I was wondering if there is a way not to change Spotify volume when I change it on Volumio?
As you can see in this video , when I change volume from Volumio (hardware), it also changes it in Spotify (software), which is weird and not the same… (btw if I change the volume in Spotify, it doesn’t change Volumio’s volume)
spotify just randomly stops playing for the last few days but keeps going but no sound so had to reconnect to get sound.
new sdflash.
Peppy meter installed.
edit: still having issues spotify stops intermittently, new clearer log.
volumio version: 3.422
spotify: 3.0.7
raspberry pi 4b.
dac: philips 1543 nos dac.
Hi I am using the spotify plugin and I noticed that after I logout from the spotify account, I cannot login again. After some investigation on the log, I realised that in the config file volspotify,toml, the username and password are encapsulated in “” which causes it be incorrect. Upon removing the “”, everything becomes fine again.
So maybe the developer wants to make this small change in the next release.
I have some issues with Spotify. When i start the first song after booting using Spotify App on android it plays fine but any other song i want to select, its being paused almost instantly. When i go to Volumio app it does the same thing until i select a different song and then it will play again, but also sometimes it will select a song i didnt pick. See log below:
Spotify works perfectly well on my Volumio but only for a short time then it loses its log in credentials. If I log out and in again it will once again work but only for hours or a few days, never for weeks. It is so annoying that I’m under intense domestic pressure to ditch Volumio for something else - and I’d rather not. Any ideas?
Same volume-reseting-problems here on the latest version using spotify connect controlling the volume within Spotify. But for me the volume does not reset at the next song, but the moment the volume pop up disappears.
I’m facing the exactly same issue as direwolf08 has described. (on a Raspberry PI)
Aso the log locks the same - when it spotify stops playing is shows “[Vollibrespot] : SessionError: Connection reset by peer (os error 104)”.
It is the same error when I play via spotify connect or in the UI. And I tried it with wired connection too.
(But I don’t believe that it is because of the network - the youtube plugin works fine and has no connection issue.)
I’m on the Version 3.0.7 but tried it also with version 3.0.4 etc.
I very much like this approach to stream Spotify on a small device headless - but is is really disappointing each time when it stops. I also shared a log with the Volumio Support, but they pointed me to this forum as the plugin is 3rd party.
So any help is very much appreciated!
I am running version 3.423, with Spotify plugin 3.0.7. What I experience is the following: when I click on a song in a list in Spotify (e.g. in a list of search results), the plugin starts playing the NEXT song, and I can never start the very first. Any clue from anybody why this is happening? Otherwise seems working, with some inconveniences, like when I pause a song for a longer period, cannot continue it, have to start another one, but I can live with that.
