IR Remote plugin after last update is not working
Hello
I have updated the volumio to the latest one after I have done system reset. IR plugin is not working anymore. Is there any help?
Thank you
Odoslané z HUAWEI M2-A01L pomocou Tapatalku
Tried to reinstal the SD Card with latest version, result is the same. does not work… :blush:
Please describe how and from which source (from the plugin store (UI) or from a .zip file) you are installing the plugin. If you are installing the plugin from a .zip file: Where and how did you download it?
Also: How far do you get?
Does the installation of the plugin finish?
Are you able to enable the plugin?
Do you get any error messages? If so, when do they appear and what are they saying?
To get a little more information you could also login to volumio via ssh and execute
sudo journalctl -f
Then watch the messages in the moment you try to install and/or enable the plugin. Copy the log entries related to the plugin and post them here. :slight_smile:
LIRC broken since the upgrade to kernel 4.19.55
reason:
old module was:
dtoverlay=lirc-rpi
new module is:
dtoverlay=gpio-ir
Installing from Volumio menu.
Yes, I am able to activate the plugin 8n menu, also set up the right IR controller.
So it is because of new kernel, do you have idea, when this will be fixed?
Thanks for answers, guys!
In another post I ask about the same topic, the remote doesn’t work after updating Volumio. In my case I install the control manually, I don’t use the plugin.
In fact it worked correctly with the previous version.
Thank you. The Volumio is a very buggy player. I can’t believe they are selling it commercialy.
I had this problem too and worked through it here:
https://github.com/volumio/volumio-plugins/issues/342
It appears that the kernel has been updated, without the lirc components being changed.
See if that fixes your issue too.
It worked perfectly, I just made the change in config.txt and hardware.conf, the other changes and deletions do not correspond to my configuration.
Thanks!!!
Many thanks @SleepingRaver!
I opened a PR on GitHub with a fix for the IR Controller plugin: https://github.com/volumio/volumio-plugins/pull/345
@gvolt - Latest version of plugin you instigated yesterday appears to be all fixed! Cheers!
:smiley: Thanks for your feedback!
Still not appeared in Volumio - no update in the app
Hi misko903,
For some reason the version number is not increased in the plugin store and still shows v1.2.1 instead of v1.2.2.
But if you uninstall the plugin and reinstall from the store you get the last version (but still shows up v1.2.1…)
It seems there are many things to do for the devs with the new kernel version (required for RasPi 4) and the devs may be on vacation - it’s summer time :wink:
Best Regards
Josef
Thanks, I’ll try it. Any chance that they will upgrade raspbian too?
Does not work…
To get a little more information you could login to volumio via ssh and execute
sudo journalctl -f Then watch the messages in the moment you try to install and/or enable the plugin. Copy the log entries related to the plugin and post them here.
Please provide some information about your system:
What hardware do you use?
Which version of Volumio are you running?
Also did you reboot Volumio after installing the latest version of the plugin?
So there it is:
When installing:
volumio@volumio:~$ sudo journalctl -f        -- Logs begin at Mon 2019-09-02 04:41:44 UTC. --
Sep 02 04:46:22 volumio volumio[936]: info: Scanning category user_interface
Sep 02 04:46:22 volumio volumio[936]: info: Scanning into folder /data/plugins/
Sep 02 04:46:22 volumio volumio[936]: info: Scanning category accessory
Sep 02 04:46:22 volumio volumio[936]: info: Cleaning folder for ir_controller
Sep 02 04:46:22 volumio volumio[936]: info: Scanning category music_service
Sep 02 04:46:22 volumio volumio[936]: info: Scanning category system_controller
Sep 02 04:46:22 volumio volumio[936]: info: Plugin folders cleanup completed
Sep 02 04:46:22 volumio volumio[936]: info: [{"prettyName":"80s80s Radio","name":"80s80s","category":"music_service","version":"1.0.0","icon":"fa-headphones","enabled":true,"active":true},{"prettyName":"Spotify","name":"spop","category":"music_service","version":"1.3.5","icon":"fa-spotify","enabled":true,"active":true},{"prettyName":"Volumio Spotify Connect2","name":"volspotconnect2","category":"music_service","version":"0.9.5","icon":"fa-spotify","enabled":true,"active":true},{"prettyName":"Youtube Playback","name":"youtube","category":"music_service","version":"0.0.9","icon":"fa-youtube","enabled":true,"active":true},{"prettyName":"Backup & Restore Data","name":"backup_restore","category":"system_controller","version":"0.7.2","icon":"fa-floppy-o","enabled":true,"active":true}]
