v1.15 update
Changelog
- fix: Better error management in case bliss tool folder doesn’t exist
- fix: wording here and here
Waiting your feedback…
v1.15 update
Changelog
Sorry, I mean uninstall DstmMix, then reboot and install it again.
I tried to do a new install yesterday and installed bliss tools first. Connection with port 10002 is still denied when I tried LMS update.
Regards/ C
Hi C
what is your machine ? is it dedicated to volumio ? other plugins installed ?
I can’t reproduce even on a fresh virtualized install
Maybe as fix I could try to move shell ports to something higher than 40000 to avoid conflict… or uninstall php and shell in a box on plugin uninstall
will see how to sustain all of this
I run Volumio 3.435 on Rpi 4, 8gb. I have some plugin installed but I don´t think they have something to do with my problem. I had DstmMix working together with my other plugins, even LMS update, until I hit the uninstall button by mistake. After reboot and new install of DstmMix it can´t connect with port 10002. Maybe there is some leftovers from first install that cause this problem.
Regards/ Claes
do you remember what version you uninstall by mistake ?
can you ssh and pass the command : sudo netstat -ap | grep :10002 ? and put the result of the command here, we will be fixed
Normally this command will close the program that occupy port 10002, then an anctivation/reinstall of the plugin should allow update command to pass
what did you post ? this is not the result of sudo netstat -ap | grep :10002 command
https://volumio.github.io/docs/User_Manual/SSH.html
Sorry my mistake. I was in a hurry.
Anyway, when I do the command you told me to run:
sudo netstat -ap | grep :10002 ,I get no result at all.
Then I did:
sudo netstat -ap grep :10002
and got this result:
\ \ \_/ |/\ \L\ \\_\ \_\ \ \_\ \/\ \/\ \/\ \ \ \/\ \L\ \
\ \___/ \ \____//\____\\ \____/\ \_\ \_\ \_\ \_\ \____/
\/__/ \/___/ \/____/ \/___/ \/_/\/_/\/_/\/_/\/___/
Free Audiophile Linux Music Player - Version 3.0
© 2015-2021 Michelangelo Guarise - Volumio Team - Volumio.org
permitted by applicable law.
Welcome to Volumio for Raspberry Pi (5.10.92-v7l+ armv7l)
Last login: Fri Mar 17 08:04:09 2023 from 192.168.50.99
volumio@volumio:~$ sudo netstat -ap grep :10002
[sudo] password for volumio:
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:3483 0.0.0.0:* LISTEN 1197/perl
tcp 0 0 0.0.0.0:44445 0.0.0.0:* LISTEN 2205/spotty-hf
tcp 0 0 0.0.0.0:49149 0.0.0.0:* LISTEN 1166/upmpdcli
tcp 0 0 0.0.0.0:microsoft-ds 0.0.0.0:* LISTEN 949/smbd
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN 1166/upmpdcli
tcp 0 0 0.0.0.0:9090 0.0.0.0:* LISTEN 1197/perl
tcp 0 0 0.0.0.0:34981 0.0.0.0:* LISTEN 1197/perl
tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 2126/shairport-sync
tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1197/perl
tcp 0 0 0.0.0.0:4200 0.0.0.0:* LISTEN 686/shellinaboxd
tcp 0 0 0.0.0.0:4713 0.0.0.0:* LISTEN 1689/pulseaudio
tcp 0 0 0.0.0.0:netbios-ssn 0.0.0.0:* LISTEN 949/smbd
tcp 0 0 localhost:11211 0.0.0.0:* LISTEN 640/memcached
tcp 0 0 0.0.0.0:43279 0.0.0.0:* LISTEN 4612/./usr/bin/voll
tcp 0 0 0.0.0.0:sunrpc 0.0.0.0:* LISTEN 1/init
tcp 0 0 0.0.0.0:webmin 0.0.0.0:* LISTEN 1216/shellinaboxd
tcp 0 0 0.0.0.0:10001 0.0.0.0:* LISTEN 1219/shellinaboxd
tcp 0 0 0.0.0.0:10005 0.0.0.0:* LISTEN 1220/php
tcp 0 0 0.0.0.0:ssh 0.0.0.0:* LISTEN 689/sshd
tcp 0 208 192.168.50.244:ssh 192.168.50.99:1628 ESTABLISHED 15052/sshd: volumio
tcp 0 0 192.168.50.244:3483 192.168.50.244:55594 ESTABLISHED 1197/perl
