I have a problem with the GUI often displaying the previous track during playback. Usually already at the second song of the playback queue it still shows the first track infos (cover, title, etc.) even though the second track is playing. The next tracks are the same, it always shows the infos of the previous song. I can correct it by restarting the song using the previous button or selecting it from the queue. But the next song will have the problem again. The seekbar seems to be generally correct, but is not correctly synced. I noticed that the song ends before the seekbar has ended, meaning that the seek bar of the next song also starts late. I tested with albums and singles of Tidal and my local collection on my NAS.
I made a log:
Summary
Starting Live Log…
info: Executing endpoint metavolumio
info: CoreCommandRouter::executeOnPlugin: metavolumio , requestToMetaVolumio
Soliciting pool server 129.70.132.36
info: CALLMETHOD: system_controller system enableLiveLog false
info: Live Log process terminated: null
Soliciting pool server 80.153.195.191
info: [ASDebug] Togle GPIO: OFF
Soliciting pool server 79.133.44.139
info: CoreCommandRouter::volumioPlay
info: CoreStateMachine::play index 18
info: CoreStateMachine::stop
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: CoreStateMachine::stPlaybackTimer
info: CorePlayQueue::getTrack 18
info: CoreStateMachine::serviceStop
info: CoreCommandRouter::serviceStop
info: [1714932425886] ControllerTidal::stop
info: CoreStateMachine::setConsumeUpdateService mpd
info: ControllerMpd::stop
info: [ASDebug] CurState: stop PrevState: pause
info: FusionDsp - volume level for loudness 27 gain applied 12.88
info: FusionDsp - If filter freq >samplerate/2 then disable it
info: FusionDsp - Loudness is ON true
info: FusionDsp - Nulleq applied
info:
---------------------------- MPD announces state update: player
info: sendMpdCommand stop took 35 milliseconds
info: ControllerMpd::getState
info: CoreStateMachine::play index undefined
info: CoreStateMachine::startPlaybackTimer
info: [1714932425924] ControllerTidal::clearAddPlayTrack
info: Getting stream with soundQuality HI_RES
info: sendMpdCommand status took 3 milliseconds
info: sendMpdCommand stop took 1 milliseconds
info:
---------------------------- MPD announces system playlist update
info: Ignoring MPD Status Update
info: sendMpdCommand playlistinfo took 6 milliseconds
info: sendMpdCommand clear took 6 milliseconds
info: ControllerMpd::pushState
info: Received update from a service different from the one supposed to be playing music. Skipping notification.Current tidal Received mpd
info: ------------------------------ 30ms
error: updateQueue error: null
info:
info: ------------------------------ 23ms
info: sendMpdCommand add “http://127.0.0.1:3245?data=tidal://song/166335358&soundQuality=HI_RES” took 18 milliseconds
STREAMING PROXY: Handling url /?data=tidal://song/166335358&soundQuality=HI_RES
info: sendMpdCommand play took 21 milliseconds
info: FusionDsp - {“Reload”:{“result”:“Ok”}}
info: Executing endpoint getStreamUrltidal
info: CoreCommandRouter::executeOnPlugin: tidal , getStreamUrlAPI
info: getStreamUrl took 298 milliseconds
STREAMING PROXY: Got real url: http://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInYmMxMDYyMDNmY2JlM2QyOWFlMzVlODNjNTM0NWJlMmNfNjIubXA0/0.flac?token=1714935844~ODliYTE4YjNjYjU3NTRhOTY1NzQ1OTViY2NhZTQ0ZjMwZjIxYjk5OA==
STREAMING PROXY: Response: 200, length: 35663645
info:
info: FusionDsp - ---- read samplerate, raw:
error: FusionDsp - invalid sample rate
info: FusionDsp - ---- read samplerate, raw: 44100,S32_LE,2,32
info: FusionDsp - ---- read samplerate from file: 44100
info:
info: sendMpdCommand status took 31 milliseconds
info: sendMpdCommand status took 2 milliseconds
info: sendMpdCommand playlistinfo took 2 milliseconds
info: CoreStateMachine::syncState stateService play
info: CoreStateMachine::syncState currentStatus stop
info: ------------------------------ 36ms
info: sendMpdCommand playlistinfo took 1 milliseconds
info: CoreStateMachine::syncState currentStatus play
info: Received an update from plugin. extracting info from payload
info: [ASDebug] CurState: play PrevState: pause
info: [ASDebug] Togle GPIO: ON
info: [ASDebug] CurState: play PrevState: play
info: touch_display: Setting screensaver timeout to 0 seconds.
STREAMING PROXY: Client dropped request, destroying
Soliciting pool server 185.13.148.71
Soliciting pool server 148.251.5.46
Soliciting pool server 45.9.61.155
Soliciting pool server 78.47.168.188
Soliciting pool server 144.76.0.164
Soliciting pool server 2001:8d8:1800:704:123:123:123:123
Soliciting pool server 116.203.219.116
Soliciting pool server 78.46.60.40
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
info: CoreCommandRouter::executeOnPlugin: metavolumio , getInfinityPlayback
info: Error : CoreCommandRouter::executeOnPlugin: No method [getMultiroom] in plugin multiroom
info: Listing playlists
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
Soliciting pool server 194.164.164.175
Soliciting pool server 2a01:4f9:c010:157::1
Soliciting pool server 144.76.138.23
Soliciting pool server 213.239.234.28
info: CorePlayQueue::getTrack 19
info: Prefetching next song
info: [1714932634259] ControllerTidal::prefetch
info:
STREAMING PROXY: Handling url /?data=tidal://song/166335359&soundQuality=HI_RES
info: sendMpdCommand add “http://127.0.0.1:3245?data=tidal://song/166335359&soundQuality=HI_RES” took 2 milliseconds
info: ------------------------------ 3ms
info: sendMpdCommand consume 1 took 1 milliseconds
info: getStreamUrl took 350 milliseconds
STREAMING PROXY: Got real url: http://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInN2NlNjE4MTNmMzkyM2E5MjljMDBkYmY5NDQ5MDRmZWJfNjIubXA0/0.flac?token=1714936234~MmNiMzI3ZjdjZDgwNDI3M2UyNmU1MjNjMTA5YzFhZTkwYTNjZGQzZg==
STREAMING PROXY: Response: 200, length: 37381017
info:
info:
info:
info:
info: ------------------------------ 14ms
info: sendMpdCommand status took 10 milliseconds
info: sendMpdCommand status took 11 milliseconds
info: sendMpdCommand playlistinfo took 3 milliseconds
info: ------------------------------ 93ms
info: sendMpdCommand playlistinfo took 70 milliseconds
info: sendMpdCommand playlistinfo took 67 milliseconds
info: ------------------------------ 198ms
info: ------------------------------ 199ms
Soliciting pool server 157.90.24.29
process exited with code null
I started by manually selecting track 18 from the queue (display is correct for the duration of this song) and let it run. Track 19 started playing after track 18, but it still showed up as Track 18.
Let me know if more information is required.
Thank you in advance!
Sven
