I’m just chiming in to ask how the work on this bug is progressing.
Currently (ver. 3.742), the UI from the web interface, Volumio app, and locally connected displays always runs into the issue, and is repeatable on different RPi4 devices.
Playback source doesn’t make a difference. Albums / playlists stored on the SD card, connected devices, or streaming services like Tidal are all affected, constantly ending up out of sync.
I know it’s 2 days since the last update. I moved from a perfectly functioning roon system to volumio as its slightly cheaper. But this bug is driving me NUTS.
I agree that’s it’s a paid for service and while some bugs are to be expected this should be one that’s has been ironed out ages ago. Please guys can we at least get an estimated time frame when an update will be released that this will be solved.
Thank you very much, the problem seems to be solved!
The track and playback location displayed are now correct even after more than 24 hours with the latest version Volumio 3.745.
Hey, great news. Is 3.745 a beta or development version for the upcoming update? I’m still on 3.742, and 3.745 isn’t available from the update function yet.
Yes, it is a beta
You can get this as an update by activating the test mode.
Please remember that these are beta versions and therefore there may be problems!
So far I haven’t encountered any problems with version 3.745 - it works great!
