Installing LMS along Volumio
Created a new topic to avoid spamming on the LMS-Docker plugin
You can always remove the plugin and install LMS manually. (you’ll loose all settings and need to configure LMS again)
Factory reset
upgraded to Volumio V3.429
sudo dpkg-reconfigure tzdata
sudo apt-get update
sudo apt-get install libcrypt-openssl-rsa-perl
wget https://downloads.slimdevices.com/LogitechMediaServer_v8.3.0/logitechmediaserver_8.3.0_all.deb
sudo dpkg -i logitechmediaserver_8.3.0_all.deb
rm logitechmediaserver_8.3.0_all.deb
Thanks. Updated the same
iam getting the following error while installing:
An error occurred in install_docker.sh: line 10: apt-get install -y ca-certificates curl gnupg lsb-release
Installation cannot proceed.
Nowhere I gave the instruction to update the docker, hence I said, remove it and install LMS…
I flashed a new volumio and tried to install as per your above instructions, but iam getting following error:
login as: volumio
volumio@192.168.1.7’s password:
                       ___
                      /\_ \                        __
         __  __    ___\//\ \    __  __    ___ ___ /\_\    ___
        /\ \/\ \  / __`\\ \ \  /\ \/\ \ /' __` __`\/\ \  / __`\
        \ \ \_/ |/\ \L\ \\_\ \_\ \ \_\ \/\ \/\ \/\ \ \ \/\ \L\ \
         \ \___/ \ \____//\____\\ \____/\ \_\ \_\ \_\ \_\ \____/
          \/__/   \/___/ \/____/ \/___/  \/_/\/_/\/_/\/_/\/___/
             Free Audiophile Linux Music Player - Version 3.0
          © 2015-2021 Michelangelo Guarise - Volumio Team - Volumio.org
permitted by applicable law.
Welcome to Volumio for Raspberry Pi (5.10.92-v7+ armv7l)
volumio@volumiorpi:~$ sudo apt-get update && sudo apt-get install libcrypt-openssl-rsa-perl
Get:1 https://deb.nodesource.com/node_14.x buster InRelease [4584 B]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:3 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Get:4 https://deb.nodesource.com/node_14.x buster/main armhf Packages [786 B]
Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Get:6 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
Get:7 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.8 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
Get:9 http://raspbian.raspberrypi.org/raspbian buster/rpi armhf Packages [1360 B]
Fetched 13.6 MB in 18s (751 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
  libcrypt-openssl-bignum-perl libcrypt-openssl-random-perl
The following NEW packages will be installed:
  libcrypt-openssl-bignum-perl libcrypt-openssl-random-perl libcrypt-openssl-rsa-perl
0 upgraded, 3 newly installed, 0 to remove and 16 not upgraded.
Need to get 59.0 kB of archives.
After this operation, 212 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 http://raspbian.mirror.net.in/raspbian/raspbian buster/main armhf libcrypt-openssl-bignum-perl armhf 0.09-1+b1
  Connection failed [IP: 103.195.68.3 80]
Err:2 http://raspbian.mirror.net.in/raspbian/raspbian buster/main armhf libcrypt-openssl-random-perl armhf 0.15-1+b1
Err:3 http://raspbian.mirror.net.in/raspbian/raspbian buster/main armhf libcrypt-openssl-rsa-perl armhf 0.31-1+b1
E: Failed to fetch http://raspbian.mirror.net.in/raspbian/raspbian/pool/main/libc/libcrypt-openssl-bignum-perl/libcrypt-openssl-bignum-perl_0.09-1+b1_armhf.deb  Connection failed [IP: 103.195.68.3 80]
E: Failed to fetch http://raspbian.mirror.net.in/raspbian/raspbian/pool/main/libc/libcrypt-openssl-random-perl/libcrypt-openssl-random-perl_0.15-1+b1_armhf.deb  Connection failed [IP: 103.195.68.3 80]
E: Failed to fetch http://raspbian.mirror.net.in/raspbian/raspbian/pool/main/libc/libcrypt-openssl-rsa-perl/libcrypt-openssl-rsa-perl_0.31-1+b1_armhf.deb  Connection failed [IP: 103.195.68.3 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
Hit:1 https://deb.nodesource.com/node_14.x buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
volumio@volumiorpi:~$ wget https://downloads.slimdevices.com/LogitechMediaServer_v8.3.0/logitechmediaserver_8.3.0_all.deb
--2023-02-17 14:40:03--  https://downloads.slimdevices.com/LogitechMediaServer_v8.3.0/logitechmediaserver_8.3.0_all.deb
Resolving downloads.slimdevices.com (downloads.slimdevices.com)... 52.84.12.79, 52.84.12.73, 52.84.12.14, ...