tcp 0 0 localhost:57350 localhost:6599 ESTABLISHED 1166/upmpdcli
tcp 0 0 localhost:35014 localhost:6600 ESTABLISHED 1015/node
tcp 0 0 localhost:36444 localhost:3000 ESTABLISHED 1015/node
tcp 0 0 192.168.50.244:47928 207.154.233.230:2222 ESTABLISHED 5573/ssh
tcp 0 0 192.168.50.244:50536 84-247-14-230.colo:http ESTABLISHED 1015/node
tcp 0 0 localhost:49972 localhost:3000 TIME_WAIT -
tcp 0 0 localhost:36258 localhost:3000 ESTABLISHED 1015/node
tcp 0 0 192.168.50.248:9090 192.168.50.248:41516 ESTABLISHED 1197/perl
tcp 0 0 localhost:36774 localhost:3000 ESTABLISHED 2493/volumiokiosk -
tcp 0 0 192.168.50.244:ssh 192.168.50.99:1599 ESTABLISHED 14976/sshd: volumio
tcp 0 0 localhost:36648 localhost:3000 ESTABLISHED 1015/node
tcp 0 0 192.168.50.244:9000 192.168.50.244:50398 TIME_WAIT -
tcp 0 0 192.168.50.244:55594 192.168.50.244:3483 ESTABLISHED 2178/squeezelite
tcp 0 0 192.168.50.244:9000 192.168.50.244:50406 TIME_WAIT -
tcp 0 0 localhost:36222 localhost:3000 ESTABLISHED 510/volumio-remote-
tcp 0 0 192.168.50.244:9000 192.168.50.244:50404 TIME_WAIT -
tcp 0 0 localhost:36616 localhost:3000 ESTABLISHED 1015/node
tcp 0 0 192.168.50.244:34382 131.160.120.34.bc:https ESTABLISHED 1015/node
tcp 0 0 localhost:36422 localhost:3000 ESTABLISHED 1015/node
tcp 0 0 192.168.50.248:9090 192.168.50.248:41508 ESTABLISHED 1197/perl
tcp 0 0 192.168.50.248:41516 192.168.50.248:9090 ESTABLISHED 1015/node
tcp 0 0 192.168.50.248:41508 192.168.50.248:9090 ESTABLISHED 1015/node
tcp 0 0 localhost:57354 localhost:6599 ESTABLISHED 1166/upmpdcli
tcp 0 0 192.168.50.244:9000 192.168.50.244:50396 TIME_WAIT -
tcp 0 0 localhost:36226 localhost:3000 ESTABLISHED 1015/node
tcp6 0 0 [::]:3005 [::]:* LISTEN 1015/node
tcp6 0 0 [::]:microsoft-ds [::]:* LISTEN 949/smbd
tcp6 0 0 [::]:8098 [::]:* LISTEN 1015/node
tcp6 0 0 [::]:4004 [::]:* LISTEN 1015/node
tcp6 0 0 [::]:37765 [::]:* LISTEN 1015/node
tcp6 0 0 [::]:6599 [::]:* LISTEN 1015/node
tcp6 0 0 [::]:5000 [::]:* LISTEN 2126/shairport-sync
tcp6 0 0 [::]:6600 [::]:* LISTEN 1/init
tcp6 0 0 [::]:4713 [::]:* LISTEN 1689/pulseaudio
tcp6 0 0 [::]:netbios-ssn [::]:* LISTEN 949/smbd
tcp6 0 0 [::]:3245 [::]:* LISTEN 1542/node
tcp6 0 0 [::]:sunrpc [::]:* LISTEN 1/init
tcp6 0 0 [::]:ssh [::]:* LISTEN 689/sshd
tcp6 0 0 [::]:3000 [::]:* LISTEN 1015/node
tcp6 0 0 [::]:3001 [::]:* LISTEN 1069/node
tcp6 0 0 localhost:6600 localhost:35014 ESTABLISHED 2132/mpd
tcp6 0 0 localhost:3000 localhost:36222 ESTABLISHED 1015/node
tcp6 0 0 localhost:3000 localhost:36648 ESTABLISHED 1015/node
tcp6 0 0 localhost:3000 localhost:36774 ESTABLISHED 1015/node
tcp6 0 0 localhost:3000 localhost:36444 ESTABLISHED 1015/node
tcp6 0 0 localhost:3000 localhost:36616 ESTABLISHED 1015/node
tcp6 0 0 localhost:6599 localhost:57354 ESTABLISHED 1015/node
tcp6 0 0 localhost:6599 localhost:57350 ESTABLISHED 1015/node
tcp6 0 0 localhost:3000 localhost:36226 ESTABLISHED 1015/node
tcp6 0 0 localhost:3000 localhost:36258 ESTABLISHED 1015/node
tcp6 0 0 localhost:3000 localhost:36422 ESTABLISHED 1015/node
udp 0 0 192.168.50.244:bootpc 0.0.0.0:* 846/dhcpcd
udp 0 0 0.0.0.0:bootpc 0.0.0.0:* 945/dhcpcd
udp 0 0 192.168.50.244:50277 0.0.0.0:* 1015/node
udp 0 0 0.0.0.0:sunrpc 0.0.0.0:* 1/init
udp 0 0 192.168.50.248:ntp 0.0.0.0:* 1005/ntpd
udp 0 0 192.168.50.244:ntp 0.0.0.0:* 1005/ntpd
udp 0 0 localhost:ntp 0.0.0.0:* 1005/ntpd
udp 0 0 0.0.0.0:ntp 0.0.0.0:* 1005/ntpd
udp 0 0 192.168.50.2:netbios-ns 0.0.0.0:* 646/nmbd
udp 0 0 0.0.0.0:netbios-ns 0.0.0.0:* 646/nmbd
udp 0 0 192.168.50.:netbios-dgm 0.0.0.0:* 646/nmbd
udp 0 0 0.0.0.0:netbios-dgm 0.0.0.0:* 646/nmbd
