (loft/roof)
Important: Do not use the telescopic antenna included with dongles - too short for proper reception.
Buying Recommendations
Best for Plugin Development
PRIMARY RECOMMENDATION: RTL-SDR Blog V3
Factor Rating Details
Price Excellent 26 EUR
DAB+ Performance Excellent Confirmed working
FM Performance Excellent Confirmed working
Driver Support Perfect Standard Debian drivers
Build Quality Excellent Aluminum case
Plugin Compatibility Perfect All features work
TCXO Yes 0.5 PPM
Bias Tee Yes Software controlled
Reliability Proven Years of successful use
Volumio Support Perfect Works out of box
Why RTL-SDR V3:
  • Standard driver support (no compilation)
  • DAB+ confirmed working
  • FM confirmed working
  • Best value for money
  • Proven reliability with Volumio
Premium Alternative
Price Good 40 EUR
Build Quality Excellent Premium aluminum case
TCXO Yes 0.5 PPM
Extended Filtering Yes Additional feature
Reliability Excellent High quality build
When to Choose XTR:
  • Want extended filtering for cleaner signals
  • Premium build quality desired
  • Budget allows extra 14 EUR over V3
What NOT to Buy
Device Reason to Avoid Alternative
RTL-SDR Blog V4 DAB+ not working, driver compilation required RTL-SDR Blog V3
Generic No-TCXO DAB+ unstable, frequency drift Any TCXO model
Fake/Clone Dongles Poor quality, unreliable Official brands
R820T (old tuner) Inferior to R820T2 R820T2 models
Plastic Case Only Poor shielding, noisy Aluminum case
TV Tuner Sticks Not designed for radio use Dedicated SDR
Complete Setup Recommendations
Setup 1: Best Value (Recommended for Plugin)
Item Model Cost
Dongle RTL-SDR Blog V3 26 EUR
Antenna Combined FM/DAB outdoor 32 EUR
USB Cable 1.5m shielded extension 7 EUR
Coax 5m low-loss 11 EUR
Total 76 EUR
FM Quality Excellent
DAB+ Quality Excellent
Plugin Features All working
Setup 2: Premium Performance
Item Model Cost
Dongle NooElec SMArt XTR 40 EUR
Antenna Outdoor DAB with LNA 65 EUR
USB Cable Premium extension 11 EUR
Coax 5m ultra low-loss 16 EUR
Total 132 EUR
Signal Range Maximum
Setup 3: Budget Testing
Item Model Cost
Antenna DIY wire dipole 2 EUR
USB Cable Standard (included) 0 EUR
Total 28 EUR
FM Quality Good
DAB+ Quality Fair
Note Upgrade antenna later
Where to Buy in Europe
Official Stores
Store Products Shipping Notes
rtl-sdr.com RTL-SDR Blog models Worldwide Official, guaranteed authentic
nooelec.com NooElec models Worldwide Official, high quality
amazon.de All brands Fast EU Check seller reputation
amazon.co.uk All brands UK/EU Check seller reputation
amazon.fr All brands Fast EU Check seller reputation
Buying Tips
On Amazon, Verify:
  • Seller rating: 4.5+ stars minimum
  • Product reviews: 100+ reviews
  • Reviews mention actual model name
  • No complaints about fakes or clones
  • Ships from Amazon warehouse (preferred)
Avoid:
  • Sellers with poor ratings
  • Products with no reviews
  • Suspiciously low prices (below 20 EUR)
  • Ships from unknown locations
  • “Compatible with” or “works like” claims
Signal Quality Expectations
With Different Setups
Setup FM Stations DAB+ Ensembles Notes
Generic + Included Antenna 2-5 0-1 Poor reception
Generic + DIY Dipole 5-10 0-2 Unstable DAB+
RTL-SDR V3 + Included 3-8 1-3 Limited range
RTL-SDR V3 + DIY Dipole 8-15 3-6 Decent reception
RTL-SDR V3 + Indoor Commercial 10-20 4-8 Good reception
RTL-SDR V3 + Outdoor 15-30 6-12 Very good reception
NooElec XTR + Outdoor + LNA 20-40 8-15 Excellent reception
Based on typical suburban UK/European location
Urban and rural areas will vary significantly
Interference Reduction
Common Interference Sources
Source Impact Mitigation
Raspberry Pi Moderate USB extension cable
Pi Power Supply Low-High Quality power supply
USB Devices Low Ferrite cores on cables
WiFi/Bluetooth Low Use ethernet during testing
HDMI Moderate Ferrite core on HDMI cable
Nearby Electronics Variable Test different positions
Best Practices
  1. Use USB Extension Cable (1-2 meters)
    • Moves dongle away from Pi interference
    • Allows better antenna positioning
    • Cost: 7-11 EUR