Sep 02 04:46:56 volumio sudo[3432]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -f
Sep 02 04:46:56 volumio sudo[3432]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Sep 02 04:47:05 volumio volumio[936]: info: Downloading plugin at http://volumio.github.io/volumio-plugins/plugins/volumio/armhf/accessory/ir_controller/ir_controller.zip
Sep 02 04:47:06 volumio volumio[936]: info: END DOWNLOAD: http://volumio.github.io/volumio-plugins/plugins/volumio/armhf/accessory/ir_controller/ir_controller.zip
Sep 02 04:47:06 volumio volumio[936]: info: Folder /tmp/plugins removed
Sep 02 04:47:06 volumio volumio[936]: info: Checking if plugin already exists
Sep 02 04:47:06 volumio volumio[936]: info: Rename folder
Sep 02 04:47:06 volumio volumio[936]: info: Folder /tmp/downloaded_plugin.zip removed
Sep 02 04:47:06 volumio volumio[936]: info: Move to category
Sep 02 04:47:07 volumio volumio[936]: info: Checking if install.sh is present
Sep 02 04:47:07 volumio volumio[936]: info: Executing install.sh
Sep 02 04:47:07 volumio sudo[3535]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sh /data/plugins/accessory/ir_controller/install.sh
Sep 02 04:47:07 volumio sudo[3535]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:47:07 volumio volumio[936]: info: Installing LIRC
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie InRelease
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/main Sources
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/contrib Sources
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/non-free Sources
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/rpi Sources
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/main armhf Packages
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/contrib armhf Packages
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/non-free armhf Packages
Sep 02 04:47:07 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/rpi armhf Packages
Sep 02 04:47:08 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/main Sources
Sep 02 04:47:08 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/ui Sources
Sep 02 04:47:08 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/main armhf Packages
Sep 02 04:47:08 volumio volumio[936]: info: Hit http://archive.volumio.org jessie/ui armhf Packages
Sep 02 04:47:09 volumio volumio[936]: info: Ign http://archive.volumio.org jessie/contrib Translation-en
Sep 02 04:47:09 volumio volumio[936]: info: Ign http://archive.volumio.org jessie/main Translation-en
Sep 02 04:47:09 volumio volumio[936]: info: Ign http://archive.volumio.org jessie/non-free Translation-en
Sep 02 04:47:09 volumio volumio[936]: info: Ign http://archive.volumio.org jessie/rpi Translation-en
Sep 02 04:47:09 volumio volumio[936]: info: Ign http://archive.volumio.org jessie/ui Translation-en
Sep 02 04:47:15 volumio nmbd[765]: [2019/09/02 04:47:15.935217,  0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Sep 02 04:47:15 volumio nmbd[765]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.15 for name WORKGROUP<1d>.
Sep 02 04:47:15 volumio nmbd[765]: This response was from IP 192.168.1.31, reporting an IP address of 192.168.1.31.
Sep 02 04:47:36 volumio wpa_supplicant[829]: wlan0: WPA: Group rekeying completed with 74:4d:28:91:29:08 [GTK=CCMP]
Sep 02 04:47:44 volumio volumio[936]: info: Reading package lists...
Sep 02 04:47:45 volumio volumio[936]: info: Building dependency tree...
Sep 02 04:47:45 volumio volumio[936]: info: Reading state information...
Sep 02 04:47:45 volumio volumio[936]: info: Suggested packages:
Sep 02 04:47:45 volumio volumio[936]: info:   lirc-x setserial ir-keytable
Sep 02 04:47:45 volumio volumio[936]: info: The following NEW packages will be installed:
Sep 02 04:47:46 volumio volumio[936]: info: 0 upgraded, 1 newly installed, 0 to remove and 24 not upgraded.
Sep 02 04:47:46 volumio volumio[936]: info: Need to get 0 B/339 kB of archives.
Sep 02 04:47:46 volumio volumio[936]: info: After this operation, 1483 kB of additional disk space will be used.
