Take a look at this topic, it might help: https://volumio.org/forum/next-x86-development-kernel-hardware-debian-stretch-t9651.html
Please note that version 2.394 is a stable dev version, though not supported and not updatable.
Many thanks for your quick reply!
I tried with ver 2.394 without success: same symptoms as with 2.411
I won’t be able to do further tests (this installation is not at home) so I installed volumio on a pi instead.
fair enough, still a valuable feedback as I’m sure someone else will run into the same issue.
Not able to do any development versions at the moment, as you have been able to install on a PI I presume you’re happy for the time being.
J4205-ITX
the problem still exists or has worked???
