a new setup v 3.611 (raspberry pi 4b) after going through the setup, dac (hifiberry dac+ pro) FusionDSP installed, everything plays normally (LEDs “clock” indicate this on an Ian Canada FifoPi MA reclocker) no sound after a reboot (LEDs “clock” indicate this on an ian canada FifoPi MA reclocker)
After a power down, only 1 LED turns on “play” on the reclocker, The i2s LEDs no longer turn on.
Even if I do a factory reset from the interface, I can’t get it right anymore.
Tried version 3.546, everything okay, no problem.
log for the reboot.
http://logs.volumio.org/volumio/sQfXy1o.html
log after the reboot.
http://logs.volumio.org/volumio/K2ynnb7.html
I also see a difference in config file, dtoverlay “slave” vs old no “slave”
also saw this one passing by