Sep 02 04:47:46 volumio volumio[936]: info: Selecting previously unselected package lirc.
Sep 02 04:47:46 volumio volumio[936]: [620B blob data]
Sep 02 04:47:46 volumio volumio[936]: info: Preparing to unpack .../lirc_0.9.0~pre1-1.2_armhf.deb ...
Sep 02 04:47:46 volumio volumio[936]: info: Unpacking lirc (0.9.0~pre1-1.2) ...
Sep 02 04:47:48 volumio volumio[936]: info: Processing triggers for systemd (215-17+deb8u8) ...
Sep 02 04:47:48 volumio systemd[1]: Reloading.
Sep 02 04:47:48 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown lvalue 'ProtectKernelTunables' in section 'Service'
Sep 02 04:47:48 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Sep 02 04:47:48 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue 'ProtectKernelModules' in section 'Service'
Sep 02 04:47:48 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown lvalue 'RestrictNamespaces' in section 'Service'
Sep 02 04:47:48 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 02 04:47:48 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
Sep 02 04:47:48 volumio volumio[936]: info: Setting up lirc (0.9.0~pre1-1.2) ...
Sep 02 04:47:49 volumio systemd[1]: Reloading.
Sep 02 04:47:49 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown lvalue 'ProtectKernelTunables' in section 'Service'
Sep 02 04:47:49 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Sep 02 04:47:49 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue 'ProtectKernelModules' in section 'Service'
Sep 02 04:47:49 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown lvalue 'RestrictNamespaces' in section 'Service'
Sep 02 04:47:49 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 02 04:47:49 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
Sep 02 04:47:49 volumio systemd[1]: Starting LSB: Starts LIRC daemon....
Sep 02 04:47:49 volumio lirc[4006]: No valid /etc/lirc/lircd.conf has been found..
Sep 02 04:47:49 volumio lirc[4006]: Remote control support has been disabled..
Sep 02 04:47:49 volumio lirc[4006]: Reconfigure LIRC or manually replace /etc/lirc/lircd.conf to enable..
Sep 02 04:47:49 volumio systemd[1]: Started LSB: Starts LIRC daemon..
Sep 02 04:47:50 volumio volumio[936]: info: Processing triggers for systemd (215-17+deb8u8) ...
Sep 02 04:47:50 volumio systemd[1]: Reloading.
Sep 02 04:47:50 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown lvalue 'ProtectKernelTunables' in section 'Service'
Sep 02 04:47:50 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Sep 02 04:47:50 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue 'ProtectKernelModules' in section 'Service'
Sep 02 04:47:50 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown lvalue 'RestrictNamespaces' in section 'Service'
Sep 02 04:47:50 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 02 04:47:50 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
Sep 02 04:47:53 volumio volumio[936]: info: Applying LIRC starting policy
Sep 02 04:47:53 volumio systemd[1]: Reloading.
Sep 02 04:47:53 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown lvalue 'ProtectKernelTunables' in section 'Service'
Sep 02 04:47:53 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Sep 02 04:47:53 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue 'ProtectKernelModules' in section 'Service'
Sep 02 04:47:53 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown lvalue 'RestrictNamespaces' in section 'Service'
Sep 02 04:47:53 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 02 04:47:53 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
Sep 02 04:47:53 volumio systemd[1]: Stopping LSB: Starts LIRC daemon....
Sep 02 04:47:53 volumio systemd[1]: Stopped LSB: Starts LIRC daemon..
Sep 02 04:47:53 volumio volumio[936]: info: Creating lircrc file
Sep 02 04:47:53 volumio sudo[3535]: pam_unix(sudo:session): session closed for user root
Sep 02 04:47:53 volumio volumio[936]: Plugin install end detected on script
Sep 02 04:47:53 volumio volumio[936]: info: Install script completed
Sep 02 04:47:53 volumio volumio[936]: info: Adding reference to registry
Sep 02 04:47:53 volumio volumio[936]: info: Done installing plugin.
Sep 02 04:47:53 volumio volumio[936]: info: Folder /tmp/plugins removed
Sep 02 04:47:54 volumio volumio[936]: info: Folder /tmp/downloaded_plugin.zip removed
Sep 02 04:47:54 volumio volumio[936]: info: Folder /data/temp removed
When enabling:
Sep 02 04:51:08 volumio volumio[936]: info: Enabling plugin ir_controller
Sep 02 04:51:08 volumio volumio[936]: info: Loading plugin "ir_controller"...
