I am on a free account. I decided to factory reset my Volumio installation on my Raspberry Pi4. My original installation had become completely unresponsive because my library is so large.
I used the factory reset button in System. Volumio took awhile to mount my NAS, but it did, finally. Now am on version 3.616. Netwoek connection is wired at static IP address.
I previously was able to access plug-ins but I cannot now. My plug-in page says I need to log into MyVolumio. I in fact am logged into MyVolumio, but the device table now is empty.
I have logged in and out repeatedly and have restarted the device several times. Is there something else that I should do? I tried to upload a log file using the tech support form, but it does not seem to be going through. I have looked at other posts here, but most have suggested SSH access and, honestly, I wouldn’t know what to do once I enabled that capability.
I factory reset again. This time, although I can’t activate my Volumio device in my account, I do have access to the plug-ins, which is what I wanted to accomplish.
Hello everybody,
I had the same problem (resolved) with my raspberry 3 B+ since i decided yesterday to recycle it as a volumio player mainly to use it with Qobuz/Qobuz connect/some plugins.
The reason why myvolumio premium account was disconnecting itself from the raspberry was because i was trying to set the ip adress of the raspberry manually in Volumio ! (i did 3 successive installation of Volumio, i tried each time).
As soon as IP adressing was set to automatic, connection to myvolumio was coming back + all the additionnal functions in volumio (Plugins, Qobuz, etc).
Manual IP config was also giving bugs with webradio (radioparadise) that couldn’t reach the stream.
Hope this will help ! Cheers !
