Volumio cannot automatically update your library from a NAS due to limmitations of the inotify in linux which does not work on network mounted devices.
So with the use of cron we can get it to update on startup, not as nice as dynamically updating your library but it is what it is.
It is not just as simple as running an update command at startup as if the network is not up or the NAS has not yet been mounted you will end up with an empty database.
So we also have to detect that the NAS has been mounted before running the update.
But First things first Backup or use a spare SD card just in case
SSH into Volumio
Install cron
sudo apt update
sudo apt install cron
Edit cron
crontab -e
This should open a nano edit window with a load of commented text.
scroll to the bottom and add the line…
@reboot ./start.sh
write out(ctrl o) and exit (ctrl x)
That has just told cron that at after a reboot to run a script called start.sh
Now we make a script to detect the mount called start.sh
First we need to find out what your mountpoint is with…
findmnt -l
you will get a list of all the mounts, now find your NAS
this is mine…
/mnt/NAS/Server //192.168.0.10/#~Muzic~#
/mnt/NAS/Server You will need this part for your script ( yours will be different)
Now make the script
nano start.sh
which will open an empty nano edit window then paste in the following, but remember to change your --mountpoint name (2nd line) to the one you found earlier
#! /bin/bash
if findmnt --mountpoint /mnt/NAS/Server;
then
sleep 5
mpc update --wait NAS/
else
sleep 2
exec bash "$0" "$@"
fi
Make the script executable
chmod +x start.sh
Thats it, all going well every time you turn on Volumio will update your library from your NAS
