Just installed Volumio V3 on Elitedesk G3 704. It uses an unnamed usb wifi stick.
My problem is,
Wifi fallback never happens
Automatic connection to a wifi network never happens.
I can connect to a network myself but never by itself.
on a different topic, the UI asks to remember the passw for each network but stores the one same ( the last inputted) password for all ie if I have 3 different passwords for 3 networks, only the last one is stored as the passw for all. That passw is also stored as the passw for my volumio login.
I used volumio on a RPi for several years and it never gave me such problems.
>>> This is a specific thread to report x86 issues.
The first post in that thread tells you exactly which information you need to supply in order to get support for your wifi issue.
Pay attention to the ‘inxi’ and the ‘log’ parts, these are vital!
This is the way Volumio currently works, but it is a question for the core team.
This question has gone unnoticed. 100% guaranteed because it has no relation with your post title.
In case you want an answer, repost it as a seperate issue.
Best not to put unrelated questions in the same post.