Connecting to downloads.slimdevices.com (downloads.slimdevices.com)|52.84.12.79|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 52860924 (50M) [application/x-troff-man]
Saving to: 'logitechmediaserver_8.3.0_all.deb'
logitechmediaserver_8.3.0_a 100%[===========================================>]  50.41M  5.09MB/s    in 7.9s
2023-02-17 14:40:19 (6.37 MB/s) - 'logitechmediaserver_8.3.0_all.deb' saved [52860924/52860924]
--2023-02-17 14:40:51--  https://downloads.slimdevices.com/LogitechMediaServer_v8.3.0/logitechmediaserver_8.3.0_all.deb
Saving to: 'logitechmediaserver_8.3.0_all.deb.1'
logitechmediaserver_8.3.0_a 100%[===========================================>]  50.41M  10.7MB/s    in 12s
2023-02-17 14:41:03 (4.22 MB/s) - 'logitechmediaserver_8.3.0_all.deb.1' saved [52860924/52860924]
volumio@volumiorpi:~$ sudo dpkg -i logitechmediaserver_8.3.0_all.deb
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
[sudo] password for volumio:
Selecting previously unselected package logitechmediaserver.
(Reading database ... 34537 files and directories currently installed.)
Preparing to unpack logitechmediaserver_8.3.0_all.deb ...
Unpacking logitechmediaserver (8.3.0) ...
dpkg: dependency problems prevent configuration of logitechmediaserver:
 logitechmediaserver depends on libcrypt-openssl-rsa-perl; however:
  Package libcrypt-openssl-rsa-perl is not installed.
dpkg: error processing package logitechmediaserver (--install):
 dependency problems - leaving unconfigured
Processing triggers for systemd (241-7~deb10u8+rpi1) ...
Errors were encountered while processing:
 logitechmediaserver
volumio@volumiorpi:~$ Selecting previously unselected package logitechmediaserver.
 logitechmediaserver
-bash: Selecting: command not found
volumio@volumiorpi:~$ (Reading database ... 34537 files and directories currently installed.)
-bash: Reading: command not found
volumio@volumiorpi:~$ Preparing to unpack logitechmediaserver_8.3.0_all.deb ...
-bash: Preparing: command not found
volumio@volumiorpi:~$ Unpacking logitechmediaserver (8.3.0) ...
-bash: syntax error near unexpected token `('
volumio@volumiorpi:~$ dpkg: dependency problems prevent configuration of logitechmediaserver:
-bash: dpkg:: command not found
volumio@volumiorpi:~$  logitechmediaserver depends on libcrypt-openssl-rsa-perl; however:
-bash: logitechmediaserver: command not found
-bash: however:: command not found
volumio@volumiorpi:~$   Package libcrypt-openssl-rsa-perl is not installed.
-bash: Package: command not found
volumio@volumiorpi:~$ dpkg: error processing package logitechmediaserver (--install):
volumio@volumiorpi:~$  dependency problems - leaving unconfigured
-bash: dependency: command not found
volumio@volumiorpi:~$ Processing triggers for systemd (241-7~deb10u8+rpi1) ...
volumio@volumiorpi:~$ Errors were encountered while processing:
-bash: Errors: command not found
volumio@volumiorpi:~$ volumio@volumiorpi:~$
-bash: volumio@volumiorpi:~$: command not found
Please advise
Please check if your date time settings are correct.
Seems your system date/time are off.
Factory reset.
Upgraded to:
volumio@volumiohpdev:~$ sudo dpkg-reconfigure tzdata
Current default time zone: 'Europe/Amsterdam'
Local time is now:      Fri Feb 17 14:45:25 CET 2023.
