After my first streamer project:
Here we here with a new high-end streamer project.
At the moment the case is late because I decided to completely change the style, but I’ll show you my first idea here…
The concept is based on a dual integration hi-fi form factor case/cabinet. In the bigest there is the streamer, in the second a very high quality DAC
I decided to use an x86 minipc, an audio grade low noise linear power supply, a large touch display and a crazy 200mm fan that was very quiet (only 10dB)
These components were selected after my own extensive testing:
-Mele Quiter HD3 Q (Celeron 5105 - 8Gb - 256Gb + 1Tb SSD)
-SMSL DO300 (DAC)
-Noctua NP-A20 PWM (Fan)
-Audio grade linear low noise powe supply 12V 120W
-Touch Display 8,8" or 12,6" wide screen (impact on the final design)
In high load work condiction (100% CUP - 10,4 Watt), after 3 hours CPU Core test registred about 87°C on the CPU without fan, with 27°C in the room. That “insane” Fan reduce the temperature of the CPU more than 13°C, considering that CPU is tested by Intel over 105°C. The fan introduce zero noise!
Please, let me know your opinion and observations
wide