  2. Use Shielded Dongle
    • Aluminum case blocks interference
    • RTL-SDR V3 and NooElec models have this
  3. Position Antenna Properly
    • Away from Pi and electronics
    • Vertical orientation for best reception
    • Outdoor if possible
  4. Use Quality Power Supply
    • Official Raspberry Pi supply
    • 3A minimum for Pi 4/5
    • Reduces power supply noise
Testing and Verification
After Purchase
Step 1: Verify Dongle Detection
lsusb | grep RTL
Should show: Realtek Semiconductor Corp. RTL2838 DVB-T
Step 2: Test with rtl_test
rtl_test -t
Should complete without errors
Step 3: Test FM Reception
rtl_fm -f 98.8M -M wbfm -s 200k -r 48k - | aplay -r 48k -f S16_LE
Should hear FM station at 98.8 MHz
Step 4: Test with Plugin
  1. Open Volumio web interface
  2. Go to plugin settings
  3. Enable diagnostics
  4. Test FM frequency
  5. Test DAB+ ensemble
All should work with RTL-SDR V3 or NooElec models
Troubleshooting
Common Issues
Problem Likely Cause Solution
No device detected USB connection Check cable, try different port
Poor FM reception Antenna Use proper length dipole
No DAB+ stations No TCXO Buy TCXO dongle (V3 or NooElec)
Stations drift away No TCXO Buy TCXO dongle
High noise floor Interference Use USB extension, shielded case
Dropouts Weak signal Better antenna, outdoor mounting
Device resets Insufficient power Better Pi power supply
Final Recommendations Summary
For Plugin Development and Testing
PRIMARY CHOICE:
Device: RTL-SDR Blog V3
Price: 26 EUR
Buy From: rtl-sdr.com or Amazon
Reason: Perfect Volumio compatibility, proven reliability, DAB+ works
COMPLETE RECOMMENDED SETUP:
Dongle: RTL-SDR Blog V3 (26 EUR)
Antenna: Combined FM/DAB outdoor (32 EUR)
USB Extension: 1.5m shielded (7 EUR)
Coax Cable: 5m low-loss (11 EUR)
Total: 76 EUR
Result: Professional testing capability for all plugin features
PREMIUM ALTERNATIVE:
Device: NooElec NESDR SMArt XTR
Price: 40 EUR
Buy From: nooelec.com or Amazon
Reason: Extended filtering, premium build, excellent performance
Quick Reference Checklist
Before Buying
  • Chipset is RTL2832U
  • Tuner is R820T2 (not R820T)
  • Has TCXO (0.5 PPM) for DAB+
  • Aluminum case for shielding
  • SMA connector (not MCX)
  • Good seller reviews (4.5+ stars)
  • Price reasonable (not suspiciously cheap)
For Plugin Testing
  • TCXO required (DAB+ will not work without)
  • Bias Tee useful (for future LNA)
  • Proper antenna (70% of performance)
  • USB extension cable (reduce interference)
  • Quality coax cable (if outdoor antenna)
  • Compatible with all your Pi models
  • Standard Debian drivers (no compilation)
Conclusion
Best Hardware for Volumio RTL-SDR Radio Plugin:
  1. RTL-SDR Blog V3 (26 EUR) - Primary recommendation
    • Standard Debian driver support
    • DAB+ confirmed working on Volumio
    • Best value for plugin development
    • Works perfectly with Raspberry Pi
  2. NooElec NESDR SMArt XTR (40 EUR) - Premium alternative
    • Extended filtering
    • Excellent build quality
    • All plugin features working
  3. Avoid RTL-SDR Blog V4
    • DAB+ issues confirmed
    • Not suitable for Volumio use
Recommended Complete Setup: 76 EUR
  • RTL-SDR Blog V3: 26 EUR
  • Combined FM/DAB Antenna: 32 EUR
  • Quality Cables: 18 EUR
This provides reliable testing capability for all plugin features on all Raspberry Pi models running Volumio.
Prices in EUR approximate, may vary by retailer and location
Based on Volumio 4.x (Debian 12 Bookworm)
Tested on Raspberry Pi 4, 5, CM4, CM5
Phew! Thank you for your time! Will act accordingly!
Wow, thank you for the device comparison
i have to think about how to install an outdoor antenna.
could you please pin that on the top for better finding ?
Josef
v1.0.6 (Current)
  • Added sox resampling pipeline for DAB playback with automatic PCM format detection
  • Handles variable DAB sample rates (32kHz, 48kHz) transparently
  • Added EPIPE error handling for robust process pipeline management
  • Fixed station switching regression
@nerd
And he keeps on building :slight_smile:
