Great job, congratulations! It would be nice to have 1920x720 resolution, otherwise the other resolutions don’t work for me. Thank you very much.
I did something in 2023. Check it out
Create a folder named e.g. 1920x720-Gelo5 and place the graphics and meters.txt there
We could add them to the available in the plugin ![]()
Thanks @Gelo5. Are these you suggested for the normal Peppymeter or the basic Peppymeter? Because I liked the meters without metadata. Sorry, my question may be trivial.
Sarebbe magnifico ![]()
Full Peppymeter,
but it works with Basic, just no metadata ![]()
PS. Tell me which skin you like, and I’ll try to make something in my free time. Then @balbuze will add to Basic skins ![]()
Sorry for the delay in replying, I would like to see 1600x720. Thank you very much
But they are already available for the plugin!
Update the list If needed and install.
Excuse me, are they already available in 1920x720 format? Because I need this format.
Not clear…
But not available in your res yet…
Yes, my English with the translator sucks. However, I need 1920x720 for Peppymeter Basic. That’s all.
Uploading: Screenshot_20250825_215205_Chrome.jpg…
These, if possible, are 1920x720. I hope I was clear about my poor English. ![]()
Unfortunately, these are @balbuze skins. Only he can do this. My skins - click my avatar
Yes, my friend, I already have yours for Peppymeter. In fact, I was contacting @balbuze e for his vumeters in 1920x720 format. Thanks anyway for your help.
I started to make them… Should be ok by the end of the week.
But you can create your own! Just have a look on the other to see how it is made ![]()
Thanks, I’ll try to make them following a guide
wonderful, you’re great, thank you so much for your availability. ![]()
Hi! I’d like using the Peppymeter Basic for my RPi 4 with Volumio 3.816. I installed plugin (Peppymeter Basic 0.0.3), and Touch Display 3.5.1. I temporarily connected my LCD tv’s HDMI input to RPI’s HDMI outputs. One of the HDMI outputs does not send any signal, while the other shows a black screen but displays the resolution and frame rate. I set the resolution to match the TV resolution in the Peppymeter Basic plugin and selected several different Meter types, set all of different parameters in Toch Display plugin’s menu, but nothing significant happened. Is it possible that this plugins only works with the RPi display port, or am I doing something wrong? Thanks for help! Sincerely:Istvan from Hungary