Sep 02 04:51:08 volumio volumio[936]: info: PLUGIN START: ir_controller
Sep 02 04:51:08 volumio volumio[936]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Sep 02 04:51:08 volumio volumio[936]: info: HAT already loaded /proc/device-tree/ir_receiver!
Sep 02 04:51:08 volumio sudo[5684]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/lirc/hardware.conf
Sep 02 04:51:08 volumio volumio[936]: info: Done.
Sep 02 04:51:08 volumio sudo[5684]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:51:08 volumio volumio[936]: error:  message=EACCES: permission denied, open '/etc/lirc/hardware.conf', stack=Error: EACCES: permission denied, open '/etc/lirc/hardware.conf', errno=-13, code=EACCES, syscall=open, path=/etc/lirc/hardware.conf
Sep 02 04:51:08 volumio sudo[5684]: pam_unix(sudo:session): session closed for user root
Sep 02 04:51:08 volumio sudo[5686]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod -R 777 /etc/lirc/hardware.conf /etc/lirc/lircd.conf /etc/lirc/lircmd.conf /etc/lirc/lircrc
Sep 02 04:51:08 volumio sudo[5686]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:51:08 volumio volumio[936]: info: Hardware permissions set
Sep 02 04:51:08 volumio sudo[5686]: pam_unix(sudo:session): session closed for user root
Sep 02 04:51:08 volumio volumio[936]: info: lirc permissions set
Sep 02 04:51:08 volumio volumio[936]: info: lirc correctly updated
Sep 02 04:51:09 volumio sudo[5719]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl stop lirc.service
Sep 02 04:51:09 volumio sudo[5719]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:51:09 volumio systemd[1]: Stopped LSB: Starts LIRC daemon..
Sep 02 04:51:09 volumio sudo[5719]: pam_unix(sudo:session): session closed for user root
Sep 02 04:51:10 volumio sudo[5735]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start lirc.service
Sep 02 04:51:10 volumio sudo[5735]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:51:10 volumio systemd[1]: Starting LSB: Starts LIRC daemon....
Sep 02 04:51:10 volumio lirc[5747]: Loading LIRC modules:.
Sep 02 04:51:10 volumio lirc[5747]: Starting remote control daemon(s) : LIRC :Driver `UNCONFIGURED' not supported.
Sep 02 04:51:10 volumio lirc[5747]: Supported drivers:
Sep 02 04:51:10 volumio lirc[5747]: accent
Sep 02 04:51:10 volumio lirc[5747]: alsa_usb
Sep 02 04:51:10 volumio lirc[5747]: asusdh
Sep 02 04:51:10 volumio lirc[5747]: atilibusb
Sep 02 04:51:10 volumio lirc[5747]: atwf83
Sep 02 04:51:10 volumio lirc[5747]: audio_alsa
Sep 02 04:51:10 volumio lirc[5747]: awlibusb
Sep 02 04:51:10 volumio lirc[5747]: bte
Sep 02 04:51:10 volumio lirc[5747]: bw6130
Sep 02 04:51:10 volumio lirc[5747]: commandir
Sep 02 04:51:10 volumio lirc[5747]: creative
Sep 02 04:51:10 volumio lirc[5747]: creative_infracd
Sep 02 04:51:10 volumio lirc[5747]: default
Sep 02 04:51:10 volumio lirc[5747]: devinput
Sep 02 04:51:10 volumio lirc[5747]: dfclibusb
Sep 02 04:51:10 volumio lirc[5747]: dsp
Sep 02 04:51:10 volumio lirc[5747]: dvico
Sep 02 04:51:10 volumio lirc[5747]: ea65
Sep 02 04:51:10 volumio lirc[5747]: ftdi
Sep 02 04:51:10 volumio lirc[5747]: i2cuser
Sep 02 04:51:10 volumio lirc[5747]: irlink
Sep 02 04:51:10 volumio lirc[5747]: irman
Sep 02 04:51:10 volumio lirc[5747]: livedrive_midi
Sep 02 04:51:10 volumio lirc[5747]: livedrive_seq
Sep 02 04:51:10 volumio lirc[5747]: logitech
Sep 02 04:51:10 volumio lirc[5747]: macmini
Sep 02 04:51:10 volumio lirc[5747]: mp3anywhere
Sep 02 04:51:10 volumio lirc[5747]: mplay
Sep 02 04:51:10 volumio lirc[5747]: mplay2
