[PLUGIN] 80s80s & 90s90s radio
Indeed during playing when I ran top the cpu load increases to about 100 %. It is reset to 7 % when the song is finished. But during 4h play no volumio hang up.
@balbuze could you pls kindly help here. I do not think it has to do with platform.
Thanks.
@Fybrox any chance you can upload your work as patch to the repo? Makes reviewing things easer :slight_smile:
Bad luck, I don’t know how to use github or how it works. I’m just a sunday handyman… Sorry.
@ashthespy could you please, when you have time, to take a look in this plugin and try to fix it :)… I will be more than happy to help you in nay how
Edit. I see that the issue has been observed also by ofiras in the post
@ofiras : could you pls share the fix
@balbuze. We need you :). Kindly pls take a look at this plugin.i guess a lot of users will apreciate this effort.
Like I said this is great plugin and the sound is quite qualitative and I use it day by day
Many thanks & regards.
Dear user,
I uploaded a new version of the plugin using files from @Fybrox !
It seems ok :wink: Thanks for your contribution
Hello Mr. Balbuze,
Kindly pls share the path in order to install it.
Not much of a contribution, just having a payid subscription and willing to test.
Regards and Sory for being… as you want to be :).
Florin.
it is available in the official plugin page :wink: but not yet for x86…(need to repair my x86 device)
I am using rpi platform on buster beta. 3.073 I will search it. Regards
for BUSTER, I didn’t check, but for sure you have to install ā€œby handsā€ :wink:
Now I have it instal with files from fybrox but still the seek value is concatenated and gets bigger and bigger. Due to this I have said maybe you have a ideea how to fix that issue.
If course I will install it by hand. Already have ins all peppymeter, mpd. oled… Etc
Like this
Sory @balbuze
But I can not find the oficial plugin page, I saw that you have modified 1h ago but I just cand find the files…
For bustet, install from https://github.com/volumio/volumio-plugins/raw/gh-pages/plugins/volumio/armhf/music_service/80s80s/80s80s.zip
@balbuze checked on 3.10 seek is oke…
only if you refresh the dev page it shows the long seek (for a second )
but the plugin works… seek bar is broken…
Hi ,
The fix is already on the message:
arithmetic sum.
  1. in file ā€œindex.jsā€ function playNextTrack , missing JSON.Parse for currentTime (twice)
  2. function getSongsResponse need to parseFloat airtime value
I will post later the all file with the fix
Thanks ofiras .
@balbuze I have the same issue . The seek value get bigger and bigger . I guess you should include the fix from ofiras from above post .The plugin is working .
Regards,
Give the corrected file and I will include it in an update
Hi ofiras,
I have just replaced the index file with this one. The seek value is still increasing…
Pls share your plugin zip file so I will install it then replace the index. Maybe in this way will work.
Nevertheless I see that is working much better
since I updated to buster i am not using this plugin anymore . so the file that I shared with you is the only left that I have from it. maybe in the future I will try to install it in this version.
I will let you know.