udp 0 0 0.0.0.0:54926 0.0.0.0:* 1197/perl
udp 0 0 192.168.50.248:50849 0.0.0.0:* 1015/node
udp 0 0 0.0.0.0:53436 0.0.0.0:* 1015/node
udp 0 0 localhost:57533 0.0.0.0:* 1166/upmpdcli
udp 0 0 0.0.0.0:49365 0.0.0.0:* 504/avahi-daemon: r
udp 0 0 0.0.0.0:mdns 0.0.0.0:* 4612/./usr/bin/voll
udp 0 0 224.0.0.251:mdns 0.0.0.0:* 2419/chromium-brows
udp 0 0 0.0.0.0:mdns 0.0.0.0:* 2205/spotty-hf
udp 0 0 0.0.0.0:mdns 0.0.0.0:* 504/avahi-daemon: r
udp 0 0 0.0.0.0:1900 0.0.0.0:* 1015/node
udp 0 0 0.0.0.0:1900 0.0.0.0:* 1197/perl
udp 0 0 192.168.50.248:1900 0.0.0.0:* 1197/perl
udp 0 0 192.168.50.244:1900 0.0.0.0:* 1197/perl
udp 0 0 0.0.0.0:1900 0.0.0.0:* 1166/upmpdcli
udp 0 0 0.0.0.0:3483 0.0.0.0:* 1197/perl
udp 0 0 0.0.0.0:50078 0.0.0.0:* 1015/node
udp 0 0 0.0.0.0:5030 0.0.0.0:* 1015/node
udp 0 0 0.0.0.0:rplay 0.0.0.0:* 1015/node
udp 0 0 0.0.0.0:57281 0.0.0.0:* 1015/node
udp 0 0 0.0.0.0:38429 0.0.0.0:* 1015/node
udp6 0 0 [::]:sunrpc [::]:* 1/init
udp6 0 0 [::]:ntp [::]:* 1005/ntpd
udp6 0 0 [::]:51381 [::]:* 504/avahi-daemon: r
udp6 0 0 [::]:mdns [::]:* 504/avahi-daemon: r
raw6 0 0 [::]:ipv6-icmp [::]:* 7 945/dhcpcd
raw6 0 0 [::]:ipv6-icmp [::]:* 7 846/dhcpcd
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 DGRAM 184599 14979/systemd /run/user/1000/systemd/notify
unix 2 [ ACC ] STREAM LISTENING 184602 14979/systemd /run/user/1000/systemd/private
unix 2 [ ACC ] STREAM LISTENING 184607 14979/systemd /run/user/1000/gnupg/S.gpg-agent.extra
unix 2 [ ACC ] STREAM LISTENING 184608 14979/systemd /run/user/1000/gnupg/S.gpg-agent.ssh
unix 2 [ ACC ] STREAM LISTENING 184609 14979/systemd /run/user/1000/gnupg/S.gpg-agent.browser
unix 2 [ ACC ] STREAM LISTENING 184610 14979/systemd /run/user/1000/bus
unix 2 [ ACC ] STREAM LISTENING 184613 14979/systemd /run/user/1000/gnupg/S.gpg-agent
unix 2 [ ACC ] STREAM LISTENING 184614 14979/systemd /run/user/1000/gnupg/S.dirmngr
unix 2 DGRAM 20788 903/winbindd /var/lib/samba/private/msg.sock/903
unix 2 [ ACC ] STREAM LISTENING 184615 14979/systemd /run/user/1000/pulse/native
unix 2 DGRAM 20813 955/smbd /var/lib/samba/private/msg.sock/955
unix 2 [ ACC ] STREAM LISTENING 37277 2331/Xorg @/tmp/.X11-unix/X0
unix 3 DGRAM 10207 1/init /run/systemd/notify
unix 2 [ ACC ] STREAM LISTENING 10210 1/init /run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 10217 1/init /run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 10227 1/init /run/systemd/journal/stdout
unix 6 DGRAM 10229 1/init /run/systemd/journal/socket
unix 21 DGRAM 11271 1/init /run/systemd/journal/dev-log
unix 2 [ ACC ] STREAM LISTENING 11279 1/init /run/systemd/fsck.progress
unix 2 [ ACC ] SEQPACKET LISTENING 11281 1/init /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 15558 1/init /run/mpd/socket
unix 2 [ ACC ] STREAM LISTENING 15563 1/init /run/thd.socket
unix 2 [ ACC ] STREAM LISTENING 15565 1/init /var/run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 15567 1/init /run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 30744 1689/pulseaudio /tmp/pulse-2L9K88eMlGn7/native
unix 2 [ ACC ] STREAM LISTENING 37278 2331/Xorg /tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 37343 2411/ssh-agent /tmp/ssh-CMc5cJH0A1US/agent.2379
unix 2 [ ACC ] STREAM LISTENING 36751 2419/chromium-brows /tmp/.org.chromium.Chromium.cRp219/SingletonSocket
unix 2 DGRAM 21855 949/smbd /var/lib/samba/private/msg.sock/949
unix 2 DGRAM 19371 951/smbd /var/lib/samba/private/msg.sock/951
unix 2 DGRAM 17172 646/nmbd /var/lib/samba/private/msg.sock/646
unix 2 DGRAM 20379 952/smbd /var/lib/samba/private/msg.sock/952