Sep 02 04:51:10 volumio lirc[5747]: mouseremote
Sep 02 04:51:10 volumio lirc[5747]: mouseremote_ps2
Sep 02 04:51:10 volumio lirc[5747]: null
Sep 02 04:51:10 volumio lirc[5747]: pcmak
Sep 02 04:51:10 volumio lirc[5747]: pinsys
Sep 02 04:51:10 volumio lirc[5747]: pixelview
Sep 02 04:51:10 volumio lirc[5747]: samsung
Sep 02 04:51:10 volumio lirc[5747]: sb0540
Sep 02 04:51:10 volumio lirc[5747]: silitek
Sep 02 04:51:10 volumio lirc[5747]: srm7500libusb
Sep 02 04:51:10 volumio lirc[5747]: tira
Sep 02 04:51:10 volumio lirc[5747]: tira_raw
Sep 02 04:51:10 volumio lirc[5747]: udp
Sep 02 04:51:10 volumio lirc[5747]: uirt2
Sep 02 04:51:10 volumio lirc[5747]: uirt2_raw
Sep 02 04:51:10 volumio lirc[5747]: usb_uirt_raw
Sep 02 04:51:10 volumio lirc[5747]: usbx
Sep 02 04:51:10 volumio sudo[5735]: pam_unix(sudo:session): session closed for user root
Sep 02 04:51:10 volumio systemd[1]: Started LSB: Starts LIRC daemon..
Sep 02 04:51:10 volumio lirc[5747]: .
Sep 02 04:51:10 volumio lirc[5747]: Starting execution daemon: irexec: failed!
Sep 02 04:51:10 volumio volumio[936]: info: lirc correctly started
Sep 02 04:52:19 volumio nmbd[765]: [2019/09/02 04:52:19.435489,  0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Sep 02 04:52:19 volumio nmbd[765]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.15 for name WORKGROUP<1d>.
Sep 02 04:52:19 volumio nmbd[765]: This response was from IP 192.168.1.31, reporting an IP address of 192.168.1.31.
Sep 02 04:52:36 volumio wpa_supplicant[829]: wlan0: WPA: Group rekeying completed with 74:4d:28:91:29:08 [GTK=CCMP]
Sep 02 04:53:28 volumio volumio[936]: info: CoreCommandRouter::volumioGetVisibleSources
Sep 02 04:53:28 volumio volumio[936]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
Sep 02 04:53:28 volumio volumio[936]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Sep 02 04:53:28 volumio volumio[936]: info: CoreCommandRouter::volumioGetState
Sep 02 04:53:28 volumio volumio[936]: info: CoreStateMachine::getState
Sep 02 04:53:28 volumio volumio[936]: info: CorePlayQueue::getTrack 0
Sep 02 04:53:28 volumio sudo[6902]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Sep 02 04:53:28 volumio volumio[936]: info: Listing playlists
Sep 02 04:53:28 volumio volumio[936]: info: CoreCommandRouter::volumioGetQueue
Sep 02 04:53:28 volumio volumio[936]: info: CoreStateMachine::getQueue
Sep 02 04:53:28 volumio volumio[936]: info: CorePlayQueue::getQueue
Sep 02 04:53:28 volumio sudo[6902]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:53:28 volumio sudo[6905]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Sep 02 04:53:28 volumio sudo[6902]: pam_unix(sudo:session): session closed for user root
Sep 02 04:53:28 volumio sudo[6905]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:53:28 volumio sudo[6905]: pam_unix(sudo:session): session closed for user root
Sep 02 04:53:53 volumio volumio[936]: info: CoreCommandRouter::getUIConfigOnPlugin
Sep 02 04:54:35 volumio volumio[936]: info: [{"prettyName":"IR Remote Controller","name":"ir_controller","category":"accessory","version":"1.2.1","icon":"fa-magic","enabled":true,"active":true},{"prettyName":"80s80s Radio","name":"80s80s","category":"music_service","version":"1.0.0","icon":"fa-headphones","enabled":true,"active":true},{"prettyName":"Spotify","name":"spop","category":"music_service","version":"1.3.5","icon":"fa-spotify","enabled":true,"active":true},{"prettyName":"Volumio Spotify Connect2","name":"volspotconnect2","category":"music_service","version":"0.9.5","icon":"fa-spotify","enabled":true,"active":true},{"prettyName":"Youtube Playback","name":"youtube","category":"music_service","version":"0.0.9","icon":"fa-youtube","enabled":true,"active":true},{"prettyName":"Backup & Restore Data","name":"backup_restore","category":"system_controller","version":"0.7.2","icon":"fa-floppy-o","enabled":true,"active":true}]