Universal Time is now:  Fri Feb 17 13:45:25 UTC 2023.
volumio@volumiohpdev:~$ sudo apt-get update
Get:1 http://deb.debian.org/debian buster InRelease [122 kB]
Get:2 https://deb.nodesource.com/node_14.x buster InRelease [4584 B]
Get:3 http://deb.debian.org/debian buster/main i386 Packages [7866 kB]
Get:4 https://deb.nodesource.com/node_14.x buster/main amd64 Packages [776 B]
Get:5 http://deb.debian.org/debian buster/main amd64 Packages [7909 kB]
Get:6 http://deb.debian.org/debian buster/main Translation-en [5969 kB]
Get:7 http://deb.debian.org/debian buster/contrib amd64 Packages [50.1 kB]
Get:8 http://deb.debian.org/debian buster/contrib i386 Packages [46.0 kB]
Get:9 http://deb.debian.org/debian buster/contrib Translation-en [44.2 kB]
Get:10 http://deb.debian.org/debian buster/non-free amd64 Packages [87.8 kB]
Get:11 http://deb.debian.org/debian buster/non-free i386 Packages [76.3 kB]
Get:12 http://deb.debian.org/debian buster/non-free Translation-en [88.9 kB]
Fetched 22.3 MB in 3s (6882 kB/s)
volumio@volumiohpdev:~$ sudo apt-get install libcrypt-openssl-rsa-perl
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
Need to get 63.1 kB of archives.
After this operation, 232 kB of additional disk space will be used.
Get:1 http://deb.debian.org/debian buster/main amd64 libcrypt-openssl-bignum-perl amd64 0.09-1+b1 [25.9 kB]
Get:2 http://deb.debian.org/debian buster/main amd64 libcrypt-openssl-random-perl amd64 0.15-1+b1 [11.2 kB]
Get:3 http://deb.debian.org/debian buster/main amd64 libcrypt-openssl-rsa-perl amd64 0.31-1+b1 [26.1 kB]
Fetched 63.1 kB in 0s (583 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libcrypt-openssl-bignum-perl.
(Reading database ... 45021 files and directories currently installed.)
Preparing to unpack .../libcrypt-openssl-bignum-perl_0.09-1+b1_amd64.deb ...
Unpacking libcrypt-openssl-bignum-perl (0.09-1+b1) ...
Selecting previously unselected package libcrypt-openssl-random-perl.
Preparing to unpack .../libcrypt-openssl-random-perl_0.15-1+b1_amd64.deb ...
Unpacking libcrypt-openssl-random-perl (0.15-1+b1) ...
Selecting previously unselected package libcrypt-openssl-rsa-perl.
Preparing to unpack .../libcrypt-openssl-rsa-perl_0.31-1+b1_amd64.deb ...
Unpacking libcrypt-openssl-rsa-perl (0.31-1+b1) ...
Setting up libcrypt-openssl-bignum-perl (0.09-1+b1) ...
Setting up libcrypt-openssl-random-perl (0.15-1+b1) ...
Setting up libcrypt-openssl-rsa-perl (0.31-1+b1) ...
Processing triggers for man-db (2.8.5-2) ...
volumio@volumiohpdev:~$ wget https://downloads.slimdevices.com/LogitechMediaServer_v8.3.0/logitechmediaserver_8.3.0_all.deb
--2023-02-17 14:46:31--  https://downloads.slimdevices.com/LogitechMediaServer_v8.3.0/logitechmediaserver_8.3.0_all.deb
Resolving downloads.slimdevices.com (downloads.slimdevices.com)... 65.9.86.30, 65.9.86.15, 65.9.86.67, ...
Connecting to downloads.slimdevices.com (downloads.slimdevices.com)|65.9.86.30|:443... connected.
logitechmediaserver 100%[===================>]  50.41M  40.6MB/s    in 1.2s
2023-02-17 14:46:33 (40.6 MB/s) - 'logitechmediaserver_8.3.0_all.deb' saved [52860924/52860924]
volumio@volumiohpdev:~$ sudo dpkg -i logitechmediaserver_8.3.0_all.deb
(Reading database ... 45061 files and directories currently installed.)
Setting up logitechmediaserver (8.3.0) ...
Adding system user `squeezeboxserver' (UID 118) ...
Adding new user `squeezeboxserver' (UID 118) with group `nogroup' ...
Not creating home directory `/usr/share/squeezeboxserver'.
Created symlink /etc/systemd/system/multi-user.target.wants/logitechmediaserver.service → /lib/systemd/system/logitechmediaserver.service.
Processing triggers for systemd (241-7~deb10u8) ...
