Hi @Jorge_Daetz,
(1) first of all you have to install some depencies:
Open a terminal and enter:
sudo apt-get update
sudo apt-get install python-rpi.gpio python-spidev python-pip python-pil python-numpy
sudo pip install st7789
(2) second you have to put some lines in /boot/config.txt, open a terminal and enter:
sudo nano /boot/config.txt
and add following lines
####### needed for Amp Hat ####
dtparam=spi=on
gpio=25=op,dh
####### Fix for Button X Y ####
gpio=16=pu
gpio=20=pu
and reboot.
(3) Now create a python file with my modified code:
#!/usr/bin/env python
import time
from colorsys import hsv_to_rgb
from PIL import ImageFont, Image, ImageDraw, ImageStat
import os
import os.path
from os import path
import ST7789 as ST7789
from socketIO_client import SocketIO, LoggingNamespace
import requests
from io import BytesIO
from numpy import mean
import sys
import logging
# logging.getLogger('socketIO-client').setLevel(logging.DEBUG)
# logging.basicConfig()
import signal
import RPi.GPIO as GPIO
# get the path of the script
# script_path = os.path.dirname(os.path.abspath( __file__ ))
script_path = os.path.dirname(os.path.abspath(__file__))
# set script path as current directory
os.chdir(script_path)
def on_connect():
print('connect')
def on_disconnect():
print('disconnect')
img = Image.new('RGBA', (240, 240), color=(0, 0, 0, 25))
img = Image.open('/volumio/app/plugins/miscellanea/albumart/default.jpg')
img = img.resize((WIDTH, HEIGHT))
draw = ImageDraw.Draw(img, 'RGBA')
draw.text((10, 200), 'shuting down ...', font=font_m, fill=(255, 255, 255))
disp.display(img)
def on_push_state(*args):
global status
global service
status = args[0]['status'].encode('ascii', 'ignore')
service = args[0]['service'].encode('ascii', 'ignore')
# Load albumcover or radio cover
albumart = args[0]['albumart'].encode('ascii', 'ignore')
if len(albumart) == 0: # to catch a empty field on start
albumart = 'http://localhost:3000/albumart'
if 'http:' not in albumart:
albumart = 'http://localhost:3000'+args[0]['albumart']
response = requests.get(albumart)
img = Image.open(BytesIO(response.content))
# Light / Dark Symbols an bars, depending on background
im_stat = ImageStat.Stat(img)
im_mean = im_stat.mean
mn = mean(im_mean)
txt_col = (255, 255, 255)
# bar_col = (255, 255, 255, 255)
bar_bgcol = (200, 200, 200)
bar_col = (255, 255, 255)
dark = False
if mn > 175:
txt_col = (55, 55, 55)
dark = True
# bar_col = (100, 100, 100, 225)
bar_bgcol = (255, 255, 255)
bar_col = (100, 100, 100)
if mn < 80:
txt_col = (200, 200, 200)
# paste button symbol overlay in light/dark mode
if status == 'play':
if dark is False:
img.paste(pause_icons, (0, 0), pause_icons)
else:
img.paste(pause_icons_dark, (0, 0), pause_icons_dark)
else:
if dark is False:
img.paste(play_icons, (0, 0), play_icons)
else:
img.paste(play_icons_dark, (0, 0), play_icons_dark)
top = 7
if 'artist' in args[0]:
x1 = 20
w1, y1 = draw.textsize(args[0]['artist'], font_m)
x1 = x1-20
if x1 < (WIDTH - w1 - 20):
x1 = 0
if w1 <= WIDTH:
x1 = (WIDTH - w1)//2
draw.text((x1, top), args[0]['artist'], font=font_m, fill=txt_col)
top = 35
if 'album' in args[0]:
if args[0]['album'] is not None:
x2 = 20
w2, y2 = draw.textsize(args[0]['album'], font_s)
x2 = x2-20
if x2 < (WIDTH - w2 - 20):
x2 = 0
if w2 <= WIDTH:
x2 = (WIDTH - w2)//2
draw.text((x2, top), args[0]['album'], font=font_s, fill=txt_col)
if 'title' in args[0]:
x3 = 20
w3, y3 = draw.textsize(args[0]['title'], font_l)
x3 = x3-20
if x3 < (WIDTH - w3 - 20):
x3 = 0
if w3 <= WIDTH:
x3 = (WIDTH - w3)//2
# thin border
# shadowcolor = "black"
# draw.text((x3-1, 105), args[0]['title'], font=font_l,
# fill=shadowcolor)
# draw.text((x3+1, 105), args[0]['title'], font=font_l,
# fill=shadowcolor)
# draw.text((x3, 105-1), args[0]['title'], font=font_l,
# fill=shadowcolor)
# draw.text((x3, 105+1), args[0]['title'], font=font_l,
# fill=shadowcolor)
draw.text((x3, 105), args[0]['title'], font=font_l, fill=txt_col) # fill by mean
# volume bar
vol_x = int((float(args[0]['volume'])/100)*(WIDTH - 33))
# draw.rectangle((5, 184, WIDTH-34, 184+8), (255, 255, 255, 145))
draw.rectangle((5, 184, WIDTH-34, 184+8), bar_bgcol) # background
draw.rectangle((5, 184, vol_x, 184+8), bar_col)
# time bar
if 'duration' in args[0]:
duration = args[0]['duration'] # seconds
if duration != 0:
if 'seek' in args[0]:
seek = args[0]['seek'] # time elapsed seconds
if seek != 0:
el_time = int(float(args[0]['seek'])/1000)
du_time = int(float(args[0]['duration']))
dur_x = int((float(el_time)/float(du_time))*(WIDTH-10))
# draw.rectangle((5, 222, WIDTH-5, 222 + 12), (255, 255, 255, 145))
draw.rectangle((5, 222, WIDTH-5, 222 + 12), bar_bgcol) # background
draw.rectangle((5, 222, dur_x, 222 + 12), bar_col)
# Draw the image on the display hardware
disp.display(img)
socketIO = SocketIO('localhost', 3000)
socketIO.on('connect', on_connect)