unix 2 [ ACC ] STREAM LISTENING 20793 903/winbindd /var/lib/samba/winbindd_privileged/pipe
unix 2 [ ACC ] STREAM LISTENING 18995 945/dhcpcd /var/run/dhcpcd.sock
unix 2 [ ACC ] STREAM LISTENING 18996 945/dhcpcd /var/run/dhcpcd.unpriv.sock
unix 2 DGRAM 20704 797/wpa_supplicant /var/run/wpa_supplicant/wlan0
unix 2 DGRAM 20708 797/wpa_supplicant /var/run/wpa_supplicant/p2p-dev-wlan0
unix 2 DGRAM 20380 953/winbindd: idmap /var/lib/samba/private/msg.sock/953
unix 2 DGRAM 16250 707/nmbd /var/lib/samba/private/msg.sock/707
unix 2 DGRAM 19373 954/winbindd: domai /var/lib/samba/private/msg.sock/954
unix 2 [ ACC ] STREAM LISTENING 21733 646/nmbd /var/run/samba/nmbd/unexpected
unix 3 SEQPACKET CONNECTED 36707 2419/chromium-brows @00012
unix 3 SEQPACKET CONNECTED 36705 2419/chromium-brows @00011
unix 2 DGRAM 20378 948/winbindd: domai /var/lib/samba/private/msg.sock/948
unix 2 [ ACC ] STREAM LISTENING 20792 903/winbindd /var/run/samba/winbindd/pipe
unix 2 DGRAM 184373 14976/sshd: volumio
unix 3 STREAM CONNECTED 28452 1/init /run/systemd/journal/stdout
unix 2 STREAM CONNECTED 21866 949/smbd
unix 3 STREAM CONNECTED 32465 2178/squeezelite
unix 3 DGRAM 15477 1/init
unix 3 STREAM CONNECTED 184575 14979/systemd
unix 3 STREAM CONNECTED 36756 2515/volumiokiosk -
unix 3 STREAM CONNECTED 16582 497/dbus-daemon
unix 2 DGRAM 19002 945/dhcpcd
unix 3 STREAM CONNECTED 34608 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 24815 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 2 DGRAM 16477 504/avahi-daemon: r
unix 3 STREAM CONNECTED 12162 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 183291 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 22379 1197/perl
unix 3 STREAM CONNECTED 22142 1015/node
unix 3 STREAM CONNECTED 79539 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 16583 497/dbus-daemon
unix 3 STREAM CONNECTED 23284 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 22541 1005/ntpd
unix 2 DGRAM 17171 646/nmbd
unix 3 STREAM CONNECTED 16479 523/avahi-daemon: c
unix 2 DGRAM 186583 15052/sshd: volumio
unix 3 STREAM CONNECTED 22577 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 13918 1/init /run/systemd/journal/stdout
unix 2 STREAM CONNECTED 184352 14976/sshd: volumio
unix 3 STREAM CONNECTED 28403 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 22143 1069/node
unix 2 DGRAM 21868 949/smbd
unix 3 STREAM CONNECTED 28274 1015/node
unix 2 DGRAM 19446 1005/ntpd
unix 3 STREAM CONNECTED 184027 15052/sshd: volumio
unix 2 STREAM CONNECTED 186563 15052/sshd: volumio
unix 3 STREAM CONNECTED 81504 4611/bash
unix 3 SEQPACKET CONNECTED 37485 2561/chromium-brows
unix 3 STREAM CONNECTED 36755 2419/chromium-brows
unix 3 STREAM CONNECTED 28404 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 23691 1015/node
unix 2 DGRAM 184584 14979/systemd
unix 3 STREAM CONNECTED 12271 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 19376 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 184026 15061/sshd: volumio
unix 3 STREAM CONNECTED 15810 504/avahi-daemon: r
unix 3 STREAM CONNECTED 34607 2126/shairport-sync
unix 2 DGRAM 17253 497/dbus-daemon
unix 3 STREAM CONNECTED 14692 451/rpcbind
unix 3 STREAM CONNECTED 16586 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 22395 1015/node
unix 3 STREAM CONNECTED 16621 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 79557 4612/./usr/bin/voll
unix 3 STREAM CONNECTED 16620 516/wpa_supplicant
unix 3 STREAM CONNECTED 16483 504/avahi-daemon: r
unix 3 STREAM CONNECTED 14596 448/haveged
unix 2 DGRAM 184581 14980/(sd-pam)
unix 3 STREAM CONNECTED 22396 1213/sh
