have a problem with the usb X10 rf remote with spotify connect2 plugin, the problem is that as soon as you press play/pause the stream stops but as soon as you press play/pause again spotify does not continue but starts playing with the web radio.
after play/pause Spotify you can play the next or previous spotify song, that will work again.
tried in standard volumio2 software and volumio buster beta, same problem in both.
I’m using triggerhappy and using a custom audio.conf that is in the location “/etc/triggerhappy/triggers.d”
Hi all,
this is my first post so i hope you will be kind with me
This issue is still part of volumio 3 (volumio toggle not working for play command). Can anybody confirm whether the fix mentioned by ash is still working with this version or is there any other fix for this (i don’t want to break my system)? I was hoping that there will be a fix integrated by volumio directly because if you attach this solution to your system it gets removed after every system update.
For the future i am planning to use an irremote for controlling volumio and since am using spotify connect a lot this is an important issue for me (and maybe for others, too).
volumio version: v3.173
spotify connect plugin: v3.0.7
raspberry pi 4
USB DAC
I can confirm that the code is still working with volumio v3. After manually changing index.js and statemachine.js the volumio toggle command is working with spotify connect as expected.
But, it seems that the changes are breaking some other services because now i am not able to start playing anything through mpd (like webradio, spotify plugin). If you try that volumio will make a reboot.