# Create ST7789 LCD display class.
disp = ST7789.ST7789(
rotation=90, # Needed to display the right way up on Pirate Audio
port=0, # SPI port
cs=1, # SPI port Chip-select channel
dc=9, # BCM pin used for data/command
backlight=13,
spi_speed_hz=80 * 1000 * 1000
# Initialize display.
disp.begin()
WIDTH = 240
HEIGHT = 240
font_s = ImageFont.truetype(script_path + '/fonts/Roboto-Medium.ttf', 20)
font_m = ImageFont.truetype(script_path + '/fonts/Roboto-Medium.ttf', 24)
font_l = ImageFont.truetype(script_path + '/fonts/Roboto-Medium.ttf', 30)
play_icons = Image.open('images/controls-play.png').resize((240, 240))
play_icons_dark = Image.open('images/controls-play-dark.png').resize((240, 240))
pause_icons = Image.open('images/controls-pause.png').resize((240, 240))
pause_icons_dark = Image.open('images/controls-pause-dark.png').resize((240, 240))
# vol_icons = Image.open(script_path + '/images/controls-vol.png').resize((240,240), resample=Image.LANCZOS).convert("RGBA")
# vol_icons_dark = Image.open(script_path + '/images/controls-vol-dark.png').resize((240,240), resample=Image.LANCZOS).convert("RGBA")
# bt_back = Image.open(script_path + '/images/bta.png').resize((240,240), resample=Image.LANCZOS).convert("RGBA")
# ap_back = Image.open(script_path + '/images/airplay.png').resize((240,240), resample=Image.LANCZOS).convert("RGBA")
# jp_back = Image.open(script_path + '/images/jack.png').resize((240,240), resample=Image.LANCZOS).convert("RGBA")
# sp_back = Image.open(script_path + '/images/spotify.png').resize((240,240), resample=Image.LANCZOS).convert("RGBA")
# sq_back = Image.open(script_path + '/images/squeeze.png').resize((240,240), resample=Image.LANCZOS).convert("RGBA")
# 100
# BUTTONS = [5, 6, 16, 20]
BUTTONS = [16]
LABELS = ['A', 'B', 'X', 'Y']
# Set up RPi.GPIO with the "BCM" numbering scheme
GPIO.setmode(GPIO.BCM)
# Buttons connect to ground when pressed, so we should set them up
# with a "PULL UP", which weakly pulls the input signal to 3.3V.
GPIO.setup(BUTTONS, GPIO.IN, pull_up_down=GPIO.PUD_UP)
def handle_button(pin):
label = LABELS[BUTTONS.index(pin)]
print("Button press detected on pin: {} label: {}".format(pin, label))
if pin == 5:
# print('Play/pause')
print(status, service)
if (status == 'play') and (service == 'webradio'):
socketIO.emit('stop')
elif (status == 'play'):
socketIO.emit('pause')
else:
socketIO.emit('play')
if pin == 6:
print('volDown')
socketIO.emit('volume', '-')
if pin == 16:
print('initalisiere Shutdown')
on_disconnect()
os.system("sudo shutdown -h now")
sys.exit()
if pin == 20:
print('volUp')
socketIO.emit('volume', '+')
# 100
def main():
while True:
print ('def main angesprochen')
# 100
for pin in BUTTONS:
GPIO.add_event_detect(pin, GPIO.FALLING, handle_button, bouncetime=100)
# 100
disp.set_backlight(True)
# mit socket verbinden
socketIO.on('pushState', on_push_state)
# get initial state
socketIO.emit('getState', '', on_push_state)
socketIO.wait()
# socketIO.wait_for_callbacks(seconds=1)
# time.sleep(1)
time.sleep(0.01)
if __name__ == '__main__':
try:
main()
except KeyboardInterrupt:
img = Image.new('RGB', (240, 240), color=(0, 0, 0))
draw = ImageDraw.Draw(img)
draw.rectangle((0, 0, 240, 240), (0, 0, 0))
disp.display(img)
disp.set_backlight(False)
pass
The amp and the buttons should work with starting volumio (and GPIO Button Plugin).
(4) The display can be startet as follows, open a terminal and enter:
python /pathtoyourfile/file.py
Now the display should work or you should get at least an error message in your terminal.
If everything works, you can put the python file in autostart to execute it while booting.
Regards
AxLED
Fettgedruckter Text