unix 3 STREAM CONNECTED 22540 1005/ntpd
unix 3 STREAM CONNECTED 21874 949/smbd
unix 3 SEQPACKET CONNECTED 37486 2559/volumiokiosk -
unix 3 STREAM CONNECTED 29192 1690/rtkit-daemon
unix 2 DGRAM 186732 15111/sudo
unix 3 DGRAM 184601 14979/systemd
unix 3 STREAM CONNECTED 22397 1015/node
unix 3 STREAM CONNECTED 29053 1015/node
unix 3 STREAM CONNECTED 16478 504/avahi-daemon: r
unix 3 DGRAM 15476 1/init
unix 3 STREAM CONNECTED 79558 4612/./usr/bin/voll
unix 3 STREAM CONNECTED 22141 1015/node
unix 3 DGRAM 184600 14979/systemd
unix 3 STREAM CONNECTED 22398 1213/sh
unix 3 STREAM CONNECTED 15998 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 37459 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 39256 2419/chromium-brows
unix 3 STREAM CONNECTED 17652 686/shellinaboxd
unix 3 STREAM CONNECTED 28275 1015/node
unix 3 STREAM CONNECTED 37457 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 20804 903/winbindd
unix 3 STREAM CONNECTED 39225 2419/chromium-brows
unix 3 STREAM CONNECTED 15730 490/systemd-logind
unix 3 STREAM CONNECTED 36835 2419/chromium-brows
unix 3 STREAM CONNECTED 39257 2516/volumiokiosk -
unix 3 STREAM CONNECTED 17110 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 36838 2559/volumiokiosk -
unix 3 STREAM CONNECTED 10582 1/init /run/systemd/journal/stdout
unix 2 DGRAM 29038 1672/autossh
unix 3 STREAM CONNECTED 25060 1221/shellinaboxd
unix 2 DGRAM 7905 225/systemd-udevd
unix 3 DGRAM 7908 225/systemd-udevd
unix 3 DGRAM 7909 225/systemd-udevd
unix 3 STREAM CONNECTED 36832 2559/volumiokiosk -
unix 3 STREAM CONNECTED 7903 225/systemd-udevd
unix 3 STREAM CONNECTED 36831 2419/chromium-brows
unix 3 STREAM CONNECTED 20627 764/bluetoothd
unix 3 STREAM CONNECTED 39252 2419/chromium-brows
unix 3 STREAM CONNECTED 37455 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 39226 2496/volumiokiosk -
unix 2 DGRAM 18209 679/ifplugd
unix 3 STREAM CONNECTED 20623 1/init /run/systemd/journal/stdout
unix 2 DGRAM 14293 846/dhcpcd
unix 2 DGRAM 20684 797/wpa_supplicant
unix 3 STREAM CONNECTED 36840 2559/volumiokiosk -
unix 3 STREAM CONNECTED 39282 2493/volumiokiosk -
unix 2 DGRAM 14308 516/wpa_supplicant
unix 3 STREAM CONNECTED 36836 2559/volumiokiosk -
unix 3 STREAM CONNECTED 12264 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 39281 2516/volumiokiosk -
unix 3 STREAM CONNECTED 18324 689/sshd
unix 3 STREAM CONNECTED 20802 903/winbindd
unix 3 STREAM CONNECTED 37458 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 20803 954/winbindd: domai
unix 3 STREAM CONNECTED 25059 1219/shellinaboxd
unix 3 STREAM CONNECTED 17252 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 39253 2515/volumiokiosk -
unix 2 DGRAM 18207 679/ifplugd
unix 2 DGRAM 20625 764/bluetoothd
unix 3 STREAM CONNECTED 36841 2559/volumiokiosk -
unix 3 STREAM CONNECTED 36839 2559/volumiokiosk -
unix 3 STREAM CONNECTED 36845 2559/volumiokiosk -
unix 3 STREAM CONNECTED 37409 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 22134 1015/node
unix 3 STREAM CONNECTED 36758 2419/chromium-brows
unix 3 STREAM CONNECTED 36844 2559/volumiokiosk -
unix 3 SEQPACKET CONNECTED 36700 2454/crashpad_handl
unix 3 STREAM CONNECTED 36847 2559/volumiokiosk -
unix 3 STREAM CONNECTED 37411 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 16390 490/systemd-logind
unix 3 STREAM CONNECTED 14033 497/dbus-daemon
unix 3 STREAM CONNECTED 36743 2419/chromium-brows
unix 3 STREAM CONNECTED 14118 508/thd
unix 3 STREAM CONNECTED 36848 2559/volumiokiosk -
unix 3 STREAM CONNECTED 18508 687/shellinaboxd