Sep 02 04:54:38 volumio volumio[936]: info: CoreCommandRouter::getUIConfigOnPlugin
Sep 02 04:55:04 volumio volumio[936]: info: CALLMETHOD: accessory ir_controller saveIROptions [object Object]
Sep 02 04:55:04 volumio volumio[936]: info: CoreCommandRouter::executeOnPlugin: ir_controller , saveIROptions
Sep 02 04:55:04 volumio volumio[936]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Sep 02 04:55:04 volumio sudo[7695]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/lirc/hardware.conf
Sep 02 04:55:04 volumio sudo[7695]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:55:04 volumio sudo[7697]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod -R 777 /etc/lirc/hardware.conf /etc/lirc/lircd.conf /etc/lirc/lircmd.conf /etc/lirc/lircrc
Sep 02 04:55:04 volumio sudo[7695]: pam_unix(sudo:session): session closed for user root
Sep 02 04:55:04 volumio sudo[7697]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:55:04 volumio volumio[936]: info: Hardware permissions set
Sep 02 04:55:04 volumio sudo[7697]: pam_unix(sudo:session): session closed for user root
Sep 02 04:55:04 volumio volumio[936]: info: lirc permissions set
Sep 02 04:55:04 volumio volumio[936]: info: lirc correctly updated
Sep 02 04:55:05 volumio sudo[7722]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl stop lirc.service
Sep 02 04:55:05 volumio sudo[7722]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:55:05 volumio systemd[1]: Stopping LSB: Starts LIRC daemon....
Sep 02 04:55:05 volumio lirc[7727]: Stopping execution daemon: irexec: failed!
Sep 02 04:55:05 volumio lirc[7727]: Stopping remote control daemon(s): LIRC: failed!
Sep 02 04:55:05 volumio systemd[1]: Stopped LSB: Starts LIRC daemon..
Sep 02 04:55:05 volumio sudo[7722]: pam_unix(sudo:session): session closed for user root
Sep 02 04:55:06 volumio sudo[7750]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start lirc.service
Sep 02 04:55:06 volumio sudo[7750]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 02 04:55:06 volumio systemd[1]: Starting LSB: Starts LIRC daemon....
Sep 02 04:55:06 volumio lirc[7755]: Loading LIRC modules:.
Sep 02 04:55:06 volumio kernel: input: lircd as /devices/virtual/input/input3
Sep 02 04:55:06 volumio lircd-0.9.0-pre1[7764]: lircd(default) ready, using /var/run/lirc/lircd
Sep 02 04:55:06 volumio lirc[7755]: Starting remote control daemon(s) : LIRC :.
Sep 02 04:55:06 volumio lircd-0.9.0-pre1[7764]: accepted new client on /var/run/lirc/lircd
Sep 02 04:55:06 volumio lirc[7755]: Starting execution daemon: irexec:.
Sep 02 04:55:06 volumio systemd[1]: Started LSB: Starts LIRC daemon..
Sep 02 04:55:06 volumio sudo[7750]: pam_unix(sudo:session): session closed for user root
Sep 02 04:55:06 volumio volumio[936]: info: lirc correctly started
Thank you for the logs.
Please describe what hardware you are using and especially how the IR receiver is connected. Also please post the result of cat /boot/config.txt
I am using Chinese clone of hifiberry DAC+, PiFi DAC+ 2.0
IR sensor is directly mounted on the board.
Output from cat command:
volumio@volumio:~$ cat /boot/config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
dtoverlay=hifiberry-dacplus
