Thanks Michelangelo, the plugin is works beautifully.
I comment is if you don’t reboot after installing and setting up the new plugin, the first time you start a spotify playlist, it jumps from one track to the next. The happened on two my devices, and a reboot fixed it.
Running volumio 3.251 (free) on rpi3 + Iqaudio , wired and wireless connection. Spotify Family Account
I am having an issue when playing using a playlist , the system will randomly jump to next song or several songs forward.
pi 4 with latest volumio installed
Rpi 3b+ with Audiophonics RaspDAC Mini
Volumio version 3.301
Payed Volumio account
Premium Spotify
Plugin works as expected, except for the already mentioned ‘random’ progression when selecting next track in a playlist. Btw, this also happens in other services, like Qobuz.
Trying this on a fresh install pi zero w and no other plugins installed. Walked through the initial setup and tried to install the plugin.
Where I get stuck in the process is this line: “Status :Downloading plugin
nloading plugin at http://127.0.0.1:3000/plugin-serve/spop.zip”
And logs show this:
Jun 19 16:03:53 pirateaudio sudo[1005]: volumio : TTY=pts/1 ; PWD=/home/volumio/volumio-plugins-sources/spotify ; USER=root ; COMMAND=/usr/local/bin/volumio plugin install
Jun 19 16:03:53 pirateaudio sudo[1005]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Jun 19 16:04:03 pirateaudio volumio[884]: …++++
Jun 19 16:04:03 pirateaudio volumio[884]: e is 65537 (0x010001)
Jun 19 16:04:03 pirateaudio volumio[884]: writing RSA key
Jun 19 16:06:06 pirateaudio volumio[689]: verbose: New Socket.io Connection to 127.0.0.1:3000 from 127.0.0.1 UA: node-XMLHttpRequest Total Clients: 5
Jun 19 16:06:07 pirateaudio volumio[689]: verbose: New Socket.io Connection to 127.0.0.1:3000 from 127.0.0.1 UA: node-XMLHttpRequest Total Clients: 6
Jun 19 16:06:08 pirateaudio volumio[689]: info: Downloading plugin at http://127.0.0.1:3000/plugin-serve/spop.zip
Jun 19 16:06:08 pirateaudio volumio[689]: info: Cannot download file http://127.0.0.1:3000/plugin-serve/spop.zip - Error: Command failed: /bin/mv /tmp/plugins/spop.zip /tmp/downloaded_plugin.zip
Jun 19 16:06:08 pirateaudio volumio[689]: /bin/mv: cannot move ‘/tmp/plugins/spop.zip’ to ‘/tmp/downloaded_plugin.zip’: Permission denied
Jun 19 16:06:08 pirateaudio volumio[689]: info: Error: Error: Error: Command failed: /bin/mv /tmp/plugins/spop.zip /tmp/downloaded_plugin.zip
^Z
[1]+ Stopped sudo journalctl -f
I tried to take ownership with “sudo chmod 0777 /tmp” but no luck.
Pirateaudio is the hostname that I have the player set to because I do have the hat attached(Pirateaudio.local). Password is still default.
Edit: Out of curiosity I changed the hostname back to the default of volumio, rebooted, and ran into the same issue.
Asus Tinkerboard
V3.301
Topping D50s usb DAC
Wired LAN
Volumio Free
Spotify Premium Family
The Spotify track does not start playing.
Live log: info: CorePlayQueue::getTrack 42 info: CoreStateMachine::startPlaybackTimer info: CorePlayQueue::getTrack 42 info: [1655668807241] ControllerSpotify::clearAddPlayTrack info: Setting this device active info: Failed to Set Device Active: Error: Not Found
When I try to seek:
“Spotify Connect API Error.
Not Found”
Live Log: info: CoreCommandRouter::volumioSeek info: CoreStateMachine::seek info: CorePlayQueue::getTrack 42 info: TRACKBLOCK {“uri”:“spotify:track:4PqVvCR2pHNhxlFGVVMuAy”,“service”:“spop”,“name”:“The Desert Rocks”,“artist”:“Chris Huelsbeck”,“album”:“Turrican Soundtrack Anthology, Vol. 2”,“type”:“song”,“duration”:237,“albumart”:“https://i.scdn.co/image/ab67616d0000b27389860ac08730e3461aa4dcd4",“samplerate”:"320 kbps”,“bitdepth”:“16 bit”,“bitrate”:"",“trackType”:“spotify”} info: CoreStateMachine::startPlaybackTimer info: CorePlayQueue::getTrack 42 info: Spotify seek to: 187000 info: CoreStateMachine::pushState info: CorePlayQueue::getTrack 42 info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo info: CoreCommandRouter::volumioPushState [SpotifyConnect] Not Found
One remark:
When you report an issue, please send the log just after the problem occurs and paste the log link here. Otherwise we have no clue on how to solve it.
Here’s the log for my issue. I did a fresh install, ran through setup leaving everything default, enabled SSH, and installed per instructions at the top of the post. http://logs.volumio.org/volumio/19zGfv5.html
4 pcs. Model: Raspberry Pi 3 Model B Rev 1.2
Version of Volumio: 3.301
Kernel: 5.10.92-v7+
Connection both Wireless +Wired
Volumio Free; Spotify Premium
I have a problem. I have 4 pcs.
Rasp PI with the new versions of Volumio. I can’t play all four Spotify volumio players at the same time. I downloaded each of my playlists from spotify. As soon as I started playing on the next one the previous one stops playing from Spotify. When you press play it starts jumping through the songs in the playlist. The sound button also jumps itself, then louder then quieter.
But when only one player from Spotify is playing everything is fine.
