PI 3B and Digi Pro
I am getting no audio from the DIGI Pro after upgrading to 3.631. I have tried both its Optical and S/PDIF Outputs without success. The PI is definitely connected to the Internet Radio station I tested with as it provides the ‘now playing’ info to my display. Is it possible that V’s 3.631 config.txt and the addition of volumioconfig.txt are causing the problem, the combination is very different to my previous settings?
### DO NOT EDIT THIS FILE ###
initramfs volumio.initrd
gpu_mem=128
gpu_mem_256=32
gpu_mem_512=32
gpu_mem_1024=128
max_usb_current=1
[pi5]
usb_max_current_enable=1
[all]
include volumioconfig.txt
include userconfig.txt
dtoverlay=hifiberry-digi-pro
volumioconfig.tx
[cm4]
dtoverlay=dwc2,dr_mode=host
[pi5]
dtoverlay=vc4-kms-v3d-pi5
[all]
arm_64bit=0
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
force_eeprom_read=0
userconfig.txt has not changed.
dtoverlay=disable-bt
enable_uart=1
Thanks again. I think the DAC is OK as it plays my CDs OK.
I did wonder if the HiFiBerry DIGI Pro was to blame but as this and the PI are installed in my Integrated Amp I was hoping for non-invasive solution !
Swapped to PI4B but it is not appearing on my network. Perhaps the original IP address has been overwritten? This is going to take a bit longer…
Is it possible to edit the SD card IP info if I remove it and use WinSCP?
Removed the PI4 from Amp and assembled and powered outside.
Correctly linked to network. I think the short ribbon SD connector I have been using has failed with all the diss-assembly /assembly.
However my PI4B DIGI Pro+ still not working, alsa error and same wm8804 read error in the log.
Not sure where to try now? Which board needs to be replaced, or is it both !
I think you are right.
I replaced the DIGI Pro with an older DIGI + and no alsa error.
Lashed up an optical lead to my DAC and Amp and it played Internet Radio !
Looks like I need a new DIGI board, are there any better ones than HiFiBerry Digi2 Pro?
Better for Audio quality and still compatible with a PI4B
Checking the HiFiBerry website they have had an issue with PI4s and early DIGI PRO2 boards and now make a revised version. Perhaps my swapping around was never going to identify the problem.