$ sudo apt-get install libcrypt-openssl-rsa-perl wget
Reading package lists… Done
Reading state information… Done
Package libcrypt-openssl-rsa-perl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘libcrypt-openssl-rsa-perl’ has no installation candidate
Did you follow the steps from the first post?
its nowt getting installed.
getting error.
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/lmsde/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/lmsde/volumio/buster/armhf
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
Installing Docker…
Hit:1 Index of /node_14.x/ buster InRelease
Get:2 Index of /debian buster InRelease [32.6 kB]
Get:3 Index of /raspbian buster InRelease [15.0 kB]
Get:4 Index of /debian buster/main armhf Packages [392 kB]
Get:5 Index of /raspbian buster/main armhf Packages [13.0 MB]
Fetched 13.5 MB in 29s (469 kB/s)
Building dependency tree…
ca-certificates is already the newest version (20200601~deb10u2).
gnupg is already the newest version (2.2.12-1+rpi1+deb10u1).
lsb-release is already the newest version (10.2019051400+rpi1).
curl is already the newest version (7.74.0-1.2~bpo10+1).
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
logitechmediaserver : Depends: libcrypt-openssl-rsa-perl but it is not going to be installed
Again, follow the instructions I gave.
Nowhere I have mention to start installing any LMS plugin.
I tried but getting following error message always:
login as: volumio
volumio@192.168.1.2’s password:
___
/_ \ __
__ __ //\ \ __ __ ___ ___ /_\ ___
/\ /\ \ / __\\ \ \ /\ \/\ \ /' __ __\/\ \ / __
\ \ _/ |/\ \L\ \
\ _\ \ _\ /\ /\ /\ \ \ /\ \L\
\ _
/ \ _//_\ _/\ _\ _\ _\ _\ _/
// // // // /////////___/
volumio@volumiousbbridge:~$ sudo dpkg-reconfigure tzdata
Current default time zone: ‘Europe/Amsterdam’
Local time is now: Sun Feb 19 14:35:28 CET 2023.
Universal Time is now: Sun Feb 19 13:35:28 UTC 2023.
volumio@volumiousbbridge:~$ sudo dpkg -i logitechmediaserver_8.3.0_all.deb
dpkg: error: cannot access archive ‘logitechmediaserver_8.3.0_all.deb’: No such file or directory
volumio@volumiousbbridge:~$ sudo apt-get update
Get:1 Index of /debian buster InRelease [32.6 kB]
Get:2 Index of /raspbian buster InRelease [15.0 kB]
Get:3 Index of /node_14.x/ buster InRelease [4584 B]
Get:4 Index of /raspbian buster/main armhf Packages [13.0 MB]
Get:5 Index of /debian buster/main armhf Packages [392 kB]
Get:6 Index of /node_14.x/ buster/main armhf Packages [786 B]
Get:7 Index of /raspbian buster/contrib armhf Packages [58 .8 kB]
Get:8 Index of /raspbian buster/non-free armhf Packages [1 04 kB]
Get:9 Index of /raspbian buster/rpi armhf Packages [1360 B ]
Fetched 13.6 MB in 25s (542 kB/s)
volumio@volumiousbbridge:~$ sudo apt-get install libcrypt-openssl-rsa-perl
0 upgraded, 3 newly installed, 0 to remove and 17 not upgraded.
Do you want to continue? [Y/n] Y
You have performed a factory reset?
what is the output of the below command and is it the correct time date stamp?
date
what is the output of:
sudo apt-get update
Yes performed Factory Reset.
the out put of sudo apt-get update is given below:
login as: volumio
___
/_ \ __
\ \ _/ |/\ \L\ \
\ _
Last login: Sun Feb 19 14:34:50 2023 from 192.168.1.44
Hit:1 Index of /raspbian buster InRelease
Hit:2 Index of /debian buster InRelease
Hit:3 Index of /node_14.x/ buster InRelease
volumio@volumiousbbridge:~$ ^C
Where are you located?
Seems you have some network problems, as all 3 packages are available on the given URL.
Please modify your network settings and set a fixed DNS:
8.8.8.8
8.8.4.4
Iam Located in India
So why did you set the date to Europe/Amsterdam? You should select your local time zone.
I guess it’s 4,5 hours later over there
I tried the time zone here and was not working so tried changing time zone to Europe
So do the following:
  • Set the customize DNS
  • Set the correct timezone