unix 3 STREAM CONNECTED 16585 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 36851 2559/volumiokiosk -
unix 2 DGRAM 12275 490/systemd-logind
unix 3 STREAM CONNECTED 36850 2516/volumiokiosk -
unix 3 STREAM CONNECTED 20796 903/winbindd
unix 3 STREAM CONNECTED 18507 686/shellinaboxd
unix 3 STREAM CONNECTED 22135 1015/node
unix 3 STREAM CONNECTED 12247 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 15295 640/memcached
unix 3 STREAM CONNECTED 23787 1077/node
unix 3 STREAM CONNECTED 12267 1/init
unix 3 STREAM CONNECTED 20795 948/winbindd: domai
unix 3 STREAM CONNECTED 22139 1015/node
unix 3 STREAM CONNECTED 20801 953/winbindd: idmap
unix 3 STREAM CONNECTED 22138 1015/node
unix 3 SEQPACKET CONNECTED 36699 2419/chromium-brows
unix 3 STREAM CONNECTED 36742 2419/chromium-brows
unix 3 STREAM CONNECTED 12274 1/init /run/systemd/journal/stdout
unix 3 SEQPACKET CONNECTED 36708 2461/volumiokiosk -
unix 3 STREAM CONNECTED 16102 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 36759 2516/volumiokiosk -
unix 3 SEQPACKET CONNECTED 36703 2419/chromium-brows
unix 3 STREAM CONNECTED 20622 764/bluetoothd
unix 2 DGRAM 20790 903/winbindd
unix 3 STREAM CONNECTED 12246 481/alsactl
unix 3 STREAM CONNECTED 24814 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 15891 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 16584 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 SEQPACKET CONNECTED 36702 2419/chromium-brows
unix 3 STREAM CONNECTED 22137 1015/node
unix 3 SEQPACKET CONNECTED 36706 2460/volumiokiosk -
unix 3 STREAM CONNECTED 14881 516/wpa_supplicant
unix 3 STREAM CONNECTED 16391 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 12266 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 14802 510/volumio-remote-
unix 3 STREAM CONNECTED 35165 2132/mpd /run/mpd/socket
unix 3 STREAM CONNECTED 28579 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 33491 1015/node
unix 3 STREAM CONNECTED 77770 1015/node
unix 3 STREAM CONNECTED 39199 2419/chromium-brows
unix 3 STREAM CONNECTED 39200 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 39191 2419/chromium-brows
unix 3 DGRAM 26600 1/init
unix 3 STREAM CONNECTED 27885 1542/node
unix 3 STREAM CONNECTED 23786 1069/node
unix 3 STREAM CONNECTED 35329 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 39192 2419/chromium-brows
unix 3 STREAM CONNECTED 25649 1218/shellinaboxd
unix 3 STREAM CONNECTED 38222 2493/volumiokiosk -
unix 3 STREAM CONNECTED 37352 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 25648 1216/shellinaboxd
unix 3 DGRAM 10208 1/init
unix 3 STREAM CONNECTED 32297 1015/node
unix 3 STREAM CONNECTED 35148 2132/mpd
unix 3 STREAM CONNECTED 184603 14979/systemd
unix 3 STREAM CONNECTED 35162 2132/mpd /run/mpd/socket
unix 3 STREAM CONNECTED 38135 2419/chromium-brows
unix 3 STREAM CONNECTED 39111 2418/openbox
unix 3 STREAM CONNECTED 39219 2419/chromium-brows
unix 3 STREAM CONNECTED 33492 1015/node
unix 3 STREAM CONNECTED 38224 2493/volumiokiosk -
unix 3 STREAM CONNECTED 29052 1015/node
unix 3 STREAM CONNECTED 38225 2493/volumiokiosk -
unix 3 STREAM CONNECTED 35166 2132/mpd /run/mpd/socket
unix 3 STREAM CONNECTED 39283 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 39197 2419/chromium-brows
unix 3 STREAM CONNECTED 30762 1703/python
unix 2 DGRAM 11332 201/systemd-journal
unix 3 DGRAM 10209 1/init
unix 3 STREAM CONNECTED 39196 2419/chromium-brows
unix 3 STREAM CONNECTED 23201 1166/upmpdcli
unix 3 STREAM CONNECTED 30741 1689/pulseaudio
unix 3 STREAM CONNECTED 38299 2516/volumiokiosk -
unix 3 STREAM CONNECTED 33493 1015/node
