New Config w/RPi 4 & Allo Digi
Volumio 3 Issues?
Haven’t used Volumio in several years. Downloaded and installed newest RPi 4 O/S. With new old OS, things were beginning to work. Switched to new OS and cannot get past “searching for new device.” Tried going back to old of OS, but cannot get beyond “searching……” screen. PS, .using iPhone 13 for control
Hey @wanders,
Can you confirm that you have completed initial setup as advised? Especially part related to WiFi configuration?
Got it installed, thanks for helping.
Quick question, in setting-up L2S, is the DAC location Allo Digione or the actual DAC, Soekris dam 1941?
Thx
Hey @wanders,
Interesting question. Allo DigiOne uses snd-rpi-wm8804 module. As such, would conform to linkage from soc → bcm → wm8804 codec. However I think that with L2S you are interested in ethernet part or USB networked data. Without dam 1941 schematics, hard to tell.
