What was your issue and how did you get it sorted?
This info is helpful
Hi all boys
after a few days of use, I encountered this problem which I had not noticed.
By changing the volume, it changes in a crazy way, as you can see in the linked video
video: https://youtube.com/shorts/6kzkhJVUCMY?feature=share
Thanks everyone for their feedbacks. The plugin is being currently fixed and already addressed issues are:
Use different workaround for not found tracks
Avoid token expiration for control actions
Fix crash if name contains hyphens
Working on improving volume control.
Hopefully, new release this week
Hello everyone, just finished a 5 days trial of the new plugin on 3 pi zero w and 2 pi zero 2 w; I connected directly my spotify account in volumio page and used the raspberrys like player! I think there is a big problem here: when you play the music spotify doesnât count the listenings, I know that because Iâm also a producer and on my artist page of spotify for artist I can see daily how many plays of my music people performs on spotify.
This is nothing that we can take care of: we use the official Spotify APIs to play, so itâs the same as using their client. My educated guess is that the listen count is not updated daily.
GOOD NEWS! Iâve managed to put a lot of work into the Spotify plugin, and solved quite a lot of issues reported by you guys.
As always, thanks for the feedbacks and reports. This time it has been especially helpful since Spotify has some geo-related issues which are not obvious to fix.
This is what has been improved in the latest version (3.0.3)
Fixed funny behaviour of volume control
Fixed conflicts between browsing mode and connect mode
Do not play unavailable tracks in region
Fix potential conflict with old plugin version settings
The plugin is now released, so feel free to enjoy! And, if there are more issues, please report them here.
IMPORTANT! Remember to provide infos when you report an issue. We need to know
- Explain the issue with the most details
- Tell us your system (PI etc), DAC, Volumio version
- IMPORTANT: Send the log How to send a log link for a bug report? and paste link here (just after the issue occurs)
ENJOY!
Since today my spotify stopped working. I can connect with the volumio trough spotify connect, but it plays the first four seconds of the song. Then skips to the next song. No sound. Happens with analog out aswell
What changed?
Update your plugin to latest version released today
First time test looks good
Unfortunately i am currently bad sick and totally off power - could please someone test switching between UI and connect feature.
It has been working for me at home - but not in the company office - where especially the âfunnyâ volume bug has been not so funny as the CEO came in while our device switched to 96% volume and that was pretty loudâŚ
Home system tested:
PI3
Allo Isolator
Allo Katana
Office System:
PI3
Allo Reclocker
Allo Piano 2.1 in dual Mono Mode
No - still not solved
After playing a few songs - it suddenly begins to skip songs after 2 seconds again.
http://logs.volumio.org/volumio/aU2xQDZ.html
After pausing and wait for some minutes itâs working again as expected - but that should not be the way ?
Also the âfunnyâ volume control came back.
I will test with a fresh installed other device as soon as i get back to be healthy
H!
When will this update be available for the miniDSP OEM version of Volumio?
Wait for if it is working - i guess that Spotify has to fix things also
New version 3.0.3: On a Spotify playlist, when using ârepeat allâ it just plays the same song over and over. (Yes I know there is a ârepeat 1â and it is not set to this)
Pi Version 3, DAC is Allo BOSS, Volumio version 3.301
Log: http://logs.volumio.org/volumio/iBCTyyZ.html
It should be noted that on the previous version of the plugin, this was not an issue. I have it set to run continuously 24/7. Sometimes it would stop and get stuck on a song but Iâve never had this issue.
Also am not able to skip forward, it just starts the same track over.
Hello to All
Today I installed the spotifyplugin from the store.
I first removed the beta plugin
Now I am testing the updated plugin form the store comparing to the beta plugin.
Plugin version used: 3.0.3
In New Volumio Spotify Plugin Open Beta-Testing - #181 by fredhohenstein I told that the plugin didn;t play spotify tracks.
I hoped that this nwe plugin solvved this problem.
Problem:
But no, the problem still exists: I can browse/select spotity tracks but thay are not played when i start them.
Nothing happens, no sound. It looks like the playback isnât started and in the debug session in putty: volumio@volumio:~$ sudo journalctl -f
I still see the messages:
Jul 14 06:42:44 volumio volumio[655]: info: [1657780964253] ControllerSpotify::clearAddPlayTrack
Jul 14 06:42:44 volumio volumio[655]: info: Setting this device active
Jul 14 06:42:44 volumio volumio[655]: info: Failed to Set Device Active: Error: Not Found
Jul 14 06:42:51 volumio volumio[655]: info: CoreCommandRouter::volumioGetState
I can browse through spotify and select a song.
When i start playing the song nothing happens/no sound!
I double checked Volumio:
Playing tracks from my qnap nas: no problem
Listing to webreadio: no problem
rebooted the system several times: problem still exists
switch off/switch on system: problem still exists
Host: Raspberry PI4
Volumio 3.312 Virtuoso membership
Version of Volumio: 3.312
Hostname: volumio
Kernel: 5.10.92-v7l+
Governor: performance
Uptime: 0 days, 0 Hrs, 11 Minutes, 59 Seconds
DAC: Hifiberry DAC+ RCA
Hw audio configured: HiFiBerry DAC Plus
Mixer type: Hardware
Number of channels: 2
Spotify Premium - familiy contract
I installed the plugin from the spotify plugin store
Plugin is getting improved, great progress, but found a few things:
System Information:
- rPi4-8GB
- Allo Digione
- NAD D3045
- Volumio V3.251
Steps:
- Removed previous Spotify plugin (V3.02)
- Restarted system
- Installed V3.03
Volume settings:
Found issues:
Cosmetics:
- After login to Spotify, Screen is not refreshed. Need to reload page to get it updated
- When making changes to Initial Volume, hitting the save button doesnât generate any message. Page seems unresponsive, however changes are stored
- In V3.02 there was a button, seems to be missing in V3.03
technical:
- Repeat all (green round arrow) acts as repeat single
- When interrupting Spotify connect within Volumio by loading a new list, song wonât start. After a few hits on Play/Pause it starts again.