unix 3 STREAM CONNECTED 30761 1703/python
unix 3 STREAM CONNECTED 38006 2330/xinit
unix 3 STREAM CONNECTED 39213 2493/volumiokiosk -
unix 3 STREAM CONNECTED 32298 1015/node
unix 3 STREAM CONNECTED 30742 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 38298 2496/volumiokiosk -
unix 3 STREAM CONNECTED 35955 2205/spotty-hf
unix 3 STREAM CONNECTED 24256 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 185355 14976/sshd: volumio
unix 3 SEQPACKET CONNECTED 39152 2454/crashpad_handl
unix 2 DGRAM 11372 1/init
unix 3 STREAM CONNECTED 37371 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 28418 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 38221 2493/volumiokiosk -
unix 3 STREAM CONNECTED 28376 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 37264 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 32278 2126/shairport-sync
unix 3 STREAM CONNECTED 23784 1076/node
unix 3 STREAM CONNECTED 28875 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 37407 2419/chromium-brows
unix 3 STREAM CONNECTED 32279 1/init /run/systemd/journal/stdout
unix 3 STREAM CONNECTED 185354 14999/sshd: volumio
unix 3 STREAM CONNECTED 35956 2205/spotty-hf
unix 3 STREAM CONNECTED 39212 2419/chromium-brows
unix 3 STREAM CONNECTED 38283 2419/chromium-brows
unix 3 STREAM CONNECTED 38134 2419/chromium-brows
unix 3 STREAM CONNECTED 35164 2132/mpd /run/mpd/socket
unix 3 DGRAM 26599 1/init
unix 3 STREAM CONNECTED 27884 1015/node
unix 3 STREAM CONNECTED 37280 2331/Xorg
unix 3 STREAM CONNECTED 35163 2132/mpd /run/mpd/socket
unix 2 DGRAM 30755 1689/pulseaudio
unix 3 STREAM CONNECTED 29880 1671/sh
unix 3 STREAM CONNECTED 39218 2493/volumiokiosk -
unix 3 STREAM CONNECTED 37406 2419/chromium-brows
unix 3 STREAM CONNECTED 22399 1015/node
unix 3 STREAM CONNECTED 35149 2132/mpd
unix 3 STREAM CONNECTED 30760 1703/python
unix 2 DGRAM 15574 481/alsactl
unix 3 STREAM CONNECTED 37311 2331/Xorg @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 39217 2419/chromium-brows
unix 3 STREAM CONNECTED 37370 1689/pulseaudio
unix 3 STREAM CONNECTED 35161 2132/mpd /run/mpd/socket
unix 3 STREAM CONNECTED 83163 2331/Xorg /tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 26615 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 30020 1681/sh
unix 3 STREAM CONNECTED 32299 1015/node
unix 3 STREAM CONNECTED 38280 2419/chromium-brows
unix 3 STREAM CONNECTED 36571 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 22400 1213/sh
unix 3 STREAM CONNECTED 23783 1069/node
unix 3 STREAM CONNECTED 23791 1069/node
unix 3 STREAM CONNECTED 185348 497/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 38281 2419/chromium-brows
unix 3 STREAM CONNECTED 30073 1693/polkitd
unix 3 SEQPACKET CONNECTED 39153 2458/crashpad_handl
unix 3 STREAM CONNECTED 23792 1084/node
unix 3 STREAM CONNECTED 39220 2496/volumiokiosk -
unix 3 STREAM CONNECTED 39020 2311/sh
unix 3 STREAM CONNECTED 28277 1015/node
volumio@volumio:~$
I hope it will help
Regards /C
sudo netstat -ap | grep :10002 return nothing mean that
1 - there was a problem launching shellinabox instance on port 10002
2 - there is no process that occupy poty 10002
it’s also coherent with the output of sudo netstat -ap grep :10002 you launched then
1+2 is strange since firstly “there is no reason” and secondly the following output let me think shellinabox is working at least on port 10001…
Next move if you are not discouraged is to post the out put of
shellinaboxd -t -b -p 10002 --no-beep -s '/update/:volumio:volumio:/:/bin/bash /data/plugins/music_service/dstmmix/update.sh'
VS
Hi again!
