The Metadata, album art, it was posible in the plugin.
How can I increase the size of the picture? I posted also in another post. I a using a 4.3 display and 60 % of the display is occupied by the 2 circles⦠Maybe make the circles little smaller and increase the album art⦠To have the album art at least 60% of the screenā¦
The volume circle is⦠Can be much smallerā¦
Thanks.
This is what I want
Yes balbuze you are wright. Sory if I annoy youā¦if it is not posible it is ok but at lease maybe in the near future we will have a UI with a bigger album art. This is what I want to see on te screen not the volume level.
It is possible that the plugin will be updated/maintained?
Curently I am listen to webradio 8080s but I am missing a lot the albumart for all the station that in that plugin⦠Thiese are one of my favorite stationsā¦
Kindly please tell me how can I install it?
I am using rpi4ā¦
The version you provided still cause a problem in volumio? If yes, I will wait for a fix
Since j am listening quite a lot 80s80s and 90s90s stations maybe in the near future it will be a posibility to reactivate the old plugin. I am missing the :
metadata with cover, artist, title, album
default station cover if no album cover available
Hello !
When this plugin started crashing Volumio, I made a small modification to solve the problem.
Replace the index.js file in the /data/plugins/music_service/80s80s/ folder of Volumio by this one : index.zip (4.8 KB)
Hello @Lintbf,
I tried to solve the blocking problem which crashes Volumio when the metadata server does not respond, for that I added a āfake-data.jsonā file to the plugin which allows it to wait 15s to restart a request . Not very elegant but functional: no more crashes.
I failed to correct āinfo: ERROR Prefetch ā¦ā and āinfo: ERROR ⦠this.currentSeek: ā¦ā which appear in Volumioās status when MPD updates playerās status. An attempted explanation would be that this plugin twists Volumioās neck by playing audio stream in āVolatileā mode while displaying metadata in āConsumeā mode using a timer to update the Frontend, a mix not very well managed by the pugin which would cause these 2 error infos.
They were originally present in the plugin and are not blocking.
The plugin is working again as before, it seems
Unzip the Files.zip archive in /data/plugins/music_service/80s80s/ and restart Volumio.
Edit, rename index_for_community.js for index.js : Files.zip (5.2 KB)
Many thanks Fybrox. This plugin I have used form the beginning z when it was not working I was so sad :(. As soon as ai reach home I will update it. I hope that @volumio dev can see your work and maybe they have time to update this great pluginā¦
For me volumio is about music. What makes so great about this plugin is the Metadata album art for every song and tbe radio channelsā¦
What do you mean by renaming the index file?
I add the new files but the numbers after seek string is increasing but after one song I think this is resetted. This is ok?
I think this is still crashes during song but after the song is finished then during the next song is still crashes because the seek string is increasing.
Thanks.
I edited the comment to update the zip where I put wrong filename for index.js, itās ok now.
I also see this āthis.currentSeek:ā which gets bigger or smaller and sometimes itās huge, itās true but itās random ā¦
I let the plugin run for hours and I did not have a Volumio crash, in case the Frontend switches to ā15s Waiting ā¦ā when the metadata server does not respond, then resumes for the next song if the server responds again. I couldnāt do better.
