It was done .Stills same
what does the shell command date show?
And please post a full log
I see a bunch of errors in the log.
Please reflash a new SD with Raspberry Pi Imager, don’t connect any disk or USB device, don’t install any plugin.
First setup Volumio, then install LMS. If it still don’t work I have no idea.
hmmm will try
After reflash with new SD with RPi imager. Not connectin USB harddrive:
error log:
http://logs.volumio.org/volumio/gffmKJe.html
what does the shell command date return and is it in line with your time?
So far I can see that the first 3 commands ran success full:
Feb 20 19:02:30 volumio-usb-bridge sudo[1628]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/usr/sbin/dpkg-reconfigure tzdata
Feb 20 19:02:30 volumio-usb-bridge sudo[1628]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Feb 20 19:02:34 volumio-usb-bridge sudo[1628]: pam_unix(sudo:session): session closed for user root
Feb 20 19:02:48 volumio-usb-bridge sudo[1655]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/usr/bin/apt-get update
Feb 20 19:02:48 volumio-usb-bridge sudo[1655]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Feb 20 19:03:16 volumio-usb-bridge sudo[1655]: pam_unix(sudo:session): session closed for user root
Feb 20 19:03:55 volumio-usb-bridge sudo[1850]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/usr/bin/apt-get install libcrypt-openssl-rsa-perl
Feb 20 19:03:55 volumio-usb-bridge sudo[1850]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Feb 20 19:04:03 volumio-usb-bridge sudo[1850]: pam_unix(sudo:session): session closed for user root
Feb 20 19:04:13 volumio-usb-bridge sshd[1602]: pam_unix(sshd:session): session closed for user volumio
Yes date and time is correct
So are there still issues then?
I even tried on installing another RPi 3B+ board. thinking it might be issue of allo USB Brdige, Still same issue
Have no suggestions anymore.
Just want to say thank you! And let you know that instructions at the first post are working fine - at least for me.
I did a clean install from image (“Volumio-3.631-2024-02-21-pi.zip”), then installed the latest LMS (“logitechmediaserver_8.5.0_all.deb”).