Here´s the result:
volumio@volumio:~$ shellinaboxd -t -b -p 10002 --no-beep -s ‘/update/:volumio:volumio:/:/bin/bash /data/plugins/music_service/dstmmix/update.sh’
volumio@volumio:~$ [server] Failed to find any available port!
Regards/ C
Hi again and thank you C, this is a good thing that you are not discouraged yet
can you try a different port on previous command, i.e
shellinaboxd -t -b -p 25000 --no-beep -s ‘/update/:volumio:volumio:/:/bin/bash /data/plugins/music_service/dstmmix/update.sh’
There’s something that is blocking acces to port 10002 for shellinabox
If it was a previous instance of shellinabox, you should be able to free the port with sudo netstat -ap | grep :10002 with a very explicit message like I get on my setup, but unfortunatlely this is not the case
Maybe I could try to get some help shellinabox dev to understand…
Hi again! Of course I would like to help if I can. DstmMix is a great plugin!
This is what I get:
volumio@volumio:~$ shellinaboxd -t -b -p 25000 --no-beep -s ‘/update/:volumio:volumio:/:/bin/bash /data/plugins/music_service/dstmmix/update.sh’
[config] Failed to parse command line!
This is weird. I tried LMS udate again and there was access to port 10002 again. Don´t know what will happen if I try update button again. Here is the message on port 10002
Edit: I tried update again and LMS could still access port 10002
Regards/ C
ok
I know exactly what is the last problem and I could reproduce
Coming from previous version, proprietary of the Blissanalyser folder was root and it should be volumio now, that’s why wget then find command failed
I’m going to fix this via plugin update, if you can wait, just pass the command sudo rm -r /home/volumio/Blissanalyser and retry update
Thank you for support, I wish you a great WE
v1.16 update
Changelog
Thank You!
You are doing a fantastic work with DstmMix plugin! Everything seems to work just fine now.
I´m glad that I could help but I really didn´t do anything…
Have a nice weekend!
Regards/ C
Since updating to Volumio 3.601, the DstmMix plugin shows ‘Inactive’ on every startup. I have to go into the Plugins screen and toggle the DstmMix plugin off and on to get it to start working again. Anyone else seen this behavior?
I am trying to update LMS but got the message you can see below. Any ideas?
Check LMS update status…
Installed version is 8.3.1
find: ‘LMS*’: No such file or directory
Latest version is
LMS will be updated to version
There was a problem downloading update package
process aborted, sorry for inconvenience
Session closed.
Logitech Media Server does not exist anymore. So the plugin should be removed in Volumio plugins.
But don’t worry. The system is not dead, it will go on as ‘Lyrion Media Server’.
For packages go to: Lyrion Music Server / Logitech Media Server Downloads
It took me half a day to find out how I could continue with my local LMS server.
It’s up and running now on my Volumio RPI3+
This is what I did:
Factory reset
upgraded to latest Volumio version
Via SSH:
sudo dpkg-reconfigure tzdata
sudo apt-get update
sudo apt-get install libcrypt-openssl-rsa-perl
wget https://downloads.lms-community.org/LogitechMediaServer_v8.5.0/logitechmediaserver_8.5.0_all.deb
sudo dpkg -i logitechmediaserver_8.5.0_all.deb
rm logitechmediaserver_8.5.0_all.deb
Good luck everyone
Just some small additions.
Logitech Media Server still exist till V8.5.xxxxx
The new releases V9.x.xxxx will continue ‘Lyrion Media Server’
Just a small addition if sudo dpkg -i logitechmediaserver_8.5.0_all.deb errors out on missing packages, run: sudo apt-get -fy install && sudo dpkg -i logitechmediaserver_8.5.0_all.deb
Thanks for that. The plugin is working perfectly fine. Maybe the update links can be fixed, so the official plugins can stay?