- Skipping tracks happens randomly.
info: CoreStateMachine::syncState stateService stop
info: CoreStateMachine::syncState currentStatus play
info: CoreStateMachine::play index undefined
info: CorePlayQueue::getTrack 2
info: CoreStateMachine::startPlaybackTimer
info: [1657787078761] ControllerSpotify::clearAddPlayTrack
[SpotifyConnect] Device palyback is inactive
info: touch_display: Setting screensaver timeout to 120 seconds.
[Vollibrespot] : Fetching autoplay context uri
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track }, track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track } }
[Vollibrespot] : error 400 for uri hm://autoplay-enabled/query?uri=
[Vollibrespot] : AutoplayError: MercuryError
info: touch_display: Using Xserver unix domain socket /tmp/.X11-unix/X0
[Vollibrespot] : Event: SinkActive
[Vollibrespot] : Event: Next { track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track } }
[SpotifyConnect] Self Esteem
info: [1657787079107] ControllerSpotify::pushState
info: CoreStateMachine::syncState currentStatus stop
info: No code
[SpotifyConnect] Sink acquired
info: Continuing Spotify Session
info: Checking Spotify Web API
[Vollibrespot] : Event: SinkInactive
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track } }
info: [1657787079185] ControllerSpotify::pushState
[SpotifyConnect] Sink released
info: [1657787079190] ControllerSpotify::pushState
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track }, track_id: SpotifyId { id: 295246024522152435297779322183121786258, audio_type: Track } }
info: CorePlayQueue::getTrack 3
info: [1657787079216] ControllerSpotify::clearAddPlayTrack
[Vollibrespot] : Loading with Spotify URI
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 295246024522152435297779322183121786258, audio_type: Track } }
[Vollibrespot] : (181533 ms) loaded
[SpotifyConnect] Basket Case
info: touch_display: Setting screensaver timeout to 0 seconds.
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 295246024522152435297779322183121786258, audio_type: Track }, track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track } }
info: [1657787079670] ControllerSpotify::pushState
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track } }
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track }, track_id: SpotifyId { id: 73295774072209172946745029855206367861, audio_type: Track } }
info: [1657787079998] ControllerSpotify::pushState
info: CorePlayQueue::getTrack 4
info: [1657787080007] ControllerSpotify::clearAddPlayTrack
[Vollibrespot] : (257826 ms) loaded
[Vollibrespot] : (215906 ms) loaded
info: Is Not Connect Playback
info: [1657787080106] ControllerSpotify::pushState
info: No code
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 73295774072209172946745029855206367861, audio_type: Track } }
[SpotifyConnect] Scar Tissue
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 73295774072209172946745029855206367861, audio_type: Track }, track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track } }
info: [1657787080777] ControllerSpotify::pushState
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 72787414551552412743303113338438041855, audio_type: Track }, track_id: SpotifyId { id: 119047454566201459263048238731580377631, audio_type: Track } }
info: No code
info: [1657787080816] ControllerSpotify::pushState
info: No code
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 119047454566201459263048238731580377631, audio_type: Track } }
[SpotifyConnect] Zombie
[Vollibrespot] : (306440 ms) loaded
info: [1657787081055] ControllerSpotify::pushState
info: [1657787081656] ControllerSpotify::pushState
- When skipping tracks has occurred, Spotify stops after playing a single track
http://logs.volumio.org/volumio/CfZlCxX.html
Question:
- When playing a list from the Volumio Spotify integration, is it normal that Volumio keeps sending information to the Spotify application on my iPhone, even after reopening the application and rebooting the system?
Solved:
- Playing a loaded playlist after reboot skipping tracks every 2 seconds
- Skipping songs while switching between Spotify integration and Spotify connect, vise versa
Yes, this implementation relies heavily on the âConnectâ functionality. So Spotify is always in control of your playback sessions. Volumio now is merely acting as a client.
PS: The fact that you have a volume slider in the configuration page does not make much sense to me. Probably you still have the old settings in place. Would you mind uninstalling then reinstalling the plugin and report if it makes any difference to you?
If thatâs the case, I have to account for this leftover settings
Thanks guys for the feedbacks.
This plugin is a very hard nut to crack, since the vollibrespot event system is quite unpredictable (plus, Volumio was not designed to accommodate standard and volatile playback in a single plugin).
I will work on it until is perfect, will not be quick but we will get there.
Already did it 4 times, so now for the 5th, with all taken steps:
- Uninstalled V3.03
- Shut down the system
- Pulled the power plug
- Restarted the system
- Installed V3.03
- Enabled plugin
- Entered credentials
- Reloaded the page
Tried to run the same test on my 2nd rPi4-8GB, rev1.4, but Volumio wonât register it, so the plugin section is unavailable (Superstar)
What is your volume setting? Software or none?
