I don’t see any reason to remove the plugin. The only changes are the name as of V9 and the login to Logitech is removed (During initial setup). but the latter was not functional since V8.4.
Hi guys, happy to read that this plugin is still useful for some.
A couple of weeks before, I wanted to update it but my problem is that I have already a pending push request @github for another plugin, I need to discuss with balbuze and people in charge to see how to separate the two activities since I’m not confident on the fact that other plugin is acceptable for volumio
We keep in touch
PS : Do you really need to update ? LMS 8.3 works fine no ?
Well V8.5 has some new features and plugins.
Unfortunately the update is hard to ignore as it pops up on the right top menu
The plugin didn’t work for me the last 3 or 4 weeks. I installed it several times.
After installation the LMS server did not start or didn’t open port 9000
So I decided to find a workaround.
I didn’t need the LMS for music but for my Squeezebox Touch that I only use as a clock to show the time.
Without the server this clock runs aprox. 1 minute behind per day.
The Logitech Media Server plugin didn’t worked for me either. But this one (DstmMix) does
I was stupid not to look in ‘Plugin Testmode’.
Now I installed DstmMix and this works excellent.
So problem solved.
Working on the plugin now
I found a better way to install latest version and keep it up to date. Stay tuned ![]()
v1.18 update
Changelog
- fix: revised installation procedure to get latest stable LMS
- fix: revised update procedure to get latest stable LMS
- fix: revised uninstall procedure to go back as pristine as possible
Waiting your feedback…
Check LMS update status...
Downloading installation package...
--2024-06-03 19:18:24-- https://lyrion.org/lms-server-repository/latest.xml
Resolving lyrion.org (lyrion.org)... 172.67.168.211, 104.21.38.239, 2606:4700:3031::ac43:a8d3, ...
Connecting to lyrion.org (lyrion.org)|172.67.168.211|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/xml]
Saving to: '/home/volumio/logitechmediaserver/latest.xml'
/home/volumio/logitechmediaserver/latest.xml [ <=> ] 1.76K --.-KB/s in 0s
2024-06-03 19:18:25 (7.87 MB/s) - '/home/volumio/logitechmediaserver/latest.xml' saved [1807]
Latest.xml downloaded successfully
Installed version is 8.5.1
Latest version is 8.5.2
LMS will be updated to version 8.5.2 from version 8.5.1
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
FILE: https://downloads.lms-community.org/LogitechMediaServer_v8.5.2/logitechmediaserver_8.5.2_all.deb
--2024-06-03 19:18:29-- https://downloads.lms-community.org/LogitechMediaServer_v8.5.2/logitechmediaserver_8.5.2_all.deb
Resolving downloads.lms-community.org (downloads.lms-community.org)... 188.114.96.6, 188.114.97.6, 2a06:98c1:3121::6, ...
Connecting to downloads.lms-community.org (downloads.lms-community.org)|188.114.96.6|:443... connected.
Length: 60015100 (57M) [application/vnd.debian.binary-package]
Saving to: '/home/volumio/logitechmediaserver/logitechmediaserver.deb'
/home/volumio/logitechmediaserver/logitechmediaserve 100%[=====================================================================================================================>] 57.23M 20.5MB/s in 2.8s
2024-06-03 19:18:32 (20.5 MB/s) - '/home/volumio/logitechmediaserver/logitechmediaserver.deb' saved [60015100/60015100]
Installing downloaded package
dpkg: warning: files list file for package 'plymouth-themes' missing; assuming package has no files currently installed
(Reading database ... 55127 files and directories currently installed.)
Preparing to unpack .../logitechmediaserver.deb ...
Unpacking logitechmediaserver (8.5.2) over (8.5.1) ...
Setting up logitechmediaserver (8.5.2) ...
changed ownership of '/var/lib/squeezeboxserver/prefs/favorites.opml' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/persist.db' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/clientplaylist_d45d64d80859.m3u' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/log.conf' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/raopbridge.xml' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/rescan.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/cli.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/fulltext.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/infobrowser.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/dndplay.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/extensions.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/raopbridge.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/upnpbridge.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/extendedbrowsemodes.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/favorites.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/jiveextras.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/randomplay.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/localplayer.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/rssnews.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/state.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/audioscrobbler.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/datetime.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/remotelibrary.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/onlinelibrary.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin/viewtags.prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/plugin' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs/upnpbridge.xml' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/prefs' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/Plugins' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/stringcache.armv7l-linux.bin' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/audioUploads' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/InstalledPlugins' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/tmp' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/plugin-data.yaml' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/cache.db' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/artwork.db' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/library.db' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/DownloadedPlugins' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache/updates' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver/cache' from volumio:volumio to squeezeboxserver:nogroup
changed ownership of '/var/lib/squeezeboxserver' from volumio:volumio to squeezeboxserver:nogroup
Processing triggers for systemd (241-7~deb10u8) ...
Session closed.
Despite some dpkg error, update to 8.5.2 worked for me
