I have an 8 TB HDD in a USB 3.0 cradle, that I use as my library. I have 127K songs on the disc. I am trying Volumio but it can only find 90K files. All the files were either ripped (CD’s or SACD’s converted to *.DSF files) or purchased (high res). When I used JRiver 28, it found every file and even Daphile finds over 120K files.
The HDD is NTFS, which I have had no problems with on smaller drives with Volumio. I have reset the system several times to try and fix this but to no avail.
My system is: A MinisForum HM90 mini-PC with a Ryzen 9 - 9500H CPU, 16 GB RAM and a 512 GB SSD for Volumio (I know overkill), the USB 3.0 Cradle is Thermaltake BlacX Duet cradle. My DAC is a TEAC UD-501.
Can you conform that the import keeps stalling at the same entry?
If you hit the update again, will the import go beyond Paul Carrack Live - The Independent Years, Vol. 1 (2000-2020) (2020) [FLAC@44.1KHz24bit]/02 - Sunny (Live at Buxton Opera House, 2004).flac
I think we need the peeps from Volumio to dig in further. The error seems related to MPD.
But you’re at the Z now, so prob. one more hit on the update and all files are in.
Still did you do anything to the WLAN setup, as the errors are occupying 30% of the logfile?
Apr 11 18:34:10 volumio hostapd[13097]: hostapd_free_hapd_data: Interface wlan0 wasn't started
Apr 11 18:34:10 volumio systemd[1]: hostapd.service: Control process exited, code=exited, status=1/FAILURE
Apr 11 18:34:10 volumio systemd[1]: hostapd.service: Failed with result 'exit-code'.
Apr 11 18:34:10 volumio systemd[1]: Failed to start Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator.
So, I went back in and looked at the mpd.conf and that line didn’t change, so I redid it, making sure I followed EXACTLY the steps you listed. I am currently rescanning the HDD. I will let you know.
I actually logged in directly to volumio on the mini-PC (nice to have extra KB and monitor) to do this.
So, I have done the steps exactly as you have them. It does not save the change to the buffer size. This is the 4th time I have done this, with the same results.
