Volumio Information
Volumio Version: 2.779
Hardware: rpi4B+2GB
DAC: none
Hi All,
I see a few references to the /var/www/css/panel.css file… but there is no /var/www/ folder on my volumio installation.
Am I missing something?
If not, which file do I need to edit to be able to change font sizes? I want to try the suggestion from this post: volumio small screen tweak
Your are referring to very old instructions for Volumio <2
I figured as much
I have been playing around with the /volumio/http/www/styles/app-##########.css file, but it seems I have only succeeded in changing the browser font-size, not the font-size on the 3.5" screen that I have.
Is there any place I can find instructions/docs that would give me an idea on Volumio > 2 edits?
