Hi all. Brand new to streaming, and I thought I’d start with Volumio and a Modi 3. My stuff:
Schiit Vali 2 headphone amp
Schiit Modi 3 DAC
Raspberry Pi Zero W
I have installed the latest version of Volumio and inserted the SD card into the Pi. Went through the initial startup fine, except that:
My only choices for music output were HDMI with I2S off, or a list of DACs with I2S on but the Modi was not found there.
No option for selecting musical input, but I also don’t have a server. I’m not a computer guy, don’t want to go into all that. I was intending on using the Volumio to stream internet radio easily.
Anyway. Got it set up, selected a radio station through the Volumio UI, and a lotta nothing.
Changed cables. Checked internet connection (65Mbps down.) Volumio tells me my internet radio to streaming to me at 48 Kbps, but what’s weird is the “timer” on the bottom of the UI doesn’t advance in real time. It stays at one or two, until I move on to tinker with something else in the UI. I go back to the radio, and the timer jumps forward. Still no sound.
I’ve tried most every I2S on the list. Nothing. HDMI doesn’t work, and that’s the only choice I get for non-I2S output. Dunno what’s going on, I’d appreciate guidance. Thank you!
Essentially there is no quick and easy way to get sound out of a Pi Zero W
If you Pi has the header pins it might be easier to fit a i2S digi hat - something like - DollaTek HIFI DiGi+ Digital Sound Card I2S SPDIF Optical Fiber RCA for Raspberry Pi
If you don’t have the header pins on your Pi Zero you might think about an upgrade to a PI 3 then you can use the USB out direct into your Modi - good luck.
Yes, but if you don’t see it as an available choice (you see only HDMI) it means that the DAC is not properly recognized by Volumio, hence my 2 suggestions
WARNING!!! Some remote endpoints cannot be reached!
Failing endpoints:
https://google.com, 5725 ms
https://www.googleapis.com, 5725 ms
https://securetoken.googleapis.com, 5725 ms
https://myvolumio.firebaseio.com, 5725 ms
https://functions.volumio.cloud, 5725 ms
https://oauth-performer.dfs.volumio.org, 5725 ms
https://browsing-performer.dfs.volumio.org, 5725 ms
http://cddb.volumio.org, 5725 ms
http://pushupdates.volumio.org, 5725 ms
http://plugins.volumio.org, 5725 ms
https://database.volumio.cloud, 5725 ms
https://radio-directory.firebaseapp.com, 5725 ms
after trying to connect to internet it all crashes not reaching all end points.
