New 2023 Spotify Plugin
Sorry for the delay, we have released Spotify Plugin version 4.3.0 with a bunch of improvements.
Regarding Spotify Lossless, we want to support it ASAP, but we need to either wait for Italy release or find a way to start testing it now. We’ll keep you posted :wink:
Stange!
I tried to install vers 4.3.0. Uninstall 4.2.2, restart and new install but only 4.2.2 is available.
I’m on rpi 5 and Volumio 4.022
http://logs.volumio.org/volumio/fz911A1.html
regards/ C
Did you try to uninstall the old one first? That did the trick for me.
You could try to use a VPN in a country that already supports it, like the Netherlands, though I’m not 100% sure that would work since I don’t know if this restriction is user-based or region-based. I found via Perplexity that Italy will be rolled out between now and the end of October.
I would not advise VPN’s, as Spotify might block you account.
Yes, I did!
regards C
Plugin builds for Volumio 4 are handled separately.
@balbuze
Thanks!
Good to know!
regards C
We should release it also for Volumio4. on my todo list :wink:
Hello ,
Does Spotify connect supports hires ?
Read below info
done! :wink:
I thought that is released in al countries …
No, they are rolling it out in stages. I’m in Sweden where it has been released, but still waiting for it to be available.
Same here în România … I did no see any mark to see if the song is hi res …
In the spotify app (phone) it shows only lossless. But you need to configure the app for it.
Ia there an icon which show this like in Qobuz ? How do o now that is lossless ? I have to see for example 24 bits or something like this …
Combine these screenshots with my previous message.
I guess în România the app does not show
Not sure if lossless has been rolled out in Romania, you do have a Spotify Premium subscription?
