Older Volumio Versions
Where can I get an older Volumio version?
The Hifiberry Digi2 Pro just doesn’t work on Volumio 3 whatsoever.
from under the " Volumio 3 does not work for me yet, some things I need are still missing."
Hi you can find this versions here:
Older volumio versions .img files - #51 by rumloser
Keep in mind that support of Version 2 ends.
Well, they should fix Volumio 3 then. It still has too many bugs and just doesn’t work with a lot of DACs and Digi boards
“a lot of” does not say much, please name them and I’ll add an item to the issue list.
